Question about Sony KP-57WS500 57" Rear Projection Television
Out of alignment (red)shadow
Turned tv on, press flash focus button. green and blue flashing squares ok , showing on all sides, but red flashing square top and bottom sides ok, but not showing on right side of screen and only showing on left side of screen about 3 to 4 inches from the edge of the screen. .
thanks
  • Sony Master
  • 8,457 Answers
Ur tv convergence are dead.U must know how to solder.U must have soldering tools,and solder to fix convergence problems.Must repalced 2 STK convergence ICS and some or all it resistors.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Posted on May 15, 2010
I have a 2001 sony kp61hs30 that has always worked great. turned it on today, the blue and red do not match up. the flash focus button on the TV will not align the blue and red plus signs. Got any...
I have a 2002 sony KP61HS30 and the blue and red do not match up. I use the flash focus button and it does not align the red and blue plus sign. Have any suggestions?
Dec 11, 2010 | Sony KP-61HS30 TV
Mitsubishi RPTV has a blue shadow/image alignment problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 23, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Red and blue color on TV is aligned but blurred, green is ok
U have a CRT Tube coolant problems.Tries Websites MCMElectronics.com,Tv reapair World.com to buy CRT tube coolant to recharge ur CRT.
Feb 26, 2010 | Sony KP-46WT500 46" Rear Projection...
I stumbled across a tutorial on fixing the convergence for my Sony KP-46WT510 a while ago, and now I can't find it again! Does anyone know where I can find that tutorial or one similar to it? We've been...
Here is a walk through on how to set your convergence.
A quick and easy way to try and let the TV realign the convergence try this...
1) Turn on the TV and tune to a channel and let it warm up for about a half an hour to let everything settle into its normal operating mode.
2) Press the Flash Focus button on the original TV remote. A cross pattern will show on the screen and the process is complete when the cross turns white and the TV returns to the program you were watching.
3) Do not press any other buttons until this process has completed.
If this does not adjust it enough you can adjust the convergence manually as follows:
1) Press the menu button on the original TV remote.
2) Use the arrow keys on the remote to highlight setup and press + button to select.
3) Use arrow keys to select convergence and press + button to select.
4) A pattern of white crosses appears, with a yellow [ ] around one of the
crosses. Aligned crosses (which do not need adjustment) look white and
have little or no red or blue showing. Crosses that are not aligned show
red or blue shades beyond their edges.
5) Use the arrow keys to move the [ ] to a cross that is not aligned. ***Note: start with crosses in the middle and work outward ****
*** TIP: Set the alignment while about 5 feet from TV for better results ****
6) Press the + button to select the cross and the [ ] will turn red indicating it is ready to adjust the Red convergence.
7) Use the arrow keys to move the red cross on top of the white one or at least as close as you can get it.
8) Once the Red is aligned press the + key again and the [ ] will turn blue. This indicates it is now ready to adjust the blue convergence.
9) Use the arrow keys to move the blue cross on top of the white one or at least as close as you can get it.
10) Once you have aligned the blue cross press the + button again and the [ ] should turn yellow.
11) Repeat steps 5 through 10 until all the crosses are aligned. To exit back to regular programming press the menu button on the remote.
Jan 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Aug 29, 2009 | Akai PT4298HD Rear Projection Television
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Color alignment kpwt500 tv
i would have a shop reconverge it.thats going to be the easiest way to get the picture back the way it should be.
Jan 13, 2009 | Sony KP-46WT500 46" Rear Projection...
Green shadowing
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 06, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Screen Is Blurred
Did you try hitting the small button on the front of the tv labled flash focus? Try pushing this button because this model only features auto focus for aligning the red/green/blue projectors.
Nov 24, 2008 | Sony KP-53HS10 TV
Green alignment
One of your convergence output IC's has burned out and needs to be replaced.
Jun 22, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
185 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
