If i switch on the ups it not working,before beep sound is coming but now even that beep sound stoped
    President:
  • 1,138 Answers
Replaced the battery inside.. or if the battery is still reusable, filled it with distilled water to charge again..
Posted on May 15, 2010
The door ajar beeping comes on anytime a door is open, whether or not a key is in the ignition.
The light and the beeping are two differant things. Headlight switch on? Or the switch were the key gos may think the key is still in the switch.
May 18, 2012 | 2002 BMW 3 Series
My 2003 Kia spectra overdrive stoped working. it used to sometimes work then it stoped. The light on the dash that says if i'm in overdrive or not does not even come on any more. what can I do to solve...
You may just have a dash light burned out. While driving over 50 mph you can activate the switch on the shift lever (it's a push button) and even if the light doesn't come on in the dash you should be able to see if you are in overdrive (will speed up) or if you just took it out of overdrive (slows down or motor runs faster at the same speed).
Jan 09, 2011 | 2003 Kia Spectra
Beeeeep beep beep sounds on start
The beep comes when the RAM is not detceted by the Mainboard during the system start up. It's usually accompanied by no display on the Monitor.
Open the Notebook and remove the RAM and place it back again and check if it work. you can even try by inserting the RAM in different slot too.
If the problem still persists, replace the RAM.
That's it.
Jan 27, 2010 | IBM ThinkPad T42 Notebook
My electronic seat control stoped working
Sounds like no power to the seat motor or yransmission. There isnt a fuse for the seats, First start with the seat switch. It might be just loose ( a common fault ) If not loose, take a test light and start checking for power. . Possible bad switch, motor, transmission, or wiring.
Mar 27, 2009 | 1980 Cadillac Deville
Display problem
  replace the power supplay smps,
Jan 12, 2009 | Intel Server Board SE7501HG2 Motherboard
Replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum light won't shut off even with door closed. Dryer will not work but all panel lights function normally - UNTIL you press start. Dryer...
Hello jmylymok,
Welcome to Fizya,
You said, you replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum light won't shut off even with door closed. Dryer will not work but all panel lights function normally - UNTIL you press start. Dryer just beeps and doesn't work. When I tried the troubleshooting solutions, the error 6E comes up. What does this mean?
This sounds like the reason your bulb went out was more than just a bulb normally dying!
There is a short, or in that socked or the switch or it affected the the control panel too!!
This sounds like a hands on diagnoses job!
Let me know how it goes.
Huuum
Oct 08, 2008 | Dryers
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Jul 05, 2008 | E-Machines eMachines Desktop PC
Doesnt come on
uh oh. Sounds Like Loose screws. Or maybe Something in the led light area!
Feb 11, 2008 | Polaroid I533P Digital Camera
Ibm laptop problem
The beeps are telling you something is not right.
Every beep is different and I'm not 100% on what means what.
Most likely something is not inserted right into the motherboard.
Go back and check you inserted the ram correctly, if that dosn't work try checking your cables (ide, power, etc.) and your cards (video, sound, etc.) as they might have slipped out of place when inserting the ram.
You might even have a bad/faulty part in the motherboard. Check the new ram stick and see if it works without it.
These basic troubleshooting steps should help you find the problem. If not it could be the cpu is burnt out.....the way to know this is if you unplug it, the beeps will disapeir or change completely.
Maby someone else on FixYa could tell you what the exact beep could be but I'm pretty sure its just something not plugged in right or a faulty part like I had just mentioned. Either way your computer should work fine once the problem is traced and fixed.
Dec 27, 2007 | IBM ThinkPad A31 Notebook
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
