Question about Brother HL-2040 Laser Printer
The toner light is on even after the cartridge was replaced. How do we fix?
    President:
  • 1,768 Answers
1.Your toner cartridge is not positioned properly / remove and reseat the toner cartridge.
Posted on May 15, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Printing blank page even in test mode. hplaserjet 1200
Checking the toner cartridge
Image formation defects are many times the result of problems in the toner cartridge. If there is any doubt, always replace the toner cartridge before troubleshooting image defects.
Use the following checklist to make sure that the toner cartridge is still operable.
" Make sure that the toner cartridge is seated properly.
" Inspect the toner cartridge for toner level.
" Check the expiration date stamped on the toner cartridge box.
" Check the toner cartridge to see if it has been disassembled or refilled.
" Inspect the toner cartridge to see if toner is leaking through worn seals.
" Check the surface of the photosensitive drum in the cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting
and image defects.
" Blurred areas on printed pages indicate that the photosensitive drum in the cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
Note A toner cartridge weighs approximately 863 grams (30.5 oz) when it is full, approximately 766 grams (27.0 oz) when it first fades, and approximately 742 grams (26.2 oz) when it is empty.
To redistribute toner in the cartridge
Before installing a new cartridge or when toner begins to run low, redistribute the toner by rotating the cartridge back and forth five or six times.
Jul 27, 2011 | HP LaserJet 1200 Printer
Refill toner
hi
check this video it is very easy
i have try 3 times in the same cartridge
and works just like the original
Dec 03, 2010 | Canon LASER SHOT LBP-2900 Printer
How to fill catridge show with images
How to Replace the Toner Cartridge:
Replace the toner cartridge with a new one using the following procedure. When replacing the toner cartridge, clean the fixing unit using the Printer Status Window. For details on cleaning the fixing unit, see "How to clean the fixing unit" in Related Information at the end of this page.
Important: Do not touch the high-voltage contacts (A) inside the top cover, as this may result in damage to the printer.
1. Open the top cover. Holding the top cover by the cutout edge, open the cover until it stops.
2. Raise the toner cartridge in the direction of the arrow (1), then remove it (2).
3. Take a new toner cartridge out of the protective bag. As there is a notch cut near the arrow, you can tear open the bag by hand. However, if you are unable to tear open the bag by hand, use scissors to open the protective bag so as not to damage the toner cartridge.
Important: a. Keep the protective bag for the toner cartridge. It will be required after taking out the toner cartridge for printer maintenance. b. Print quality may deteriorate if you touch or damage the drum inside the drum cartridge. Be sure not to touch or open the drum protective shutter (A). Be careful not to hold or touch sensitive areas that are not specified in this procedure. This may result in damage to the cartridge.
c. Do not expose the toner cartridge to direct sunlight or strong light.
4. Hold the toner cartridge as shown in the figure, shake it gently 5 or 6 times to evenly distribute the toner inside the cartridge.
Important: a. If the toner is not distributed evenly, this may result in deterioration in print quality. Be sure to perform this step properly. b. Be sure to shake the toner cartridge gently. If you do not shake the cartridge gently, toner may spill out. c. Be careful not to hold or touch sensitive areas such as the electrical contacts (A) or sensor, as this may result in damage to the toner cartridge or printer.
5. Place the toner cartridge on a flat surface, then pull out the sealing tape (approx. 50 cm long) gently while supporting the toner cartridge. Pull out the sealing tape straight in the direction of the arrow.
Important: a. Do not pull the sealing tape diagonally, upwards, or downwards. If the tape is severed, it may become difficult to pull out completely.
b. Pull out the sealing tape completely from the toner cartridge. If any tape remains in the toner cartridge, this may result in poor print quality. c. When pulling out the sealing tape, be careful not to hold the drum protective shutter (A) with your hands.
d. After removing the protective bag, install the toner cartridge in the printer as soon as possible. e. Dispose of the sealing tape according to local regulations.
6. Align the projections on both sides of the toner cartridge with the toner cartridge guide inside the printer, push the toner cartridge completely into the printer (1), and then pull it down toward you (2).
7. Close the top cover.
Nov 30, 2010 | Canon LASER SHOT LBP-2900 Printer
AFTER RELOADING TONER INTO CARTRIDGES, THEN RED LIGHT BLINKING AND IT WILL NOT PRINT. WHAT CAN I DO TO FIX THE PROBLEM?
Did you change the chips in the cartridges after you filled them with toner? Inside the cartridges are chips that the printer keep track of the number of images that are printed. After so many pages, the printer marks the cartridge as empty, even if you fill it with toner. When the cartridge is changed the printer reads the serial number on the cartridge and keeps a log it its memory. If the chip is replaced, then the printer does not recognize it and thinks it is a new cartridge.
Hope this helps.
Apr 30, 2010 | Samsung CLP 300 Laser Printer
When should I replace the toner cartridge? I found that red light is flashing( the lower light, totally there are 2 lights: upper one is green now). I don't understand what does it mean.
It mean when your toner is near empty,then red light flashing.tow light is fixed or red mean toner cartridge is empty.must be replace toner cartridge.You buy a new cartridge and put in your printer then printer is OK.
you can also get better idea please read printer user guide.
Mar 04, 2010 | Samsung ML-2240 Laser Printer
Samsung clp-315 colour fading
This may be a case of running out of toner, even if the software indicates that toner is still there. If you have a gram scale, try weighing the cartridges. For some reason I have not got consistent weights of empty cartridges, even with all residual toner shaken out, but my empty cartridge weights for color cartridges have been 457 grams, 462 grams and 475 grams. If the toner has been used up, the answer is to refill or replace the toner cartridges. Refilling requires (a) replacement chip(s). See other postings about toner refills for this model here on FixYa.
Apr 10, 2009 | Samsung CLP 315 Laser Printer
Toner error
hmmm..not good. when you took out the paper jam, did it come out easy?
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Samsung ML 2010 Laser Printer
Error Light
The error is "toner cartridge error" you could try cleaning the contacts inside the printer (with the power off, of course). If that doesn't work you will need to try another cartridge.
Jun 14, 2008 | IBM Infoprint 1116 Laser Printer
Printed document has light spot running down entire page
Hi, On another Samsung model (ML1610), I tried shaking the toner cartridge left & right (presumably to evenly distribute the powder inside). On another instance, it was caused by a replacement cartridge (not original) and then again was when I tried simply refilling the old original cartridge. In all cases, the drum (which was inside the cartridge assembly)had to be cleaned, or the cartridge replaced (with original). The most tedious was when I had to open the cartridge and remove the replacement toner that has formed into solid lumps. Hope this be of some help. Pls post again how things turn up. Good luck and kind regards.
Jul 30, 2007 | Samsung CLP 300 Laser Printer
Brother HL-2040 Laser Printer Logo
172 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
