Question about LG 32LG30 32 in. LCD HDTV
Cant plug Pc into TV
I have an LG tv, and an HDM1 cable. I used to be able to plug my Dell laptop into the TV just fine, but now it has stopped working. I can plug my Laptop into a different TV, so the problem has to be with the TV not the computer. Please let me know anything I could do to solve this problem.
  • LG Master
  • 736 Answers
Try holding down the fn key on the laptop and the dual monitor key (F5 or F8) for about 15 whole seconds. The laptop screen should go dark and the image should come up on the television screen.
Posted on May 15, 2010
Can I use Amazon fire. It say I need a hdm1 and all I see is a USB connect above my power cable plug in. Can you help?
In your LG TV's user manual there should be a schematic with all the ports/connections on your TV.
Jan 09, 2015 | LG Televison & Video
HOW DO I GET NET FLIX TO RUN FROM MY DELL COMPUTER TO MY LG TV?
You would need to use an AV cable linkup, then on the PC, in your hardware or display options choose the alternate display and select the hardware the cable is connected to.
Sep 05, 2014 | Dell Computers & Internet
Cant connect my laptop to my LG32LC45 tv
Hi there
Below is a link which takes you to a page that shows how to cable the PC (laptop) and the TV together, with a brief explanation of resolutions etc.
http://www.lg.com/uk/support/product-help/CT00008333-CT00008334-2132861
If the above doesn't get you any further then the link below takes you to an LG support page from which you can download the full manual for your TV, which gives the supported connection methods and the supported resolutions.
http://www.lg.com/uk/support-product/lg-32LC45#
I would strongly suspect that if correctly cabled then either the laptop external resolution is set to a level that the TV can't cope with, or the external monitor function is turned off. If the external monitor function is turned off then pressing and holding the Fn button whilst pressing a function button once and releasing both should turn the external monitor on. On a Toshiba Tecra the top line functon button you need is F5, on an MSI U130 its F3, on a Dell Inspiron 1525 its F8, on a different Dell model its F1, so you need to check your laptop and its manual to find out which button is relevant to your machine.
Sorry to have been longwinded - Good luck
Aug 25, 2014 | Computers & Internet
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
We recently purchased a sony bravia 55 inch tv. we have a hdm1 cord and have hd channels through Telus optik. i am not certain we have it hooked up for the best picture? can you please instruct us on what...
If you are using the HDMI input, you are using the best hook up that is available.
Is there a particular problem with the picture that does not look good?
Skyassoc
Nov 24, 2010 | Sony Televison & Video
I have a dell studio 1537 and i am not able to get picture when i connect my laptop to tv using a HDMI. i have tried everything possible but i cant seem to get the picture
make sure your pc is powered completely off(not a restart but a shutdown). hdmi cable should be unplugged. plug cable to tv first, then turn on tv. Now power up pc and it should recognize the tv. Use projector mode if available on your pc. do not unplug hdmi cable while pc is on or you may have to repeat process.
Mar 17, 2010 | Dell Studio 1537 Laptop
Cant connect tv to laptop via htmi cable
You need to use the RGB input port on the TV
May 01, 2017 | LG 47LG50 47 in. LCD HDTV
Dell Latitude D600 PC Notebook
your s-vidio out on the laptop only transfers vidio, you need to use a headphone to rca jack cable pluged into your headphone port on laptop and plug rca into back of tv or vcr or s-vid converter box
May 31, 2009 | Dell Latitude D600 Notebook
Connecting laptop to lcd
You may need to use the S-video cable for video. Make sure video mirroring is disabled on the powerbook. Also, make the external monitor the primary display by dragging the menu bar to it in Displays preferences (Mac OS X) or the Monitors control panel (Mac OS 8 and 9).
Mar 14, 2009 | LG 32LG30 32 in. LCD HDTV
Pc to tv
Same problem for me too!
Dec 21, 2007 | LG 42LG30 42 in. LCD HDTV
LG 32LG30 32 in. LCD HDTV Logo
