Question about Frigidaire FAC084N7A Air Conditioner
Frigidaire fac084n7a1 cooling system troubleshooting
I have a frigidaire fac084n7a1 which has a non working fan. I think I hear the compressor turning on. Is there a way to check the cooling system independent of the fan working?
    Novelist:
    Champion:
  • 246 Answers
There are a few checks that could be done, i.e. you could 'ohm the compressor out' to see if it had a 'short, or its windings are 'opened.'
Or - if there was a valve on the AC - you could tell if the system was holding it's refrigerant or not - you could also visually examine both coils to see if they were 'clean.'
But to 'make sure' the AC is operating 'correctly' will require all the components to be working - including the fan motor.
Posted on May 15, 2010
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Will not get cold
Hi Ebony! Are you having issues with the unit turning on at all and staying on? Or do you not hear the unit turning on and running? If you hear no noise, to show the unit is running (compressor turning on), you would need to contact a professional at your earliest convenience. The compressor and sealed system are not turning on. If you hear the compressor running, but the unit is not cooling you have a coolant/sealed system concern. Please contact Frigidaire and a professional to repair the unit.
Sep 04, 2013 | Frigidaire Freezer GLRT183TD
A non programmable digital cheap thermostat indicates low battery. replace with new battery. still not cooling. is there a reset when replacing the batterly. can a low battery cause the system to stop...
No, The only thing you may loose replacing the thermostat battery's would be the time/date. All default pre-programming will not be lost. The thermostat controls the unit. If the unit is coming on then the t-stat is working. Confirm the unit is coming on when the T-stat tells it to.Turn the t-stat to the off position, have someone go outside to the condenser unit. Turn the unit on and listen for the fan and the compressor (2) different sounds from the unit. Feel the lines that connect to the house, the larger line should feel cool to cold and the smaller line should feel warm to hot. If you do not hear the compressor, or suspect it is not coming on with the fan, then you may have some other issue. In the heat we have been having one good suspect is a bad compressor start capacitor. The fan comes on but not the compressor,,this is a good indication the cap. is bad.. On the wall by your outside unit is a power disconnect. Open the box and pull the disconnect or flip the breaker to the off position. Now have someone turn the T-stat on and wait a minute then off and wait a minute, on and off ... you should hear a relay clicking on/off or in/out inside the control box of the A/C unit. When in the on position you should hear a slight buzzing sound also once the relay pulls in, this will tell you the t-stat is telling the unit what it should be doing. If all this is good then your unit is just is not cooling right and needs further troubleshooting. Hope this helps FixYa up.
Aug 18, 2011 | Heating & Cooling
Top freezer - not freezing - thermostat dial for cooler - no change when moved to colder. do not hear a fan or compressor turn on - of course lower not cooling either. (frigidare) model #...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Frigidaire Refrigerators
My gallery frigidaire refrigerator is on, the light works, I can hear the fan going but it doesn't get cold, neither the fridge or freezer
Refrigerator
heatman101
My frigidaire air conditioner model FAA060p7a will not cool the fan works fine but on cool the compressor does not kick on, if I turn the the temp knob you can hear it click behind the knob like its...
The problem here is the compressor.... it has failed and will not start. You can try to replace the capacitor and see if it will go but most likely the compressor is toast. I t will cost more to replace it then to buy a new unit.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Frigidaire FAA060P7A Air Conditioner
My frigidaire is not getting cold. Is there a way to troubleshoot to detemine if it's the compressor gone bad?
Good day,
Here is a basic checklist any qualified tech would use to isolate why a refrigerator won't cool.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer or electronic defrost control.
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
As you can see, there are multiple reasons a refrigerator won't cool, or cool properly.
To zero in on the compressor might take you away from the true non-cooling reason.
However. The compressor might have a defective relay or thermal overload that would prevent it from starting or running. Theses items can be removed from the compressor and taken to any appliance parts houses. Most all would be glad to test them for you.
As well, the compressor could have a bad valve internally that would prevent the compressor from pumping refrigerant, or there could be a restriction in the refrigeration lines preventing the refrigerant from circulating properly, or the windings in the compressor could be burned out or shorted, or lastly, the system could have developed a leak. All of the above compressor related issues, except for the first one could only be checked by a qualified tech.
I would treat the problem as a whole with the compressor being one of the potential issues.
Not to throw a monkey wrench into this but a refrigerator is like a car.
9 out of 10 times the problem and solution are obvious. It's that last 10% that take all the training and experience.
May 19, 2010 | Frigidaire FRS26H5AS Side by Side...
Frigidaire refrigerator does not seem to be cooling or freezing completely. Frigidaire refrigerator does not make any noise and does not seem to be cooling or freezing. I have checked the back of the unit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
nmnm
Sep 24, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Refrigerator not cooling
Is the fan on the bottom on? Do you hear the compressor kick off and on within a minute? No/ Is the evaporator fan running? Do you have frost on the evaporator? Frost is a sign that the defrost isnt working. If evap fan doesnt run it wont cool the refrigerator. If everything is running and no frost buildup in freezer then you have a sealed system problem and need of a tech.
Jul 25, 2009 | Kenmore 50522 / 50524 Side by Side...
Frigidaire does not work (freezer and cool area)
what can u hear. u should hear fan in freezer. fan in back. is compressor running. is ice in freezer on back wall. are both sides not cooling. post more info to go by
Jul 02, 2008 | Frigidaire FRS26RLECS Side by Side...
Frigidaire FAC084N7A Air Conditioner Logo
182 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
