Question about Nixon Ticket Men's Watch - Silver Dial / Stainless Steel Band
Cant remove links from nixon ticket watch
Are the pins screwed in or pressed in?
SOURCE: Nixon Watch band
Perheps this will help though it's not the same company http://www.allamericanwatches.com/site/626101/page/182605 Or get in touch with your local dealr you have a 2 year warraty on that watch http://www.nixonnow.com/za/NNS?PAGE=FAQ&MENU_ID=14
Posted on Jul 03, 2007
SOURCE: Changing links for a Casio watch bracelet
solutions already mentioned(casio wristband) worked for me. However the first link took me forever to remove as I found it hard to envisage what I what attempting. Attached is a pic of a disassembled link which hopefully might help someone....BPB547b9a0.jpg
Posted on Dec 30, 2007
SOURCE: nixon watch warranty info?
I have the exact same watch and problem. The local Nixon dealer told me to take it to them and they'd send it away to be fixed. Good luck!
Posted on Feb 28, 2008
escapement
  • 2334 Answers
SOURCE: tighten wristband of the Nixon Watch , remove links
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: need to switch bands and cant remove pins
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Mar 28, 2009
Hello I have two nixon men's wrist watches that
just bring your watch to Nixon watch experts. they have spare and tools to repair your watch.
Jul 14, 2011 | Watches
I need extra links for the Nixon 42-20 crystal bezel chrono. The watch is too small.
I have looked at the Nixon site and it says that spare links are provided in the bottom of the box, see below.
Do you still have the presentation box?
"The compartment at the bottom rear of the watch stand can be opened and closed, and it contains the user manual and extra links and pins."
Apr 07, 2011 | Nixon Watches
Change tide location
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NIXON watch manuals.Rate me, please..
Mar 29, 2010 | Nixon Lodown Tide watch
How do you set the time to the Nixon 51-30 watch. Also what can you do to stop the knob from coming all the way off when unscrewed?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all Nixon watch manuals. To stop the crown to come off it must be screwed and secured onto stem. If you are not sure how to do that, visit your nearest watch repair shop and they will do it for you. Rate me, please.
Feb 26, 2010 | Nixon 51 30 Tide Watch
Need to switch bands and cant remove pins
Job done!
Mar 28, 2009 | Nixon Key Men's Watch - Gunmetal Dial -...
How to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
Feb 10, 2009 | Nixon Scout NIX0013 Wrist Watch
Tighten wristband of the Nixon Watch , remove links
Job done!
Jan 05, 2009 | Nixon Manual NIX0031 Wrist Watch
Nixon watch warranty info?
Feb 26, 2008 | Watches
Nixon Watch band
I tried the hammer plyer thing way back but took a bunch of time and stress, then I took it into a skate shop where they sold nixon watches and they had an actual tool supplied by nixon and all the **** needed to do the job.
Jul 01, 2007 | Nixon El Dorado NIX0010 Wrist Watch
Nixon Ticket Men's Watch - Silver Dial / Stainless Steel Band Logo
224 people viewed this question
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
