Question about Boating
MERCRUISER 260 ENGINE WILL NOT RUN FASTER THAN 2000 RPMS
  • 5,537 Answers
Change the fuel filter and see if it helps. Disconnect the throttle cable and work the carburetor by hand and see if it helps. (Cables improperly adjusted).
Next, try drawing vacuum through the distributor dashpot and see if the spark is advancing. The vacuum should hold and the breaker plate should move.
Next items would be to check vacuum pressure. Then check fuelpump pressure. Finally the prop can affect the engines top RPM, Thats about all I can think of, Good Luck.
Posted on May 15, 2010
Why does my mercruiser engine die when put in forward?
Something is too close to the coil wire , CAbles(steering and throttle ) either up front or on the engine do flex when moved.Checkthe movement and operating clearnces at both full and idle positions. All tests can and should be done with engine off, due to Dangerous prop exposure. Good Luck and I would like it if you tell me what you ultimately find. _Ned_
Aug 03, 2014 | Mercury Marine Mercruiser 120 140 3.0 470...
Why is it hard to start my Mercruiser 7.4L MPI after a hot run?
Electric choke? Try retrofitting a manual choke. I think the electric choke is closing over a hot engine, thinking that the engine's cooler than it really is. A manual choke will allow you to start it with no choke at all when you know the motor's already warmed up.
Jul 25, 2014 | Mercury Marine Mercruiser 350 - 454 - 5.7...
Mercruiser 4.3 LX engine looses power
Check the fuel supply line and filters.
Jul 14, 2014 | Boating
I have a mercruiser 260 and wheb i connect the 2nd battery it arcs is my isolator bad
Check the polarity, it sounds real wrong, the batteries need to be pos to pos and neg to neg.
May 12, 2010 | ProMariner Battery Isolator 2 Alternator ...
All the gear lube on my bravo III leaked out. The oil came out where the prop and the lower unit meet.
we had replaced the engine in our 87 4.3 star craft and when we put the omc cobra stern drive back in we now dont have foward gear, we have nuetral and reverse. could it be the linkage or could it be the shifter cable or any other idea's that could be the problem.
Nov 09, 2009 | Garmin Boating
WHAT IS THE HIGH SIDE RPM ON A 15HP B&S ENGINE?
It depends on the application but the ABSOLUTE maximum you want to run is 3600 RPMs
Sep 14, 2009 | Garden
2000 GMC Jimmy 4.3 engine surging while running
HAVE YOU HAD YOU THROTTLE BODY AND OR YOUR CAM SHAFT SENSOR CHECKED OR YOUR AIR TEMP SENSOR ? IT MOST LIKELY SOUNDS LIKE YOUR AIR TEMP SENSOR IS'NT LETTING ENOUGH AIR IN OR OPENING YOUR MASS AIR FLAP ENOUGH WHEN ITS COLD OUT CAUSING THIS.
Apr 11, 2009 | 2000 Chevrolet Blazer
Good idling speed
This all depends on when you are reading the rpms becaus ethe engine will run faster when you first start it to bring it up to operating temperature than it will drop down to about 700-800 when the engine is warm. i recommend letting your engine warm up, than read your tach and if it is still reading 1000 rpms than reduce it down to 700-800. your ECU will compensate for this when your engine is cold.
this could also be a possible bad Idle Air Control Valve because your engine speed should be regulated by the computer.
Mar 30, 2009 | 1998 Honda Civic
Boating Logo
300 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
