Question about Panasonic DVD-RV32 DVD Player
FT02 is displaying
How can i resume original factory settings for my DVD player...it keeps displaying FT02 and wont play properly...its flashing and has no colour
When mine said FT-02 it wasn't flashing or anything, but I pressed the cancel button and after it said "initializing" for a sec it went back to normal. FT-02 is some kinda test mode for the manufacturer, I think.
Posted on Apr 20, 2008
Rca drc8295n reset parental codes I bought this unit at a yard sale for five bucks... It plays cd, vhs tapes, but when I put a dvd in it wont play and I see a pad lock on the little display. I am assuming...
Page 55 of the user manual shows a way you may be able to 'reset' the player back to factory defaults and/or if a parental lock has been set and the password is unknown/forgotten:
* Press the STOP button on the front of the unit while you press the STOP button on the remote control-keep pressing both buttons for approximately 3 seconds (until the 'padlock' icon disappears from the front panel display). Release both buttons (the player should be unlocked). If that doesn't work, try resetting the DVD/VCR (instructions are listed below).
* Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON button while you press and hold the STOP button-wait at least 3 seconds before you release both of the buttons.
You'll need to set up your menu preferences because this Reset Procedure returns the DVD/VCR's menus to the factory default settings and also erases the disc library.
( sourced from: http://www.retrevo.com/support/RCA-DRC8295N-DVD-Players-manual/id/402bh648/t/2/ )
You can always go to the above site and download the free pdf of the owner's manual for this model if necessary (follow the prompts).
Give the suggestions a try before considering downloading the documentation.
Apr 26, 2011 | RCA DRC8295N DVD Recorder/VCR
Cannot play newer blu ray discs and now cannot play cd's. "This disc can not be played" error message
power off your dvd, disconnect the plug from the power source and then reconnect it again. Power on the unit again and try to resume normal operation. If it cannot still play a dvd much less a cd, then you need to have it repaired. At the most, the flex needs to be replaced or your lens is damaged in which case it needs replacement. Try also locating for a reset button on your unit. Just press the reset button if there is one on your dvd player for about 5 seconds to restore it to its original factory setting
Dec 19, 2010 | Samsung BD-P1600 Blu-ray Disc Player
How can I get my mitsubishi car cd player to play all types of cds. It only plays original cds and not copied cds.
this can not be done to the factory deck you would have to replace it if wanting to keep factory just get an aux or i pod cable intergrated with your factory deck
Aug 22, 2010 | Digital Audio (DADVDP) DVD Player with AM/...
Ht-x30 samsung cinema system display unknown disc
TThe player does not play this type of dvd disk! only pre-recorded movies and CDs Try hooking Up a player that plays DVD+ and DVD- disks!Hope I was of help!
(please use The ratings to keep this site free!)
Dec 14, 2008 | Samsung HT-X40 System
Player will not read dvds
Get into the Service Menu by entering 1397139 on the remote control like you did before and restore the original factory-set values stored in flash-memory back the way they were. One you do this your unit will function properly again. mikeadams110@yahoo.com
Original factory-settings
Option1: F2
Option2: 15
Option3: 93
Option4: CF
Option5: 94
Option6: C0
Option7: 04
Option8: 15
Oct 30, 2008 | LG RC797T
I am in NZ and have philips 616K dvd player. Have some dvd's origin UK that wont play on my dvd. Comes up wrong region. My daughter also in NZ has played these dvds in NZ but not sure what brand dvd she...
Changing the region code for DVD616K :
1. Press OPEN/CLOSE, and wait for the tray to open.
2. Use the remote control to input digital key '1', '1', '1', 'l' in that
order.
Kindly leave a few seconds between each entry, the microprocessor is slow
with these entries.
3. Press number '7', '8' or '9' to display the current region code of the DVD
player.
OR
4. Press any number of '0' to '6' to set the required region code. The OSD
will display the new region code of the DVD player.
5. Region '0' will be the setting for multi region
6. The region setting will be saved in the FLASH memory.
7. Press OPEN/CLOSE again, the DVD player will return to normal operation.
Jun 28, 2008 | Televison & Video
FT02 is displaying on my DVD player
Try this. With no disc inside player, press and  hold 'PAUSE', 'FWR SKIP' and 'OPEN' on player until INTIALIZED is displayed.
Mar 30, 2008 | Panasonic DVD-RV32 DVD Player
Lx 9000r wont play any dvds even previously played
You can try reseting the unit.
Reset the set to the default factory settings:
All the information stored
(programmes, time and date) will be lost.
1.
Disconnect the set from power supply.
2. Press and hold down "STANDBY•ON" on the set and reconnect the set.
3. As soon as "IS TV ON?" is displayed, release "STANDBY•ON."
Hopefully reseting it will clear whatever problem it is having and allow you to once again use your DVD player.
Hope this helps. Good Luck.
Jan 22, 2008 | Philips LX9000R System
Disk won't load
I would verify that connections between the DVD player and the TV; then go into your DVD’s control panel and re-set to original factory settings. I would also make sure that your TV’s settings are set to the correct connection settings as well.
It would also be nice if you included the make, and model of the DVD player and which connections are you using to connect to the TV.
Nov 10, 2007 | Televison & Video
Can't get the remote to display the set up screen
If you have the original remote and the unit wont let you in the menu, then Try first ti reset the machine by unplugging it for 24 HOURS. If that does not reset the microprocessor then the eeprom IC or the microprocessor is bad.
Sep 30, 2006 | Samsung DVD-V1000 DVD Player/VCR
Panasonic DVD-RV32 DVD Player Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
