Question about Dishwashers
How long should a dish washer run on the Pots and Pans cycle?
    Sergeant:
    Champion:
  • 232 Answers
If you still have the manual that came with it ,the answer is in there. If you dont,You can probly down load the manual at the company site.
Posted on May 15, 2010
Dishes not cleaning after full cycle running
Your screens are plugged with food residue in the bottom of the unit. clean it out. You can use 1 gallon of white vinegar for your wash after you clean the screens. Start your washer to fill with water but after the water starts, open your door and pore all of the gallon in the unit. Let it now run for 4 minutes and stop it by opening the door. Leave the door slightly open for 1 hour. close the door and let the cycle continue for 4 more minutes. open the door and repeat it a couple of more times. Let it sit all night with the vinegar in it and in the morning - close the door and let the cycle continue to the end. This should help soften and clean out the food particles in the unit. You can repeat the process and get a better cleaning then too. All the scale should be off your dishes now.
Jan 08, 2014 | Frigidaire Professional Series 24 in....
Tip
Tips For Dishwasher for its safety and getting dishes cleanest
A) If your household is small, try gradullay accumulating a full load of dishes and rinsing as you go, instead of stacking dirty dishes in the dishwasher.
B) Cleaners and some elbow grease will always get pots and pans cleaner then the pots and pans cycle on the dishwasher.
C) Good crystal and china should be hand washed and not placed in the dishwasher since the detergents and jostling can damage them quite easily.
D)It can take several hours for dishes to dry when using the no-heat dry option the dishwasher. Try propping the door open to speed the drying process.
on Dec 14, 2009 | Dishwashers
Purchased in 2003. Dishes were exquisitly clean till 2008. Our water heater temp was set at 140 temp. This heater was replaced with a heater now set at 125 temp. In the past two years dishes are nowhere as...
try turning on your water at the sink for a while on hot let it run then start the wash cycle that should help. what that will do is let the cold water run out of the pipes and therefore you will have a hot water start.
Dec 17, 2010 | Kenmore Dishwashers
Manual for hotpoint how to work it
  • Load the appliance with dirty dishes, placing soiled pots and pans on the lower rack where they will be subjected to the most vigorous cleaning. Glassware and dishwasher-safe plastics should go on the top rack. It is not necessary to rinse dishes before loading them in the Hotpoint appliance, unless the dishes have been sitting for awhile and the food particles have dried.
  • Fill the detergent compartment with your preferred brand of dishwashing detergent, and add glass rinse solution to the rinse reservoir on the inside of the door if your model is equipped with one, then close the door to lock in place.
  • Select the cycle you wish to use and press the button. For pots and pans, use the heavy-duty cycle. Normal wash is fine for dishes and utensils.
  • Save on your energy bill by running the dishwasher only when it is full and by allowing the dishes to air dry instead of using the heat dry function on the appliance.
  • Oct 10, 2010 | Dishwashers
    What causes my pots and pans to turn black on the botom when cooking on a gas stove? Many thanks
    depends on the pots. Some is because of they type of metal. The metal turns black because actual fire will turn it when it touches the medal. Others could be grease. Some dish soaps dont get all grease off the pot. Specially if you use dish washer. Try soaking them and see if they will come clean. Dawn dish soap works great or there are products you can buy just for that purpose. good luck
    Jan 07, 2010 | Ovens
    Won't wash dishes
    Interrupt the power to the unit by flipping the appropriate breaker off in the house electrical panel for several minutes, then back on. If this doesn't help, then likely the control module is in trouble and needs to be replaced.
    Sep 26, 2009 | Dishwashers
    Kenmore dish washer lights up but will not start wash cycle.
    turn off your dishwasher then try it again ok
    Feb 27, 2009 | Kenmore Dishwashers
    The washing cycle takes 2 hours to complete
    Make sure the sani cycle is not selected, or pots and pans, also with the dry cycle most will take about 2 hours, if your dishes are not that dirty use the short cycle. Be sure your water is at least 130 F. Run hot water at faucet before starting the machine.
    Feb 27, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
    WHIRLPOOL QUIET PARTNER IV
    Ok this can mean 2 things.
    Pump or filter is clogged
    or heater is not working correctly. Can you give the precise model number?
    Aug 09, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
    Dishwashers Logo
    35 people viewed this question
    Top Dishwashers Experts
