Question about Asko 24 in. D3120 Dishwasher
Asko D3120 seems to have a blocked drain hose, what do I do?
I have purchased a house that has this diswhasher. It hasn;t really cleaned well from the start, so I stopped using it. Now it appears the grey hose out the back of the machine had a blockage. O cleared it, but it still won't go. Any ideas??
  • Asko Master
  • 12,061 Answers
Http://www.servicematters.com/maytag_library/docs/16010622.pdf
http://frigidaireservicetips.com/pdfs/486_5.pdf
OK those two service manual links should help you troubleshoot and hopefully remedy your problem. All DW's are very similar and what is troubleshooting for one, is same for many.
Posted on May 15, 2010
Testimonial: "Thanks for your help"
Asko D3120 remove door to clean
Depending on how thorough you are wanting to be depends on how far you want to dismantle the dishwasher, The outer door needs to be removed first, there are torx screws around the outside of the door which you need to remove and also 2 harder to spot ones at the bottom, The hinges are attached on the sides with another 2 torx screws each side but be careful as the hinges are under tension and can be a pain to align when putting back together.
Most of the time you don't need to remove the entire door to clean it but once the outer shell is off you can get to the front of the basepan where the dirt seems to gather around the lower door, A stiff bottle brush is good for cleaning this, Be very careful with the electronics and ensure you don't get any moisture near them, Also be careful with the wiring as due to exposure to heat the wires on this model can get brittle especially where the wires curve under the machine inside the plastic protective tube...
have fun.
Mar 04, 2012 | Asko D1716 Built-in Dishwasher
I have an f3 and f4 error code on asko washing machine front loader. i know what the error codes are just dont know where they are anyone can help I need it thanks
F3 indicates a problem with the drain pump. At the bottom left of the machine, theres a square cut-out. This is where the drain pump is located. Using a flat head screwdriver or similar object, insert in opening on right side and gently pry open the drain pump cover.
Once the cover has been opened, be careful when opening the drain pump, as there is always a little water left in the drain pump. Before you open the drain pump, place a small container on the floor below the drain to catch the water. Pull the small black hose from the door and let the water drain into the container. You can now open the drain pump to clean it out. Also clean the pump rotor at the back of the pump housing. Replace the drain cover and reconnect the drain hose securely back to its position on the door. Close the cover.
F4 indicates a problem with the water inlet valve. Make sure the water supply is fully turned on. If no water enters the machine, then turn water supply off. Disconnect the hoses from the water inlet valve to see if the strainer in the inlet connection is blocked. Reconnect the hoses and turn on water supply. Hopefully this solves your problem.
Feb 14, 2011 | Asko W6441 Front Load Washer
I need to replace the drain hose on my Dishwasher - Asko D3120. Do I need genuine Asko part or is there cheeper generic option?
asko is a hard one to get generic parts for,, if you will have any luck repair clinic.com will be your best bet
Jan 19, 2011 | Dishwashers
Havnt used my dishwasher in 2 years on account of saving water. now when i push the start button some water flow into machine for a few minutes and then just stops. manual says to clean filters and drain...
Try pouring water from a bucket through the front. maintain the level. It should not overflow.
Run a empty cycle. If there is a air block it will get cleared.
Sep 08, 2010 | Asko 24 in. D3120 Dishwasher
When I start my dishwasher it will initally drain any residual water and then add clean water but will not wash the dishes.
I had the same problem and replaced the control board - problem solved. The good news is it's easy to replace; the bad news is a replacement board costs almost $300.
Jan 19, 2010 | Asko 24 in. D3120 Dishwasher
Asko D3120 I have resolved the problem of pum always running by tilting the dishwasher but now I have a new problem of the pump not draining the water in the bottom of the dishwasher. I thought it was...
In the bottom where the filter are, you can see a yellow 'thing'. Remove this and stick one finger in an try to rotate the pump wing. Try to remove particals that is blocking the pump.
Or there is something in the drain hose. Try to drain the machine by holding the drain hose over bucket. If it drain here, then the problem is under the sink.
Jul 17, 2009 | Asko 24 in. D3120 Dishwasher
I have a asko d3120 and it's only draining water and will not start or stop draining :( what can i do?
check the float switch under the pan .. you could have water in the pan or float stuck in the up postion...
Hope it helps if NOT let me know more about your problem... and I will help
Jun 08, 2009 | Asko 24 in. D3120 Dishwasher
Asko d3120 flashing coffee cup
I had to slide the dishwasher forward (undercounter installation)and tip it forward as far as possible. Water leaks onto floor, but then the internal controller seems to reset and the ASKO now works normally again. What kind of idiot would design a control module that does not incorporate a power-off interlock? FAIL FAIL FAIL - Bad, ASKO, Bad. Go to your room.
Nov 18, 2008 | Asko 24 in. D3120 Dishwasher
ASKO Overfill protection tripped
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Dec 31, 2007 | Asko 24 in. D3120 Dishwasher
Asko 24 in. D3120 Dishwasher Logo
521 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
