Question about Acer TravelMate 240 Notebook
Travelmate 243x i have cleaned the heatsink of all dust , but the fan is erratic, screen is dim and computer shuts off
  • Anonymous Aug 08, 2008
    how to change the fan?
    Scholar:
  • 133 Answers
Its just because of your fan ... your fan is not working properly so processor is becominh over heat and problems occurs
try to find new fan for your notebook
i know its defficult to find cpu fan for notebook but you must have to find it
Posted on Apr 08, 2008
My acer travelmate 4200 starts up and then shuts off
Try another Cord/Charger with the EXACT same power specs. Have you cleaned the fan, vents, heatsink recently? Do you get to any screen? BIOS setup? Boot Menu? Has the AC jack been damaged due to pulling on the cord?
Apr 15, 2013 | Acer TravelMate 4200 Notebook
Acer Radiator fan will not shut off PC Desktops
LOL, some fans will not shut off, this is normal in some case. But, to be sure your system is not running real hot to keep the fan running try this:
Remove the Power Cord, Remove the Case and take a can of compressed air and blow out dust from the computer's vents and all inside the computer. Also blow out dust from around the power supply and fans.
If it still runs all the time you can remove the fan that sits on top of the cpu and heatsink and clean the dust and apply a fresh coat of Thermal Paste to the CPu and HeatSink.
Apr 11, 2012 | Acer Computers & Internet
15 to 20 mins screen will go blank and will have A black screen reboot and it will work 10 or 15 mins. RELOADED XP AND THIS DID NOT HELP, SAME PROBLEM
Your Dell OptiPlex GX260 PC Desktop computer is overheating. It is shutting itself down to prevent component failure.
Ensure that the Processor heat sink is clean of dust so sufficient air can flow through the heatsink and cool the processor.
Install additional fans in your computer 120mm are best but 80mm fans will do fine.
Clean the computer chassis of dust as well.
Thanking you
damnor01
Feb 02, 2011 | Dell OptiPlex GX260 PC Desktop
My system is shutting down and restarting and it shows system shutdown by thermal
Hi:
When you have a thermal shut down, the first thing to check is the Heatsink/fan assembly. When you computer is cool, open the side panel, and power up the computer, and make sure the fan is spinning on the processor. If it is, observe the interior of the computer, and see if there is alot of dust and lint build up around the fan assembly. Obtain some heatsink compound, and carefully remove the clip or bracket that holds down the heatsink fan assembly. carefully clean off the bottom of the heatsink, and the top of the processor, and reapply heatsink compound in a thin layer to each surface, and reattach the heatsink/fan assembly, after you have cleaned it up. this should take care of your problem.!
Sep 21, 2010 | Intel D945GCCR Motherboard
Over heatng and shuting down
Computers will shut themselves down when they overheat in order to avoid damage.
Try pulling the battery out and seeing if it works better. If it does, then replace the battery.
It could also be that the CPU heatsink has fouled. Either the heatsink grease is bad (provides a good connection between the CPU and the heatsink itself). Or there could be a insulating layer of dust between the fan and the heatsink.
-=/ Daft Tech /=-
Oct 27, 2009 | Computers & Internet
Acer Aspire 1640z overheating
Clear the dust from the heatsink and fan assembly. Most laptops have vents on the bottom and outlet vents on the side or back of the laptop. The fan covers on the base are held in place by screws. The fan is usually over the CPU and is held in place with 3 or 4 spring loaded screws, remove these will allow you to remove the fan and heatsink assmbly.
If there isn't vents on the bottom of the laptop, only on the sides and back edges, then the heatsink and fan assembly is usually located under the keyboard and you need to remove the keyboard to clean/remove the dust off the heatsink/fan.
After cleaning and before re-assembly apply a thin film of heatsink compound on top of the CPU.
Feb 21, 2009 | Acer Aspire 1640Z Notebook
Computer shutting down automatically
Remove case side and clean out ALL fans then remove fan from heatsink DO NOT remove heatsink (probably stuck on CPU) clean all fluff and dust from heatsink.
Use a stiff brush and vacuum cleaner on power supply fan area
then vacuum out case include all vent holes and behind power supply. test start.should be OK
Oct 29, 2008 | EliteGroup 945GZT-M (V1.0) Motherboard
Travelmate 243x
its because of your laptop is having dust inside
you didn't mention how old your laptop is
but you can see a holes for cpu fane in your laptop
by this hole dust goes inside and now your heatsinkl is not working properly
so just open your laptop case if you know how to do this
otherwise its not advisable
if you dont know how to open case go to any technician and let him do this for you
Mar 29, 2008 | Acer TravelMate 240 Notebook
Overheating
yes its probably the fan but it could also be the screen brightness. replacing the fan and turning down the brightness will cool the laptop. but i agree try a new fan first.
Dec 26, 2006 | HP Compaq Presario V2000 Notebook
Acer TravelMate 240 Notebook Logo
264 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
