Question about LG Flatron L1750S 17" LCD Monitor
When I boot my computer I cannot see the display on my LG monitor. However, if I turn the power on the monitor off and then back on, I see a flash of the display, but it goes back off again.
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 15, 2010
2 Suggested Answers
  • 732 Answers
SOURCE: When starting computer in the morning, the monitor
Hi, 12fixlouie here. LCD monitor may have intermittant solder joint on power supply board inside unit. May only need you to resolder it to fix. Locating it is a whole other problem in itself!!! If not into monitor "teardown" and all the other stuff that you will need to attempt a repair, then let me know right away. 12fixlouie
Posted on Sep 14, 2010
Monitor flashes logo and then turns black.with red lights on
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 07, 2014 | LG Flatron Computers & Internet
Lg monitor power problem
Good luck.
Aug 06, 2014 | LG Studioworks 563N 15" CRT Monitor
Gateway all in one touch screen model zx4931 turns on then shuts off before monitor can boot on.
Here's some tricks I would try...
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 25, 2014 | Computers & Internet
Hp p6530z desktop will not boot
It could be the monitor. Try a different monitor. Here's some tricks I would try...
Good luck.
Jul 02, 2014 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Nothing comes up on the monitor
Please check if there is power to the system.
Is this a laptop or desktop?
If it's laptop see if any light turns on in the computer and or if you can connect it to an external monitor to check if the problem is the LCD display or the Video Graphics Adapter.
If it's a desktop see if there's power to the monitor and to the system.
Do you seea any message like no signal or output out of range or is the monitor totally blank?
If you can provide additional information like if it's a desktop or a laptop, when was the last time it worked if there are any indicator of power coming to the system.
Hope to hear from you soon.
Aug 07, 2011 | Computers & Internet
My LCD LG Flatron monitor decided to go black after turning off my computer. When i went to turn it back on, my computer booted, but no display on the monitor. the blue light just kept blinking. Cannot...
More likely to have failed power supply due to bad caps, that will be the first place to look.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Nov 21, 2010 | LG 22" FLATRON LCD Monitor
My ADC monitor will not come on but the power light flashes yellow. Does this mean my monitor is shot? Is there a way to check it? The power adapter is still putting out 12 V. Thanks, Bob
Flashing yellow light usually means it is not getting the video signal from the PC, try it on other PC first to narrow it down the problem, bad VGA cable can also be the cause, last will be problem in the monitor itself which you will need to open up to inspect the inside. Post back what you find so we can helpou more. More likely to be bad backlights inverter board.
Mar 05, 2010 | Computers & Internet
PC boots for seconds then NOTHING APPEARS SCREEN
Check to see if you have inadvertently hit the CRT button which turns off your screen to turn on an externally connected screen even if there is no external screen plugged in. OR you could have a bad (Back-light) or (Inverter)
Jan 27, 2010 | LG Flatron L1750S 17" LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
LG Monitor L194WT - Indicator Lights Flashing
sorry - i posted my response at the original thread : )
Comment by ohms, posted on Jun 19, 2008
Definitely it is not your computer. When it was given the signal to go OFF, it did but like completely off.
Comment by ohms, posted on Jun 19, 2008Oh one more thing, if the monitor still exhibits same issue after setting your Power Options as displayed above,
check your warranty with that monitor and exercise it.
Yep u got it ! warranty or new monitor
Jun 19, 2008 | Computers & Internet
LG Flatron L1750S 17" LCD Monitor Logo
111 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
