Question about Sony KDS-60A2000 60" HDTV
I replaced the bulb, closed the doors properly,try to turn on tv,
I replaced the bulb, closed the doors properly, then, when power button is pushed, it sounds like the fan tries to turn on, then nothing. power button flashes 3 times indicating the bulb is not installed properly. I repeat the procedure with the same results. Now what?
  • 1,557 Answers
Find the reset button and depress it for 30 secounds then fire the unit up again and leave to run for at least 1 hr
Posted on May 15, 2010
Won't turn on! No green light to show that it has turned on.
look for a tiny hole in the button panel. It may or not be marked reset. Straighten out a paper clip and push it in the hole slowly until you feel it stop. Gently push it to reset the TV. If that doesn't work, then look at the lamp cover door to see if it is closed all the way. The switch may be bad too.
May 29, 2016 | Mitsubishi WD65737 65 inch DLP 1080p HDTV
Why does my DLP TV turn itself off
Try replacing that lamp door switch, this has been known to cause issues in some Samsung DLPs
Contact Samsung at 1-800-627-4368 for proper part#
Oct 21, 2014 | Samsung HLP5063WX/XAA
I heard a pop on the Toshiba rear projection TV (model #62hmx84) and immediately lost the picture
Sir the problem of your unit is the lamp try to replace it it is much better to use a gloves and wash your hand after replacing the lamp because this lamp contains mercury. follow this steps.
1. Unplug the unit to main ac outlet. Remove the bulb housing cover from the back of the TV. Using a screwdriver, carefully remove the cover to reveal the old bulb. Using a cloth, remove the bulb from the TV by first unplugging it from the wiring harness. Carefully rock the harness back and forth until it comes free from the bulb. Push in the bulb slightly and turn it a quarter-turn to remove it from the bulb housing.
2. Install the new bulb. Do not touch the new bulb with your fingers, as any grease or fingerprint from your hands will damage the tiny mirrors in the bulb. Instead, carefully handle the bulb using the cloth. Insert it into the bulb housing and secure the door. Test the unit. Plug in and turn on your Toshiba TV and make sure that the new bulb is installed properly and that the image looks crisp.
3.
Reset the lamp time counter. Each Toshiba TV comes with a lamp hour meter stored in its software. If you do not reset the lamp timer, the unit may stop operating when it gets to a certain time (refer to your manual because each Toshiba TV is slightly different). To reset your Toshiba lamp timer, turn off the TV, wait 10 seconds, hold down the "on," "menu" and "input" buttons on the remote at the same time, and turn the power back on. A yellow light should appear in the bottom corner of the TV indicating that the lamp timer has been reset.
Hope this help good day and best regards.
Sep 23, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
Sony TV kds60a2020 replaced lamp and power lights blinks three times. Checked to make sure lamp was secure. Would light still blink if defective bulb?
have you tried making sure the lamp door is closed ... generally 3 blinks means the lamp door is not closed the door pushes a switch closed
Jun 03, 2011 | Sony KDS-60A2020 60" HDTV
I push the power button standby light turns red & blinks 3 times 7 THEN TURNS OFF
If the standby light is flashing 3 times. (your post says 3 times 7) I was unclear... A error code of 3 blinks inidicate that the door covering the lamp is not secure oer the lamp is not secure. Make sure the lamp door is seculy screwed down. ussally the door push a little switch closed. If this doesnt work the next thing to try is to remove the bulb carefully(dont touch the lens) and replace it making sure the bulb is in place securely. let me know if i can help any further
Mar 04, 2011 | Sony KDSR50XBR1 50" Projection HDTV
THE INTERIOR LIGHTS TO MY 98 BUICK LASABRE WON'T TURN OFF. I TRIED TO TURN OFF THE CAR BUT THEY STaY ON THEN WHEN I START IT AGAIN. THEY TURN OFF MOMENTARILY THEN COME BACK ON. WHAT SHOULD I DO?
do you not have a switch on dash for them? try turning the switch counterclockwise to turn them off. or you may have a bad switch on the door jam,,look for a plunger swictch on the door jam itself push the plunger in on the doorjam,,if the lights go off, then you'll know the problem! hope this helps!1
Sep 16, 2010 | 1998 Buick LeSabre
The power light is red and the bulb light is blinking red
OK...Did you replace the lamp with a Sony original? If you did, then carefully check that the door is closed properly.
May 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
Garage Door opened but will not close. I opened
I think the trolley has jammed against the bolt just in front of the motor unit. Remove the bolt and then run the door until it is closed. With the door closed locate the 'up limit' control on the side of the motor unit. Turn this 2 turns in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lamp replacement
Hi there
Make 100% sure that your lampdoor is closed properly because there is a little swith on the lamp door that supplies the power to the mashine ( only when pushed in ) You'll see on the lamp door there is a pin that stands out - that pin pushed in the switch when the lampdoor is closed thus supplying power to rest of the components.
Apr 10, 2008 | BenQ PE8700 Multimedia Projector
Sony KDS-60A2000 60" HDTV Logo
662 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
