Question about Car Audio & Video
I swapped my clarion cy-358 on my 2002 sentra with a cy-620 from a 2005 sentra. now i have no sound from the left speakers. both plugs fit right into the radio.
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: Replacing oem car radio/CD (Clarion PN-2165M I)
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Posted on May 25, 2011
Replacing oem car radio/CD (Clarion PN-2165M I) from 2002 Nissan Sentra GXE. I ordered Scosche Car Stereo Connector to avoid cutting OEM connector. Im confused about the OEM Radio/CD wiring colors as to...
May 25, 2011 | Clarion Car Audio & Video
I HAVE A CLARION MODEL AB213R OUT OF AN IVECO
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate people arnt rating hope this helps
May 10, 2010 | Clarion ARX6670Z Cassette Player
I need the wire color code for the clarion db225 ,so i can install it .
Red = switched 12V
Yellow = constant 12V
Black = ground
Blue/White = power antenna
Speakers are a color set, one with a black stripe
White set = left front
Gray set = right front
Green set = left rear
Purple set = right rear
The RCA plugs are pre-amp out.
Dec 27, 2009 | Clarion DB-225 CD Player
Left Channel does not work. Subwoofer and Right Channel work fine. The plug needs to be plugged into the brown jack on the front of the computer to work at all.
Sort of sounds like there's a PC in the mix.
Can you swap the left and right speakers to isolate the speaker from the source as the problem?
Have you tried switching the various plugs around to isolate if anything comes out to the Left Channel, ever or if any other speaker plugged in as the Left works at all? Turn the volume down and bring it up slowly at first because if you send Subwoofer programming to a speaker not designed for it you may damage it.
If nothing works when plugged in as the Left speaker, maybe the sound card is the problem. Resubmit a question with the source or the PC as the problem
Nov 28, 2009 | Altec Lansing VS4121 Speaker
Need wire colors power,ground,speakers/clarion arx6670zterryrose
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
Oct 12, 2009 | Clarion ARX6670Z Cassette Player
Clarion stereo in1997 mercury marquis wiring hook up to amplifer
make sure the speaker wires in the car do not have one side grounded.the output on the clarion is a floating output and cannot be grounded.the best solution is to look at the wiring on each of the speakers,and match them out to the ones on the clarion.the most common colr code is white front left,gray front right green rear left and purple rear right.each speaker has a plus and minus.mixing them up will result in the speakers being out of phase and result in poor bass performance.i would wire the wires directly to the clarion using crimp connectors.the first thing i would do is power up the stereo out of the car to 12 volts,and using a speaker make sure you have sound coming out.the yellow wire which is the clock/memory is a must to be connected to constant 12 volts or no sound can result
May 26, 2009 | 1997 Mercury Grand Marquis
No sound out of left side speakers, front and back.
easiest way to see if the left outputs have gone is to swap the right and left speakers over. if the left works out of the right channels you know if the set has had it.hope this helps
Apr 22, 2009 | 2004 Nissan Sentra
Need wire diagram for clarion 500EQA equalizer
You should contact a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
Apr 22, 2017 | Clarion Car Audio & Video
Clarion Model #PN-9881l plug wiring
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
Jan 11, 2009 | Clarion XA-311 Cassette Player
WIRING COLOR CODE
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Apr 07, 2007 | Clarion DRX5575
Car Audio & Video Logo
133 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
