Question about Gateway GT5220 PC Desktop
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I PLIUG IT IN TO SATA PLUG AND TRY AND BUT MY WIN 7 ULTIMATE IT SAYS "BOOT MANAGER MISSING ,,SO I BURNT A BOOTABLE RECOVERY/REPAIR DISC AND STILL CANT GET IT TO BOOT BACK UP EVEN WHEN I UNPLUG EVERYTHING ELSE AND TRY IT STILL TAKES FOREVER THEN SAYS BOOT MANAGER MISSING....!!!! I AM TRYING TO MAKE IT WHERE MY 250GB/IDE CAN BOOT XP WHEN I NEED IT AND MY 500GB/SATA WILL BOOT (WINDOWS7-64BIT) PRIMARY PLEASE PLEASE HELP "
    Champion:
  • 218 Answers
Ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
Posted on May 15, 2010
WHAT HD & SIZE RECOMMENDED FOR MY GATEWAY 500S PC WITH OS XP?
You cannot use a SATA (serial ATA HDD in this machine. You need a PATA (parallel ATA) HDD, also known as IDE, ULTRA IDE, ULTRA ATA. This has a 40-pin ribbon connector & a 4-pin power connector.
Sizes generally available would be 80GB up to 250GB, although very few PATA drives are now sold since SATA is the new standard.
Jan 25, 2013 | Gateway GT5220 PC Desktop
What is the maxium hard drive will my k8v-x support
You have to limiting factors when determining max HDD size. 1) IDE or SATA interfaces. 2. 32 bit or 64bit Operatings System. With a 32 bit OS you are limited to 2TB per drive. Although I think 500GB is the largest IDE drive you can get.
Nov 23, 2011 | ASUS K8V-X Motherboard
My HDD will going to corrupt, so i need to buy one, but i don't know that which HDD is compatible with my AMD Athlon XP 2000 PC. Could any one suiggest that how much maximum capacity HDD Support my PC....
Hard Disk upto 500GB capacity can be added to most of the PCs. As regards compatibility, first you have to check the motherboard for SATA Hard Disk interface as newer hard disks are SATA. Adding the hard disk has nothing to do with the processor. However, motherboard should have the connecting port/ option (such as SATA). Some motherboards support both IDE and SATA devices. Please check the motherboard for SATA Port. You may find the motherboard model/ system model and google a bit for its specification. (You have mentioned AMD Athlon XP 2000, which is the Processor not the motherboard)
If SATA is available on your motherboard, you may add Sata drives of 250-500-750GB drives according to you requirements. Otherwise you have to look for IDE hard Disk.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 24, 2011 | AMD Athlon XP 2000+, 1.67 GHz Retail...
My desktop computer keeps freezing about 3-5 mins into start up with windows 7 ultimate 32 bit. I attempted to install windows 7 pro 64 bit, formatted the hard drive, then started to install and my...
a custom built computer check every connection a computer needs current and data to travel up to and through every device for a computer to work properly
check the cmos battery make sure the seat is cleam this will apply to the ram as well make sure the sockets are clean and they are seated securely
what sort of ide connections are they do you mean molex power connections?
make sure the leads from motherboard to hard drive sata and electrical are securely seated also check all of the connections to drives cd/dvd floppy and usb
hope this helps
Jun 29, 2011 | HP Computers & Internet
I have HP Comaq Presario SR1617CL Desktop PC, part number ED870AA with a Samsung SpinPoint P80 SP1604N - hard drive - 160 GB - ATA-133, I would like to upgrade to a 500GB hard drive. I have a ASUS A8AE-LE...
XP cannot be installed natively on an SATA disk without the appropriate driver which must be loaded during the install - an extremely complicated maneuver. The best way to deal with that is to just add the new SATA hard disk: install XP on the PATA and use the new SATA for your files as a separate partition. The adapter cable can be bought for about $5 from the same shop as the hdd.
All the other modifications are just fine - just remember , the RAM will not be fully recognized and used because of the limitations of the 32bit XP.
Mar 11, 2011 | HP Compaq Presario SR1617CL PC Desktop
Can I transfer data from 250GB IDE HDD to a SATA II 500GB HDD
Yes you can. You may have to go in BIOS or and select your SATA as the first drive to boot off of though, else it might try to boot off the old IDE. But once you're in windows, it will appear as another drive in my computer.
Thanks and please take a moment to rate as fixya.
Dec 16, 2008 | ASUS A8N-VM Motherboard
I have A8N-VM Motherboard and 250GB IDE HDD. Can i connect 500GB SATA II HDD and transfer data from my IDE HDD to SATA II HDD
Assuming you have a Asus A8N-VM CSM GeForce 6150 Motherboard then if you have a SATA cable that works for that or an adapter for the SATA II if it wont fit it should be fine and you can have both in at once. So there would be no need to transfer but if you want you could.
If im not getting this please let me know and I will try to help you more.
Dec 16, 2008 | Computers & Internet
Does My A8N-VM Motherboard support 500GB SATA or SATA II ?
Yes, your motherboard features 2x SATA II ports so you can add any sata II hardrive
My system doesn't see 500GB HDD (SATA) (Seagate Barracuda)
Can you see this HD in:
Control Panel/System/Device Manager?
In Computer management?(Rt.Click My Computer/Manage/Disk management)? You can also format the disk here.
Oct 14, 2007 | Soltek SL-75FRN2-RL Motherboard
Gateway GT5220 PC Desktop Logo
148 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
