Question about Apple MacBook Mac Notebook
I have a macbook pro 15 and the printer has always worked, but now it will put a doc in the queue and it says it's stopped. I try to start the job, but nothing happens.
  • jimgives May 15, 2010
    I did all that first sentence before I wrote, but I'll have try reloading. Thanks.
  • Apple Master
  • 6,487 Answers
It seems that the problem here is with your printer communication to your mac computer, so first thing that you can do here is to unplug and replug the printer from the computer and then restart the printer and computer. Then if still not working you may need to reload the printer software to your mac computer to correct the problem.
Posted on May 15, 2010
Only One Doc/Job Prints
When multiple docs/jobs are placed in the print queue, the printer becomes all confused and doesn't know how to prioritize. The solution is to dump the existing queue (usually by shutting down the printer and even disconnecting power) then queue up one or two jobs at a time to help the printer cope. This should keep Ground Hog Day at bay - at least for awhile :-)
Jan 02, 2014 | Lexmark Pro901 All-In-One Inkjet Printer
Lexmark x1270, installed on new Dell, will scan/print once but print queue won't clear after printing, and further jobs just back up in queue. Once, after trying reboot, printed next doc but that was...
Try to follow the steps below to fix the problem:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Aug 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
Samsung ML-2525W monochrome laser printer; connected via USB to MacBook Pro. Prt driver 1.00.02. First job prints fine; 2nd job in queue fails to print, and ''Open Print Queue'' indicates ''printer...
I have the same problem with mine - first job usually prints but no go on the second one. It tells me the printer is "offline". In some cases I can't even power cycle normally. I have to unplug the back cord and plug it back in, then I can power back on.
I called Samsung today 1-800-726-7864 and was told the printer will need to be taken to a repair center for service. Wish I had better news.
Apr 25, 2010 | Office Equipment & Supplies
Epson stylus sx205 won't print on my macbook pro
Def sounds like a driver error, do you get a yellow mark next to your printer driver or is it ok?
You could try & see if there is a more recent driver from epsons website
Nov 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Unable to delete doc after being sent to printer
First, I would try canceling the document either at the printer (hit cancel if it has already been sent) or at the computer.
You can do this by going to start -> settings -> printers and faxes
double click on the printer to open it
right click on the offending file and hit delete
It sounds like both of these have been done already. So...next option.
Second option - Restart the print spooler
Go to Start -> Settings -> Control Panel -> Administrative Tools -> Services
Click on the "Print Spooler"
Select Restart
Third option - delete the document from the spooler
Stop the Print Spooler by following the instructions above and clicking "stop"
Delete all files in the c:\windows\system32\spool\printers directory
Restart the print spooler.
CAUTION!!! - This will clear out both the offending job and any other jobs that have been sent to the printer after the offending job. If you have a number of other jobs, you may wish to clear out only the offending job from the printers directory.
Hope this helps - flub
May 29, 2009 | HP Officejet 4315 All-in-One Printer
Print Queue is stuck on
This is old, but I will post my solution for anyone else who might be having this problem.
In Mac OS 10.5: Go to System Preferences under the "apple logo" menu. Then select the "Print & Fax" module. Select your printer from the list on the left, and then click the "Open Print Queue…" button. Select the job(s) you want to cancel, and click the Delete button.
In older Mac OS 10: Go to the Utilities folder in your Applications folder, and open the "Printer Setup Utility". Double click your printer in the list. Then it is the same as above: select the job(s) you want to cancel, and click the Delete button.
Nov 30, 2008 | Apple MacBook Pro Laptop Computer with...
Cannot delete print jobs in queue
Instead of restarting, try this:
1. Start
2. Run
3. Type this in the box: services.msc
4. Hit ENTER
5. Scroll down to PRINT SPOOLER
6. Right-click on it and choose RESTART
This will clear out your print queue without having to restart. Good luck!!
Aug 22, 2008 | Lexmark Office Equipment & Supplies
Job in queue
Let me exaplin the cause why the jobs get stuck in queue: When ever we try to print there is a windows service called print spooler that manages the print jobs in queue. We can clear the jobs in queue by just disconnecting the usb cable and restarting the print spooler service. Here are the steps to restart the print spooler : 1.Click on start 2.Then click on Run 3.In the Run box type " net stop spooler " Then press enter Note: Type the text with out inverted cotes in the run box this will stop the print spooler service Next we have to restart the print spooler 1.Click on start 2.Then click on Run 3In the Run box type " net start spooler " and press enter Once done reconnect the usb cable and check for the jobs in queue. If there are no jobs in queue you can set the print directly settings to avoid this issue in future. Just open the printer and faxes folder and right click on the printer icon and select properties and then click on the advance tab and under it select the option print directly to printer and click on apply and Ok to save the settings. Once done try to print this should resolve the issue.. Wish u success..
Sep 18, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Apple MacBook Mac Notebook Logo
20 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
