Question about Water Heaters
My heater that heats the pool won't work. It is coming up with error e05. Help, I am having a party tomorrow.
  • 10,319 Answers
Every make has there own error code system
You did not state what brand you have
Here is a website you can click onto aqnd see if your make is listed
This way you can find out what dcode problem you haqve
http://www.ask.com/web?q=error%205%20pool%20heater&o=15554&l=dis&qsrc=2871
Posted on May 22, 2010
Jamdy RS Shuts off heater too soon
when using the aqualink make sure heater is in tstat mode if not for your heater then turn heater all the way up make sure the wires are connected to pool and com then make sure the wires 5and 6 are connected to the heater then the aqualink will command heat if the red light is lit on controller
Feb 10, 2014 | Jandy 7953 AquaLink RS One Touch Control...
Electric Pool Heater Tripping Out!
What is the model number of the unit?
Jul 13, 2013 | Water Heaters
Won't heat water
Glad it worked out so easily.
Be sure to perform the regular maintenance as shown in manual to prevent common error codes.
Sep 25, 2012 | Bosch ProTankless GWH C 800 ES LP Tankless...
Rheems Power Vent Model 42vp50fw Manufactured 3/08\r\n The gas comes on but will not stay lit. I have replaced the Combination Gas Control and igniter and heat sensor. Error code comes up as an igintion...
Intellivent gas valve shows AB and vacation error lights:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
The igniter and flame sensor have to be positioned correctly:
http://waterheatertimer.org/pdf/Hot-surface-igniter-troubleshoot.pdf
Check electrical outlet with circuit analyzer, and test that unit is receiving 110Volts
Intellivent gas control must be grounded.
Check that gas control is getting 24volts.
Check for air in gas line and low gas pressure.
Following links offer troubleshoot resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 10, 2011 | Rheem Water Heaters
Our tankless water heat will not heat the water-it won't ignite
Question posted under Boasch tankless. Model number not known.
Before calling service technician, open following link for Bosch troubleshooting resources, including phone and contact for Bosch, error codes, and possible manual, plus hours of reading and research:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
As you know from reading manual, tankless water heaters require yearly maintenance by trained service technician, or by homeowner. This action would check gas and pressure, venting draft, condensation drain, burner and combustion parts, igniter and-or pilot light, electrical connections, air intake and general condition of plumbing.
Problem you describe does not include error code.
Open following link for possible help with general plumbing problem:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Add a comment with model number that appears on side of unit, and I can directly locate possible service bulletins and further troubleshoot resources available at Bosch for possible do-it-yourself diagnosis and repair.
Sep 02, 2011 | Bosch & Tankless LP Hot Water Heater
I have an A. O. Smith Model FPSH 40-261 hot water heater. It won't heat water. there is a green light on the control flashing. What does it mean?
AO Smith uses the Honeywell ICON gas valve with green indicator light.
Some models use White Rodgers Intellivent with a row of indicator lights.
The gas control blinks the error code:
Open following links to identify gas control thermostat and read possible error codes:
http://waterheatertimer.org/pdf/Honeywell-Gas-Valve-LED-Codes-2000.pdf
http://waterheatertimer.org/BW.html#Temp
Jul 18, 2011 | Water Heaters
The hot water just turn cold by it self and wont come back. I have to go to the attic and unplug and then plug back, it will then work. It does this again next time in the shower, midle of the shower,...
Before calling service technician, open following link for troubleshooting resources, including possible manual, and Rheem chat.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Rheem usually asks you to call local service technician.
There are many factors that cause problem you describe: bad PC board, sensor problem, loose wires, crossover in single-handled faucet, lime build-up in heat exchanger, clogged water filter.
The remote control might give you an error code. Error code is a starting point for troubleshoot.
Error code on one unit can have different cause than same error code on different unit.
Read manual for required maintenance.
Tankless require yearly maintenance.
Upvote the help.
May 26, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
I have a reliance model 501 electric water heater thats 8 yrs old who's responsible if it blows out the thermostat and floods the bldg I'am on the third floor codo
The person who owns the water heater is usually the responsible party. If it is in warranty, I have heard lately that serveral of the insurance companies have sued the manufacter and won but this is rare at this time. If unit is working I would put some type of preventive measure to stop if from drowning the people below and ruing your condo too.
Water Cop'
Brust Buster
Watts water stop
this is just to name a few to protect yourself and other under you.
Oct 04, 2010 | RELIANCE ELECTRIC WATER HEATER
Raypak gas pool heater with error code HL2
Do you have power to the heater?If you do then I would look for a hi limit switch to reset.It might be the pump you have to reset.
Mar 16, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Water Heaters Logo
22 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
