Question about Olevia LT37HVS 37 in. LCD HDTV
Why cant i scan to access channels
Why cant i scan to accessthert channels
How to retune a tv
Whether you have a remote or not, you'll need to access a menu screen and figure out how to use the volume buttons or channel buttons to highlight the scan for channels section and allow the TV to scan to pickup or drop channels.
It's usually somewhat self-explanatory once you've accessed the menu.
Jul 31, 2014 | NEC T.v. Wall Mount
I have a 39 inch element tv i cant program the cable channels
Typically you can access the menu, select "tuner" or something similar, make sure you're selected either on CATV or ANT (or similar), then do a channel scan. Should be pretty straightforward. Oh, and make sure you actually HAVE cable. If it's digital cable, you may need an external converter box for it to work.
Feb 23, 2014 | Televison & Video
Emerson EWF2006 TV access code
if your tv doesnt have a digital tuner, you cant, unless you have a digital to analog tuner converter (can be purchased in walmart, or other stores that carry tv s, electronics) you tune your tv to 3 or 4, use the converter box to scan for channels, and for changing channels instead of your tv tuner
Mar 21, 2013 | Emerson EWF2004 20" TV
Cant get any bbc channels on new alba tv freeview
In that case you need to auto scan your TV to get all available channels on your location..
Go to menu and find auto scan and enter it..For best results please complete the 100% scan..
Aug 28, 2012 | Televison & Video
Lost channel connections
Go to the menu and then enter your choice out of them like find channels or scan/scan channels.
Apr 24, 2012 | Olevia 227-S11 27 in. LCD TV
How to get it to do a new channel scan
by the original remote thats my problem now all i really need is to at least scan
Sep 01, 2011 | Coby Electronics DTV102 ATSC...
Cant get wireles signal, i just switched service providers and can not pick up wireless signal.
Do a channel scan before you call provider and ask them to change it to a channel number that is not being occupied. Ask you provider to change your channel number on your router? You and your neighbor is sharing the same channel number. One is over powering the other.
Dec 09, 2009 | Linksys Wireless-G WGA54G 802.11g/b...
I cant get them to stay on same on the same channel
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T4500_User_Manual_E.pdf
Read the section on channels and frequencies followed by programming your radios to match one another. Then also read the section on scan. It sounds like you may have your radios in scan mode.
Nov 17, 2009 | Motorola T4550FP (22 Channels) 2-Way Radio
Cant attain digital channel scan on hitachi rear projection tv
Do you have the tuner locked out for use of HDMI input only?
Most of the time when a selection is not able to be hi-lited it is
because a feature that is activated locks out other selections.
Hope this helps,
Skyassoc
Jun 17, 2009 | Hitachi 51F59 51" HDTV Projection...
Olevia LT37HVS 37 in. LCD HDTV Logo
244 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
