Question about Panasonic Lumix DMC-TZ15 Digital Camera
Memory card locked
When I turn on the camera it says the memory card is locked and I cannot do anything.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on May 17, 2010
Thanks K-akima! I'm just about to go on holiday and I couldn't work out WHAT the hell was the problem. Thanks again. Hope this info helps someone else.
Posted on May 27, 2010
Cannot do anything with camera go to take anything it says write protected
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 29, 2011 | GE X5 Digital Camera
My cammera is locked i dont know how and why i try to take picture it says THE CARD IS LOCKED i turn it on it says the same i pretty much cant do anything, how can i unlock it or fix it????
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
There is also a software protection feature on some cameras, but this is used to protect a folder or individual picture from accidental deletion, not the whole memory. You set or release this protection from the camera menus.
If it is not that, then maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. Have you tried formatting the card in the camera? This would be one way of making sure that the camera can cope with the card, and it will also erase anything on the card. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Jan 08, 2011 | Casio Exilim Zoom EX-Z80 Digital Camera
Casio ex-z1050 when I turn on camera it reads "the card is locked" and can't do anything!
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 26, 2009 | Casio EX-Z1050 Digital Camera
I have a canon powershot sx110is and when i turn it on it will not take any pictures but instead gives the message "memory card error." When I put it to the display mode it says the same message plus...
First see if the camera will work without the memory card installed. Then format the internal memory using the camera's setting as described in the manual.
Then turn OFF the camera and insert the sd card. Turn on and reformat the card too.
Make sure you have NEW batteries or sometimes things go flakey.
Dec 22, 2009 | Canon Powershot SX110 IS Digital Camera...
My samsung s1065 camera is saying "card locked "i have not put a code or anything in it so i dont know why its locked an i cannot take any photos or anything
Remove the SD memory card from the camera. Look for the lock switch on the memory card and slide it away from the "lock" position. Re-insert the SD card and all should be well.
SD stands for Secure Digital and was one of the first memory cards to have a physical security lock to protect your data.
Oct 05, 2009 | Fuji FinePix A500 Digital Camera
Locked memory card...
hi crazytami,
the memory card on your camera is SD. on the side of the card you should be able to see a whitwe toggle switch, try to put it to the left, then try it again on the camera, if not, then try the switch on the right then try it on the camera.
one of them should unlock the memory card. if not, please let me know.
regards,
voodoo
Jun 07, 2009 | Canon PowerShot A460 Digital Camera
Camera says card locked
1) Try to unlock it by the lock/unlock switch on the side of the memory card.
2) If step 1 does not work replace memory card with new card.
3) If step 1 & 2 do not work the problem is internal (inside the camera). Go to www.ecasiorepair.com to get a quote for repair. Cost will be anywhere from $39-115 to fix it (if not under warranty). You could even ask if this is a defective camera (lemon) they might even fix it for free? I've seen this issue with the Casio a lot.
Dec 17, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Memory Card Locked.... how do I un-lock it?
Your memory card has a small white "switch" on the side. Move the switch and your card will unlock. It is a saftey so you don't erase anything accidentaly.
Jun 27, 2008 | Canon PowerShot A560 Digital Camera
Memory card locked
try to slide up the notch on the memory card...its on the lefthand upper part of the memory card...
Jan 01, 2008 | Samsung Digimax S500 Digital Camera
Memory card locked!??
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
Jul 05, 2007 | Pentax Optio E10 Digital Camera
Panasonic Lumix DMC-TZ15 Digital Camera Logo
78 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
