Question about Bose Acoustimass 15 System
Woofer not powering on
I am having problems with my woofer not powering on. I have taken it all apart and the fuse underneath the circuit board is good. I was wondering about the resistor. Could it be the resistor? What else can I try. All the sudden one day it will turn on out of nowhere. Every time I unplug the woofer or shut it off it will not power back on. Than out of nowhere in the next couple days it will power on. Subwoofer (Acoustimas 15) will not power on. Having trouble removing the case to look inside. I remove the dials (for Bass and LFE levels) and try to slide the plastic case off but it won't budge. I try to gently pry it off with a screwdriver but am afraid of breaking it. So, is there something I am not doing right to remove the cover? I need to get at the fuse to see if it is open
  • 13,433 Answers
The powersupply is most likely the cause and would need to be replaced. Fuse is most likely ok, some parts of the powersuply would need to be replaced, id recommend replaceing the whole psu (powersupplyunit)
Posted on Mar 30, 2008
  • Bose Master
  • 19,396 Answers
Check the power unit inside woofer, it was cause for same problem in my creative surround.
  • Ginko
    Ginko Mar 30, 2008
    In any case is not the resistor , if the resistor is gone you have no power at all all the time. to ensure that is not the resistor test it using a Digital Multimeter. If it has ohm infinite then resistor is broken. In my surround system I changed the whole supply unit, which is a block board/transformer inside the woofer, where you plug the power. I payed around £40 for the replacement. Before replacing it I tested all resistors, some IC and contact and did not find anything wrong.
    I think this kind of problem is due to a faulty contact on device power unit. they can work for a while, then they can break down for a while, because of movements or heath and use factors.
    Regards
Why does it randomly lose power?
Hello, I can not say what the direct cause is,
perhaps some soldering points on the printed circuit bords are loosen due to thermic stress. test: give mechanical ticks on the woofer while he is playing to check this.
Hope you will have succes.
Jun 11, 2015 | Mackie SWA1501 Subwoofer
Woofer has popping noise
I have the same problem with my Cambridge Soundworks CSW250. Also one of the speakers doesn't work all the time. I'm sure it's a loose connection on the circuit board. When I tap the subwoofer near the connections, the popping noise changes (gets worse, better, other speaker works,etc.).I tried taking the subwoofer apart, but the area near the connections is sealed with glue, so I cannot access it. I hate it because when it works,it sounds so good. Anyone know how to get just the circuit board and back panel?
Aug 09, 2012 | Cambridge Soundworks Audio Players &...
I also have an Athena ASP4100 sub woofer which blew the fuse on the circuit board and when I replaced the fuse, it just blew it again. As an electrician, my understanding would be the circuit board has a...
You should look at the circuit board for the power amplifier and check for any leaking or bulged electrolytic capacitors. If this speaker uses the circuit boards made by AMI (such as most JBL and Mission sub woofers around 1999-2001 vintage) they had a lot of problems with this as well as bad modules. Google for the module S53AMI and you will find lots of info if this is what you have in that Athena.
Feb 21, 2011 | Athena AS-P4000 Subwoofer
Polk Audio PSW10 electrical board smoking
I should just replace the parts that were burning, it will cost a lot less.
Jan 15, 2010 | Polk Audio PSW10 Subwoofer
No Sound
This might very well be a fuse - check by setting the sub woofer to "On" to see if it powers up. If it does, there may be a problem with the sub woofer audio cable(s) or connection(s).
Don't forget to check for a tripped circuit breaker or blown fuse on the stereo's speaker output. If your sub is connected to a low level output - this shouldn't be a possible cause - as circuit breakers & fuses are usually on amplified (high level) or speaker outputs.
Another possibility is that the settings of the stereo has been changed from a *.1 system to plain stereo 2.0 or some other setting that disables the LFE (low frequency effects) or sub woofer audio output.
Sep 18, 2009 | JBL Venue SUB10 Subwoofer
Woofer will not turn on. fuse was bad but i replaced it and still no power.
Had the same problem, no power from the sub, no light. Opened the box, fuse was bad, replaced the fuse...pop...blew again. Found out that on the bigger middle board next to the power plug there are two capacitors on either side, the inner one burned and crumbled to pieces. I called Kenwood, they said that I would have to bring it to a Electronic Service Specialist that they will give you a number to in your area...or...Ship it yourself to their East Coast Center in Virginia. I already asked if Kenwood is going to send an RMA or Shipping Label and they will not. You will be responsible for the shipping there, but they will pay for the shipping back. Kenwood's East Coast Center in Virginia's number: 757-340-1702 - Good luck
Dec 14, 2008 | Kenwood SW-38HT Subwoofer
Fried Woofer
The problem are worsen that before. It is wisely to replace both left and right amplifier
IC, but make ensure that the power supply feed a good amount of voltage to amplifier,
Also a strong good signal. Be sure to measure it.
r_ic7
Jun 22, 2008 | Alesis M1-Active MkII Main / Stereo...
hows power strip your pluged into ? try differt outlets is it
srewed down tight to wood cabnit wires tight on speaker good grounded power how sthe wire going to it
Jan 06, 2008 | Bose Acoustimass 15 System
Power Light off & speaker not working
I had the same problem. The screws around the perimeter of the back plate must be unscrewed and the plate must be pried off as it is glued to the box. When replacing my fuse, 2A 5x20 GMA, it blew the fuse again. Disconnecting the second circuit board prevented the next fuse from blowing, but now the question is what is wrong with the circuit board? I cannot see any damage or shorts.
Oct 10, 2007 | Kenwood SW-38HT Subwoofer
Bose Acoustimass 15 System Logo
298 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
