Question about Nintendo Wii Console
Internet Problem with Wii
I got my wii connected to my router and the wii says support code 61212, but still not have access to internet.
  • 864 Answers
Try to trouble shoot the unit. If after following the guide you still need further assistance i will be glad to help. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
Setting up wireless conection to my wii
  • 1Before you connect Nintendo Wii to wireless Internet, set up your Wii console according to the manufacturer's directions.
  • 2Turn on the Nintendo Wii and wait for the main menu to appear.
  • 3Using the Wii remote, point and click on the small Wii button in the bottom left corner.
  • 4Select Wii settings.
  • 5In the bottom right corner click the black square with the number 2 in it or use the right directional arrow to go to the next page. When you come to "Internet" click it.
  • 6To connect Wii to the Internet select "Connection Settings."
  • 7On the next screen select the first connection that says "none."
  • 8On the following page, when given the option for wired connection or wireless Internet, select "wireless."
  • 9Now it's time for your Wii to search for a wireless connection. To do this choose "search for an access point."
  • 10Press "okay" and find the name of your wireless Internet. If it's not on the first page, arrow down until you find it. If you need a password to access the Internet, you will be asked to enter it. Click okay.
  • 11Click save and okay so the Wii remembers the wireless Internet connection options for the future.
  • 12Finalize the Wii Internet connection process by testing the wireless connection.
  • 13When Wii's wireless Internet test finishes successfully, you're ready to play Wii online.
  • Read more: Video: How to Connect Wii to Wireless Internet ' eHow.com http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html#ixzz1f6AZS48m
    Nov 26, 2011 | NetGear WGR614 Wireless Router
    Tip
    How to connect your Nintendo Wii to the internet
    In this tips and tricks guide I will go over the steps you will need to take if you wish to connect your Nintendo Wii to the internet. If you want to connect wireless you will need to be within range of a wireless access point. If you wish to connect via a wired connection(Ethernet to modem or Ethernet to router) you will need a Wii LAN adapter which is sold separately.
    -Power on the console and press the A button to reach the Wii menu. At the menu, use your remote to select the Wii button at the bottom left.
    -Now select "Wii settings"
    -Now, hit the arrow on the right side of the screen to go to the next page and select "Internet"
    -Select "Connection 1: none"
    -Select "Wireless Connection" then select "Search for An Access Point"
    -Select "OK" then the Wii will display all the wireless access points(wireless routers) that are in range.
    -Select the wireless access point you wish to use.
    -If the access point requires a security key, you will need to enter this key in. This key is set when you first configure your wireless router.
    -Select "OK", then "Save Settings", and then "Yes".
    At this point your Wii will now test the internet connection.
    If you are using a Wired connection then you can connect the Wii directly to the router or modem and not use WiFi. Wii LAN Adapters are sold separately. If you have the LAN Adapter, follow the steps above up to the point were you select a connection type. You will select "Wired" instead of "Wireless. The Wii will now test your internet connection.
    I hope this guide has helped you connect your Wii to the internet. Enjoy!
    Regards,
    G33k
    on May 13, 2011 | Nintendo Wii Console
    Cant connect to my router netgear
  • Read more: Video: How to Connect Wii to Wireless Internet ' eHow.com http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html#ixzz1f6B48YnB
    How do you set up Internet on the wii?
    To access the internet with your wii console you'll need either a wireless router/gateway, or a wii wired LAN connector.
    1. Power on your Wii console
    2. Access the "Wii Setting" menu by selecting the circular wii icon in the bottom left of the screen and then choosing wii settings.
    3. Use the arrow on the right of the screen to move to page two, then select "internet".
    4. Select "Connection 1 ' None"
    5. Choose "Wireless Connection" (assuming you have a wireless router), then select "Search for Access Point".
    6. Wait for your wii to scan, then select your wireless network, and if prompted enter your wireless network password/key. Then click "OK".
    You should now be able to connect to the internet. If your Wii runs a connection test and it proves unsuccessful it will display an error code. If you get Error Code 51330 or 52130 this means the password you entered does not match the password on the wireless network you are attempting to join. A list of all other error codes and what they mean can be found here: http://www.nintendo.com/consumer/systems/wii/en_na/onlineErrorCodes.jsp
    Jul 24, 2011 | Nintendo Wii Console
    How to get the internet to the nintendo wii console
    Hi. Welcome to fixya!
    Hereis a step by step procedure on how to connect your Wii to the internet.
    1. Turn on your Wii console and press the A Button on the Wii Remoteto reach the Wii main menu. Use the Wii Remote to select the "Wii"button.
    2. Select "Wii Settings" to access the"Wii System Settings" menu.
    3. Using the arrow on the right side of thescreen, scroll to page two and select "Internet."
    4. Select "Connection 1: None"
    5. Click on "Wireless Connection"and then "Search for an Access Point."
    6. Select "OK" and the Wii willdisplay all the wireless networks it finds.
    7. Select the wireless network that isyours.
    8. If prompt to enter the security code,enter the security code that you have saved your router settings.
    Jul 19, 2011 | Nintendo Wii Console
    Trying to connect my WII council to the internet and it keeps coming up "Unable to connect to the internet Error code: 50230"
    Error code 50230 is thrown when the Wii's internet connection has not yet been configured. These instructions on configuring the connection settings come from Nintendo's website at:
    http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
    1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
    2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
    3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
        (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
    5. Click on "Wireless Connection" and then "Search for an Access Point."
        (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
    6. Select "OK" and the Wii will display all the wireless networks it finds.
    7. Select the wireless network that is yours.
        (If you're not sure which is yours, or you don't see any wireless networks, click here.)
    8. Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
    9. Select "OK," "Save Settings," and then "Yes."
      • The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
          As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
      • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
      • The connection test was not successful - If the test was not successful, you will receive an error code.
        • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
        • All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
    May 07, 2011 | Nintendo Wii Console
    How to set up nintendo wii internet
  • 1 In order to set up your Nintendo Wii internet connection, you need to have high speed internet service, such as DSL, cable, or fiber optic.
    If you want to use a wired connection for your Wii, you will need to purchase the Nintendo Wii Lan Adapter and a long ethernet cable to reach your router or modem. The Wii Lan adapter is available from many sources for about $30 and the cable will cost you around $10 or more. If you want to plug in your computer and Wii at the same time, you will need a router. You do not need a router if you are planning on unplugging your computer when you use Wii over the internet. Honestly, wireless routers cost about $35 and don't require a cable, so I purchased a wireless router instead. Plus, I don't want an ugly cable running across the room.
    If you still want to use the Wii Lan adapter to connect to the internet, here are the steps to connect your Wii Lan adapter to your Wii game system:
    Make sure your Wii game system is turned off.
    Attach the Wii Lan adapter to the USB port on the back of your console.
    Connect the other end to an ethernet cable that goes to your router or modem.
    Turn your console back on.
  • 2
    If you are using the Nintendo Wii Lan Adapter to connect to the internet, follow this step. If you are connecting to the internet via a wireless router, skip this step and go to step 3.
    To connect your Wii via a wired connection:
    Go to the Wii Menu.
    Click on the round Wii button on the lower left corner.
    Click Wii Settings.
    Click the right arrow to go to page 2.
    Click on the Internet button.
    Click Connection Settings.
    Click Connection 3.
    Click Wired Connection.
    Your Wii will do a connection test and hopefully everything will be all set. You are now finished.
  • 3
    To connect your Wii via a wireless connection:
    Go to the Wii Menu.
    Click Wii Settings.
    Click Connection 3.
    Click Wireless Connection.
    Select Search for Access Point. Click OK.
    Select the access point you want to use. Click Save and OK.
    You may be prompted to enter your password.
    Your Wii should now be all connected.
  • Nov 28, 2010 | Nintendo Wii Console
    INTERNET CONNECTION
    To connect the Wii to the Internet you will need a wireless router in your home. Otherwise, you have to buy Wii lan adapter to connect it with an ethernet cable.
    To connect, go to Wii settings, then Internet, then Connection settings, then Connection 1.
    Then click wireless connection and then let the Wii search for a wireless access point (a wireless router).
    When your router appears on the list select it.
    If your router has a key, then you have to enter it.
    Press OK and you are finished.
    Jan 30, 2010 | Computers & Internet
    Have just tried to connect the wii tothe internet
    to connect the wii to the internet you go to wii settings then find internet then there should be connections use connection 2 and set it for wireless then search for your router then input the security code which is on the back of the router which is wpa-psk or wep key then start the search then it ll upgrade then jump back to the wii main menu then you should be able to access the wii s online features
    Jan 24, 2010 | Nintendo Wii Console
    Error messages when updating Wii with my wireless connection
    Maby the place youre wii is put. I had to put my wii in a higher place.
    Jul 14, 2009 | Nintendo Wii Console
    Nintendo Wii Console Logo
    246 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
