Re: lg tower xp install
ive set atapi-cd rom as first boot device. then hard drive second. but whats fdd? also theres 4 boot device set up points not 3.
if it appears that i have a faulty connection from the IDE ( 40-80 wire cable ) that runs from the motherboard Primary/secondary slot that means cobbildugook to me lol. ive checked the cable that goes from motherboard to hard-drive and theres one connected but theres quite afew wires that aint connected to anything. jumper blocks what/where are they?
as for the small white plastic block i dont know where that is?
    Genius:
  • 1,019 Answers
FDD Floppy-Disk Drive.
It would be advisable to go to the motherboard Manufacturers site. And download the setup or user manual for this Board.
The White or black plastic jumper blocks i,ve refered to, are on the back of the Actual CD/DVD Rom Drive. Located at 1 end. this should be set to Master or Slave. diagram of settings usually printed on top of the drive. I dont know whether you have an IDE Drive ( 40-80 strand ) wire connecter.
Or sata drive connectors. 1 single red cable from motherboard to drive.
please bear in mind, this site is designated to solve technical solutions.
i,ll help all i can, but if your not technical minded, perhaps this is a job for someone more competant than yourself. no disrepect intended.
regards mike @ compurepair.
Posted on Mar 31, 2008
I have 1 note book LG X120 with windows 7. when im trying to install Windows XP proffessional through a USB CD ROM its showing the following Message * To specify additional SCSI adapters, CD-ROM...
Hi lionking2022!
Since this is a USB CD_ROM, you need change some settings in the bios for it to be detected and the system will actually boot from it.
1. You enter your BIOS
2. Look for the tab that will contain IDE settings
3. Change it to AHCI
4. Save and Exit
You may know try to boot from cd-rom and install your windows xp.
After the setup or installation is finished don't forget to changed it back to SATA or whatever the setting was.
Hope this will help.
Thank you for using Fixya,
avf110686
Mar 24, 2011 | AGPtek USB External CDROM Drive For LG...
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
I hav ejust purchased a new lg gh22 dvd writer. It is working fine in operating system like windows xp and ubuntu. The bios also recognizes the drive. But when i insert a bootable cd/dvd of ubuntu windows...
hi,
Is the hard disk drive is in secondary slave? If yes, change it to master and your dvd is into slave. Refer to the jumper settings at the back on the drive. If not work, your bootable disk may defective. Try other a botable disk.
Best regards,
geloaa
Oct 06, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Toshiba tecra m2v s330
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
Mar 20, 2009 | Toshiba Tecra M2V-S330 Notebook
Cd rom message "no emulation" when booting the windows xp installer
when i install my windows xp professional i get a message prompting BOOT TO ATAPI CD-ROM: "NO EMULATION".... how can i fix this?Pls help me on this
Jun 07, 2008 | ASUS P4SP-MX Motherboard
the boot device setup in the bios, if you set atapi-cd rom as first boot device. then hdd second. and fdd last.
it appears that you have a faulty connection from the IDE ( 40-80 wire cable ) that runs from the motherboard Primary/secondary slot. check the cable goes from motherboard to hard-drive and is connected firmly, also check the jumper blocks ( small white plastic block ) is set to master or slave on both devices ( cd-hard-drive ) if both on same cable set hard-drive to slave and CD rom to master. if they are both set as master or slave, they will conflict with each other.
if you need further help, please mail back.
mike @ compurepair.
Mar 29, 2008 | Computers & Internet
Lg tower pc
you need to go into bios at startup, press F2 Or Delete Or Esc on bootup. When you get into the System Bios. Change the boot device priority from HDD To CD/DVD To boot first.
Save/exit And when you reboot ( with windows XP in the Drive ) you,ll get options to format or re-install.
Mike @ Compurepair.
Mar 29, 2008 | LG GMA-4082N DVD±RW Burner
Got a laptop (ei systems) that i cannot properly start up, and access vital information which i just cant lose (court stuff etc). When computer turns on it say Boot device Hard Disk C / ...
try to boot your laptop from hard disk
reset your laptop & press f2 or del to go in cmos setup by press f2 or del key then afer go in boot manu select there is hard disk in a frist boot divice then save the settings by press f10
try this
may your problem will solves
Mar 23, 2008 | Computers & Internet
System is no boot neither with cd-rom nor hard disk
Hi, Based of your post/description and assuming not hardware problem, you may have to set up the priority boot device in the BIOS to CD. This will tell your mb to look for a boot medium from the cd first. This is normally in the Advance Setup/1st Boot Device. Of course soon as installed, you have to boot from the HD next time. Good luck and kind regards.
Aug 14, 2007 | Intel Motherboard
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
