Question about Dell Dimension 3100 PC Desktop
My Dell Dimension 5000 series suddenly stop coming on when it was put off at the on button. I realised that the power surge light had been off for awhile on th socket switch. I think the problem now is that it needs a new powerpack as current is not getting to it any longer and it's not the power lead as I tested that. How do I get a reasonable and correct one for my old PC? I aslo do not want to lose my data on this Dell PC that I bought around 2002. Ed from London UK
  • barjthomps00 May 15, 2010
    Yes but I've already done this but need to get the correct replacement because of the old Dimension 5000 Pc model power supply is not around again
    President:
  • 4,070 Answers
Hi! You dont have to worry bout files getting lost. Its just a power supply problem and you will just need to replace it. Open the Casing and you'll find the power supply on the upper rear. Loosen the screws and pull out the connectors that connects the power supply and anything that attaches to it. Pull out the power supply, you can use this as a sample on buying a new one. Hope this helps and have a good one!
Posted on May 15, 2010
    It's not just about removing the power supply unit which I've done but getting the replacement. It's ridiculously priced at £50+ postage that I had to think twice about getting it as it is not even the exact one for the old Dimension 5000 series. Is it because it's out of fashion that the parts have become really expensive. Any idea where I can get one on the web or otherwise that is reasonably priced? Thanks Ed
  • dj_relly999
    dj_relly999 May 15, 2010
    Well I suggest that you get the parts from any surplus store which surely has and much cheaper.
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
Dell dimension 3000 won't turn on
No way to teat but to install another PS.
Jul 31, 2012 | Dell Dimension 3000 PC Desktop
Can't turn my computer on and i have a yellow blinking light on my dell dimension E510
Do you use a surge protector? If you do, try turning off the power supply to the surge protector and switch on again.
There are a number of causes for this problem, the most likely being a PSU problem or a motherboard fault/failure. To check the power from the PSU to the motherboard, you will need a multimeter to make sure enough power is going to the motherboard. Also check the motherboard closely to see if there is any signs of corrosion or blackened areas, which could be caused by overheating components. Check for leaky or burnt capacitors.
Apr 13, 2012 | Dell Dimension E510 PC Desktop
My dell dimension 4600 doesn't come on. When i press to on button I get an orange light on the power light ( left hand one ) then nothing happens. can you help
Possibly a faulty power supply?
Faulty Power cable?
Faulty Video Card?
Try replacing each of these in turn , remove all components and try to boot with the basics - 1 stick of memory, no drives, just video
Then add 1 drive
Then add another stick of memory
Keep going till you work out whats stopping it from starting.
Regards
1234s282
Apr 18, 2010 | Dell Dimension 4600 PC Desktop
MAXIMIM Ram You Can Put In A Dell Dimension 5000?
Your PC can support upto 4GB of RAM incase you are using vista or Windows 7 and if you are using win XP (32 bit) then only 3 GB is supported 1GB shall standby and also make sure that they are not more than 533 HHz
Kindly rate this solution
Thanks And Regards
Feb 24, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 3100
You most likely just need a new power supply. You can pick these up for around $40 for a 450W, which is plenty for your machine. Pretty simple to replace, unscrew the 4 screws in back, around the fan on top, then unplug all the power wires, pull the old one out, and then put the new one in. There is a slim chance that other components were damaged, but this is your first step to fixing it. The power supply is the martyr of the computer. It will throw itself in front of power surges to save the rest of your computer....
Feb 11, 2010 | Dell Dimension 3100 PC Desktop
Dell 5000 Dimension starting issue
You need to change your power save options. Right click on the desktop, click properties, click tab screensaver click on power tab. set the desired power save functions. hope this helps
Feb 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Dell Dimension 3100 PC Desktop Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
