Question about Brother Sewing Machines
Brother pr600 main motor lock message.what can i
Brother pr600 main motor lock message.then inappropriate needle position. what can i do.
SOURCE: Brother pro 600 embrodiery machine
You may have a bent bar inside the machine (big trouble), needle error is easy it is just to wind the big nob at the back of the machine, make sure you are on the correct needle when you move it, on mine it is a little stiff, just do it slowly. The engineer just bent my bar back into shape, that was 1yrs ago. Good luck have fun :-)
Karen (wytchstitch)
Posted on Jan 04, 2009
SOURCE: Inapproipiate needle stop position THEN Main Motor Lock comes on
The BELT was OFF. I guess it did that during shipment to me. So my husband just put it back on. THAT SIMPLE. It just kept making a motor trying to run sound and my husband took the left top cover off and seen it was only the belt. I was SO excited. It saved me a service call.
Posted on Feb 08, 2009
SOURCE: Brother PR-600...does anyone know if it's a major
I took the case off, and was able to raise the lever, and am NOT getting the error msg anymore. However, now machine is out of time (I think) I want to fix it myself...can I?
Posted on Mar 01, 2010
SOURCE: Brother PR600 embroidery machine has
Hello .
my PR600's touchscreen has stopped working properly.It is now hard to get it to work .
Posted on Aug 10, 2010
SOURCE: Brother PR600 embroidery machine, the needle
hook out of date
Posted on Jan 21, 2011
How to get brother pr600 out of main motor test mode?
Looks like the machine is bound up, or the motor is failing. If the hand wheel is easy to turn then it is probably the motor drawing too much current.
Brother recommends a new motor and belt every 1500 hours of run time.
Feb 25, 2015 | Brother Sewing Machines
Main motor lock, inappropriate needle position, after broken needle
The broken needle may be lodged in the bobbin housing. If you cannot locate, take it in for professional servicing. You may have put the timing out of whack.
Mar 09, 2014 | Brother Sewing Machines
Thread race in down position
What is your question ?
Make & Model ??
Main motor rotate error
You will get that error message when the machine is seizing somewhere, continue to use it and the repair will be very expensive.
It needs to be brought in for service.
Mar 06, 2014 | Baby Lock Sewing Machines
I have a pr600 brother embroidery machine,it trims the thread too short
Make sure that when your machine stops and cuts that your needle is in the upper most position. Other than that you may need an adjustment from a pro repairman.
Dec 04, 2012 | Sewing Machines
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
Brother PR-600...does anyone know if it's a major problem if it says "main motor lock"? The needle broke while sewing, and it is stuck in the down position and will only say "main motor lock" on the...
Nov 04, 2009 | Brother Sewing Machines
Brother PR600 embroidery machine has decided it won't thread any longer, had a wiper error which I cleared but the machine now won't thread the needles?
Just got the pr600 machine. Can't get the upper and lower thread to connect. Keep getting the error message to check upper and lower thread.
Jun 11, 2008 | Husqvarna Designer I
Sewing Machines Logo
1,191 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
