Question about Car Audio & Video
I have a lanzar opti drive plus 500 old school,i have 2 12'' 1200 watt pyles,running in parallel at 2 ohm. when i bridge it at 2 ohm 1000 watts it blew my 40 amp in line fuse.
  • 3 Answers
The 40 amp fuse is too small. 1000 watts = 12 volts @ 83 AMPS. Bigger power wire my friend. If you want to sell, let me know.
Posted on Aug 21, 2010
I want to connect Max 2500 with 6 JBL Control 28 speakers 175 watts @ 8 ohms each... please suggest what will be the best connection...series or parallel
first is how u want to run the amp itself ....... the MAX2500 can run in mono (bridged) output or stereo ......... though wat u want to watch is the impedance of the load really with the bridged load being no lower than 8 ohms/1500W (there's reasons for this) and the stereo load where u can have either 4 ohms/750W or 8 ohms/500W so how do u want to run this is first the question ..... all 6 on the bridged output or 2 off each channel (though running 3 would make for complicated impedance load) ..... so u'd run 2 in parallel for a 4 ohm load with 300 watt requirement from the amp and u can drive them to 1.5 times their rated RMS figure so a nice 500 watts :)
Feb 07, 2012 | Phonic MAX 2500 Amplifier
I just bought a old school lanzar opti 50c amp but i need to know what is the postive and negtive for the speaker output and what one is for bridgeing?and what is the spec? what is the lowest ohm i can go
the 50 C was used as a cheater amp back in the 90. You will be shocked by what this thing is capable of doing you can run an entire system subs mids and highs off of this 50 C. About 1300 watts
Jun 19, 2011 | Lanzar OPTI 50c Car Audio Amplifier
I have a plad213 what load impendance am i running it i hook up 2 4ohm speakers in series bridged on that amp and how many watts RMS am i getting per speaker
2 4 ohm speakers wired in series is 8 ohms and then is dropped back down to 4 ohms when you bridge it.
2 4 ohm speakers wired in parallel is 2 ohms then dropped down to 1 ohm when bridged
(most amplifiers will not handle loads below 2 ohms)
hope this info helps
May 20, 2011 | Pyle Dryver PLAD213 Car Audio Amplifier
I have a Lanzar 4000 watt amplifier hooked up to 2 12inch MA Audio subs. When I crank my car the green power light on the amplifier comes on, but after a second or two it changes to protection mode. I have...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to get an old school Opti Drive. .A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-4000-watt-amplifier-hooked-up-2-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Jan 29, 2011 | Lanzar VIBE286 Car Audio Amplifier
Would a Pyramid 15" subwoofer work for my Yamaha synthasiser?
Do yourself a favor do not get anything Pyramid they are cheap for a reason and you will not get good bass response from them even in a optimal enclosure.If you want nice bass for little money go with lanzar opti 1535D sub you can pick one up for around $265 and will blow away Pyramid any day.
http://review.zdnet.com/product/subwoofers/lanzar-opti-drive-opti1535d-car-subwoofer-driver/33649420
  • Custom Tooled Die-Cast Aluminum Basket
  • COC Composite Cone
  • Jumbo Dense Foam Surround
  • 3’’ High Temperature Dual 1.2 Ohm Voice Coil
  • 100 Oz x 3 High Density Barium Ferrite Magnet
  • Power Handling: 1600 Watts RMS /3200 Watts Peak
  • Frequency Response: 30 - 500 Hz
  • Impedance: Dual 1.2 Ohm Voice Coil
  • Efficiency: 88dB
  • Includes Installation Hardware and Template
  • Packaged In a Wood
  • lanzar-opti1535d.9909657.jpg lanzar-opti1535d.3004946.jpg lanzar-opti1535d.9909658.jpg lanzar-opti1535d.1054589.jpg lanzar-opti1535d.1785277.jpg lanzar-opti1535d.9909656.jpg default.jpg
    Apr 18, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
    What size amp do i need to run 4 1000 watt pyle 10's bridged
    well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
    Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
    To get the most power what is the best way to connect paraelle or
    run them straight and dont use the cross over. One speak on right channel and the other on other channel. Then turn up amp settings 7/8 the way up and control the rest from your dvd/cd player. I recommend some monster cable which is very thick. Ground the amp directly to trunk bolts but make sure to scrape the paint off or the connection will be bad. You can also use a cap which will send battery pulses to amp much quicker.
    Nov 19, 2009 | Lanzar VIBE286 Car Audio Amplifier
    Hi i have two 10'' jenson xs sub and they are about 6 years old and i was wondering wut amp size i should buy to run them.
    I believe these are 4ohms, if so buy a 2ohm stable monoblock amp, that puts out 250-300 watts RMS, and connect your subs to it in parallel, don't pay attention to peak watts, look at RMS watts, or continuous watts. If they're 2 ohms, buy a 2 ohm stable 2 channel amp that puts out 125-150 watts RMS per channel, and 250-300 watts total or bridged RMS output. And connect them normally, on sub per channel... hope this helps, as far as brand recommendations, MTX, pioneer, Alpine, Kenwood... Good luck
    Sep 20, 2009 | Jensen XS-1010 Car Subwoofer
    Lanzar amp 1000 watt stays on protect mode
    Hello snow11879,
    I haven't been able to locate any support information online about your product, other than the email contact for support questions:
    support@lanzar.com
    If the amp stays in protect mode all of the time, I would suspect a short in the speaker wiring or speaker(s) voice coil(s), or perhaps a faulty ground. If it plays for a short period of time and then goes into protect mode, it is most likely overheating. First check all of the wiring. Test your speakers on a known good amp and make sure there are no places in your wiring where the insulation may have been damaged, causing an intermittent problem.
    Many owners have reported that this particular amp has a tendency to overheat. Also, when run in bridged mode, the speaker impedance needs to be at least 4 ohms. It will overheat if the impedance is below 4 ohms.
    Hope this helps.
    Apr 18, 2009 | Lanzar VIBE266 Car Audio Amplifier
    Car Audio & Video Logo
    360 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
