Question about Kenwood KVT-512 Car DVD Player
Ipod says disconnected when plugged into my kenwood kvt 512 but it does play music through the auxillary jack. I was just wondering why it wont let me control my ipod through my screen on the deck via usb, and why it says its disconnected when its actually connected and charging from the deck
  • 20 Answers
Same problem deck says disconnected my system software already 3.2.0 yried two ipods
Posted on Aug 04, 2014
  • 311 Answers
I sometimes have the same problem it says do no disconnect when it should show the kenwood logo
try restoring your ipod from itunes
Posted on May 15, 2010
I got a kenwood kvt-512 and my ipod seems like it doesnt work ?
go to :- http://kenwood.com/cs/ce/mm/firmware/2008/eng.html
then change the file to an iso and burn to a disc.
put the disc into stereo and press dvd and let the disc do the rest.
hope this helps works on all kvt systems
Dec 31, 2010 | Kenwood KVT-512 Car DVD Player
My subwoofer won't play while watching a movie or playing iPod only while on the radio. Why?
it sounds like the "remote wire" on the amp is coming from the "power antenna" output of the radio instead of the "remote turn-on" wire or in the case of kenwood, the "power cont." wire. Sounds like that's whats happening.... switch the wires on the kvt-512, should be a blue wire and a blue/white wire. hope that helps, dave
Nov 11, 2010 | Kenwood KVT-512 Car DVD Player
I had to change my battery on my truck and when i did my kenwood kvt-512 flip screen says protect and will not play any music... help please...
It might have taken a small short. You can push the reset button just to the left of the volume buttons. Good Luck.
May 29, 2010 | Kenwood KVT-512 Car DVD Player
KVT-512 Car DVD Player: Battery was disconnected ans car stereo locked out...
Sorry...KENWOOD codes are only available from the Main Dealer or a Radio Decoding Service
May 17, 2010 | Kenwood KVT-512 Car DVD Player
I plug my ipod to the stereo but my stereo screen still says discconected
you have to go to the kenwood site and download the firmware update go to this page http://www.kenwood.com/cs/ce/mm/firmware/2008/eng.html
after you download the file unzip it and burn it with either nero or roxio, as a data file insert the cd on your kvt-512, if it reads DISK ERROR, press the reset button on the front of the stereo, once the screen comes back up select the DVD function, the system update should start from there. let it finish once it does then you'll be able to plug in your ipod. oh and ofcourse for this you should know that you need the ipod adapter, depending on what you want to do with it for instance i have the KCA-iP300V which allows me to view videos from my ipod as well.
Jan 27, 2010 | Kenwood KVT-512 Car DVD Player
My 5th generation ipod is reading on my kenwood kvt-512 but no music is playingits been updated to firmware version 2.5
This happened to me. What worked was turning off the ipod (not stand by mode). Turn it back on and plug it in, it should work.
Jan 26, 2010 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
Just purchased a brand new Kenwood KVT512 and the ip300v interface cable. i can play music from my i pod but i dont have any interface, it basically just acts as an audio input rather then linking to the...
Did you buy the adapter for the ipod and are not just hooking it up directly through usb. It sounds like their may not be the correct adapter attached. The adapter comes with plug for the ipod on one end, and a usb, audio, and video plug on the other end. Without that you will not see anything on the screen due to not having the correct cable to display the video portion.
Feb 24, 2009 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 Car DVD Player Logo
603 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
