Question about Stanley Bostitch N88rh Framing Nailer Driver Piston 158582
I have a Bostitch Framing Nailer that I bought used. No manual. I used it once, and I noticed that it fires two nails (POP-POP). I'm only looking to shoot one at a time and it shoots two. Is there something I can do to fix that? Lower air pressure? Lubricating? etc Thanks
    Problem Solver:
  • 5 Answers
Could have the sequential trip trigger on the gun, there is a single shot trigger available! I believe the single shot is Grey in color!
Posted on Sep 13, 2010
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
My N88rh shoots two nails at a time
N88rh uses a full round head plastic collated nails which are spaced apart enough that the driver cannot hit two nails at once. If your are using other nails that fit into your magazine that are closer together you may in fact drive two nails at once. If, however you are using the correct nail and the nailer shoots twice, then you probable have a very sensitive firing valve. You could change the TVA6 valve or change the actual trigger. To overcome this problem of double firing and you do not want to try changing the firing valve, you need to change the trigger to sequential type instead of bump fire type. This trigger is usually white and will only permit one nail to be fired. Check www.toolpartsdirect.com or bostitch.com for parts. Good holiday
Nov 28, 2010 | Stanley Bostitch N88rh Framing Nailer...
I just bought a used Bostitch Coil Nailer. 3 1/4" nails work fine but the 2" nails will not keep feeding.
Check the spacing of the nail collation between the two nail sizes and also the spacing of the copper wires. Some nailers have a different setting for the check paws on the latch door to compensate for the thinner nails (too much clearance between the latch door and body of gun). Check manual at www.bostich.com for proper setting of check paws between nail types. Good luck
Oct 12, 2010 | Stanley Bostitch Coil Framing Nailer
How do you set up the bostitch coil framing nailer for contact nailing?
Bostitch nailers have two triggers available. Black trigger is rapid fire while the gray is single shot. Both triggers are usefull depending on type of work. Most people say that there is a degree of accuracy with single shot allowing for better placement of nail. If speed is your goal then use the black trigger to bump fire. More information and parts can be found at www.bostitch.com , look for "Support" tab, then "service / parts " find your model number from the pull-down list and search for the manual and parts list for needs. Good luck on your projects.
Jun 30, 2010 | Stanley Air Tools & Compressors
Have a stanley bostitch framing nailer. Nails
Normally, yes- depends on how old the nailer is. But first, let's ask: are you getting at least 90 psi of pressure to the rig?
If so, you may adjust the nailer with an allen wrench, or with a thumbwheel, both of which are located near the firing mechanism.
IMPORTANT: before you mess with it, be sure no pressure is left in the unit, otherwise you may be on here asking how to extract a framing nail from your skull while your hand is attached!
Nov 25, 2009 | Stanley Air Tools & Compressors
Stanley Bostitch Coil Framing nailer blows head off of nail?
Make sure that when you run with one gun that your psi is between 90-110. You may need a kit. Is it an RN45 or 46? Go to Stanley Bostitch online and look up parts and schematics. Kits should only be about 15-20 dollars, easy to put in, and come with instructions. Lemme know. Please rate me
May 31, 2009 | Stanley Bostitch Coil Framing Nailer
N80sb-1 stanley bostitch framing gun.
Yes your nailer will drive other sizes of nails. For info and parts go to www.bostitch.com and look for the support tab then select service parts. Here you will find parts list and manual. To remove the tva11 trigger valve remove the retainer pin (the pin is 3mm) for the trigger and remove trigger. Next remove roll pin/pins that retain trigger valve. Use heavy glove to catch trigger valve as you apply air pressure to gun. The valve could pop out with great force so try lowering the pressure to gun. Before installing the new valve, check the opening for sharp edges which will cut orings. Good Luck and email if you have more questions.
Mar 14, 2009 | Stanley Air Tools & Compressors
Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Jan 05, 2009 | Stanley Bostitch Coil Framing Nailer
Stanley Bostitch N88rh Framing Nailer Driver Piston 158582 Logo
173 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
