Question about Microsoft Xbox 360 Console
Sound but no screen
Help me!!!!!!
there is sound when i urn on my xbox 360 but no screen at all!!
i have already unplugged everything and re-plugged it! im twelve years old and need help to fix it for my 13th birthday!!
tell me what to do!!
thanks,
tess
  • ventrex Mar 30, 2008
    my xbox 360 has sound but instead of a good picture3 i get little dots or little lines i have tried the hdtv/hdmi switch i have tried un plugging and plugging it in i have tried this on different tvs I NEED HELP MY LITTLE SISTERS BIRTHDAYS IS COMMING UP SHE LOVES THE XBOX 360!!!!!!!!!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Ok, try going through all the different video cables till one works, same as the ps3 you have to go into the setting and tell the 360 what type of video setting you want to use, once you find the one that is active then you can go into the setting and change it around - if you have already tried this then the video processor is fried and you need a tek to fix,
Posted on Mar 30, 2008
SOURCE:
Ok my consle is an xbox 360 arcade i have an eathnet cord and coneted it to my compter and it still wont work and i dont no how to set up my xbox live
how to connect the 360 to the Live network.
Before you do anything you are going to need to decide how you plan on connecting the bad boy. The 360 supports both wired and wireless connections. In order to use a wireless connection you will need the Xbox 360 Wireless adapter. Personally I find the wireless connection to be a bit too temperamental for my liking so I go with a wired connection via a router, but not everyone has the same wireless experience.
To set up the connection via a router unplug the router and the modem and turn off the 360. Connect an Ethernet cable to one of the out ports of the preexisting router then connect the cord to the back of your 360. Plug everything back in and turn and give the modem and router about 3 minutes to reboot.
Once you have given everything a few minutes to reboot you can turn the 360 back on. If you have already set up a gamer profile you will see the Xbox Live screen. If you have not set up an account you will be prompted to do so. All you need to do is follow the on screen instructions. It is a pretty cut and dry process and should not take more than 10 minutes of your time.
Dec 11, 2010 | Microsoft Xbox 360 Arcade
How to setup xbox live
If you want to go wireless or you must go wireless you will need to get the Xbox360 wireless network adapter. The adapters are available at most stores that sell 360 games or you can order it online. Once you have the adapter unplug any Ethernet cable you might have plugged into the 360 then clip the Network adapter to the back of the 360. It is really easy to see where it belongs, but just in case, the adapter will sit right alongside the USB port which is right above the Ethernet port. Once you have clipped it in plug the USB cable that is attached to the adapter into the port on the Xbox 360. Flip up the antenna that is laying flat against the adapter and you are set, well almost set.
Turn on the 360 and head into the System tray. You will see Network options, go ahead into that screen and follow it through to the "Edit Settings" subcategory. The Network name should appear on a list of available networks. Select your network and enter the password, if there is a password. Exit out and you should be ready to play.
Nov 27, 2010 | Microsoft Xbox 360 Elite Console
When i try and sign in it says. a problem has occurred
I know this might sound like annoying tech support but unplug your enthernet cord from your xbox and unplug your modem and router(if you have one) for about 5 minutes and plug everything back into everything..make sure your 360 is off.
Aug 31, 2010 | Microsoft Xbox 360 Console
I can sign in to xbox live
It green screens after 10 mins
Are you using hdmi cable. If so your hdtv needs to have it's hdmi port reset .First unplug everything even the TV and xbox. Then disconnect everything and unplug every thing from the wall outlets. Then plug the TV back in and hook everything back up. The HDTV even with the power off can have it's hdmi port bumped so you need to unplug it to reset the ports.
Thank you
May 09, 2010 | Microsoft Xbox 360 Console
Memory or video Issue?
Try unplugging everything and letting it sit for a few minutes. 10 is a good safe number. Plug everything back in and try again. If this doesn't work, you have a serious issue that microsoft needs to address and fix.
Oct 04, 2009 | Microsoft Xbox 360 Console
When playing games my xbox 360, the screen will
try this. unplug everything (power cord, av cables, wireless adapter, controllers) and take off the hard drive. dont plug anything in for about 1-2 minutes. when the time is up, put the hard drive on first then plug everything else in.
Sep 27, 2009 | Microsoft Xbox 360 Arcade
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Help.. My xbox has 3 reds lights
Hello.
This is a common problem from the Xbox 360.
The only way to fix this problem is to call Microsoft or email them. Its something to do with the hardware failure. Its over heated. Their is one way to fix it but temporary.
Its called the towel trick.
First, Unplug your xbox.
Then wrap it around with Heavy towels dont expose anything on the xbox 360. Cover everything.
Then plug in the xbox 360 while the towels are around it. After you do all that you wait 15 minutes. Then unwrap the towel from the xbox 360. It should be very hot. Let it cool down for 2 minutes then plug everything in and it should work.
But I hope this helps you.
Dec 30, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
