I don't know what to use for the subnet mask gateway dns1 or dns2 entry on the set up. Thank you, G. Fuchs
  • Anonymous Mar 24, 2014
    Trying to set my iphone wifi. Where can I find the Subnet Mask Number and Router # on the modem
  • 68 Answers
Explain do you want to use home or office based network or the cable internet. Explain more so i would you help
Posted on Mar 30, 2008
Subnet mask
subnet mask is usually 255.255.255.000, or something like that. If you not know what it is, no use trying to set it up. Most devices do set this up after they know what the ip address is. Look what the router or your hub makes for other devices. The gateway (address) is the ip address your provider gave you to connect to.
Jul 15, 2014 | Microsoft Xbox Video Game Consoles & Games
Tip
Show Routing Table button will open a chart displaying how data is routed...
Show Routing Table button will open a chart displaying how data is routed through your LAN. Use the example below on how to configure a static routing:
STATIC ROUTING:
192.168.2.2 192.168.1.2
ROUTER C ----------------- ROUTER B ----------------- ROUTER A--------------PUBLIC IP ADDRESS
192.168.3.1 192.168.2.1 192.168.1.1
ROUTER A: Gateway Mode ROUTER C: Router Mode
1STENTRY 1ST ENTRY
DESIP: 192.168.2.0 DES IP: 192.168.2.0
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.2.2
HOP COUNT: 2 HOP COUNT: 3
INTERFACE: LAN INTERFACE: WAN
2NDENTRY 2ND ENTRY
DESIP: 192.168.3.0 DES IP: 192.168.1.0
SM: 24 SM: 24
HOP COUNT: 3 HOP COUNT: 2
ROUTER B: Router Mode
1STENTRY
DESIP: 192.168.1.0 WAN IP: 192.168.1.2
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.1.1
HOP COUNT: 2 DNS: DNS of 1st router
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
1stRouter must be set on Gateway Mode
2ndRouter must be on Router Mode
Use Static Routing
Select Entry
Destination IP = IP Subnet of the 1st Router
Subnet Mask = Subnet Mask of the 1st Router
Default Gateway = Interface IP
Hop Count = 1 + n
Interface= Connection to the 1st Router
Hope this help everyone.
on Apr 22, 2010 | Computers & Internet
Tip
HOW TO CONFIGURE STATIC ROUTING ON LINKSYS ROUTER
STATIC ROUTING:
1STENTRY 1ST ENTRY
SM: 24 SM: 24
2NDENTRY 2ND ENTRY
SM: 24 SM: 24
1STENTRY
SM: 24 SM: 24
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
Use Static Routing
Select Entry
Hop Count = 1 + n
on Jan 26, 2010 | Linksys Wireless-G WRT54G Router
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' sales@internetvoipphone.co.uk ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
Jan 16, 2013 | Panasonic KXTPA50 Phone
NOT CONNECTING TO THE INTERNET ON MY ROUTER ASKING FOR IP SUBNET MASK, GATEWAY, DNS1 AND DNS2
Sounds like your router is not set up for DHCP
try pressing the hard reset (pinhole probably) in the back of your router it should default to DHCP although you may loose your internet connection.
but without knowing your routers local IP address it would be difficult to connect to it to just switch on DHCP
Mar 17, 2011 | Computers & Internet
Trying to open ports
Try this instead Set static IP on your router like 192.168.1.60 (depend on your gateway) and DNS1 = 2.2.2.2 , DNS2 2.2.2.3
Apr 04, 2010 | Zhone Paradyne 6388-A1-200 Router
Xbox connected through network cable to pc ! what do i need to perform on pc through my wireless usb port connected to go online
If you are running Windows Vista on your PC here is how you can route your XboX360 through your PC/Laptop in order to get on Xbox Live Wirelessly:
1. Set up a Static IP address in Vista. Go to Start -> Control Panel -> Network & Sharing Center -> Manage Network Connections
2. Right-click on Local Area Connection and go to Properties
3. Double-click on Internet Protocol (TCP/IPv4)
4. Set the option to "Use the following IP address"
IP Address: 192.168.100.1
Subnet Mask: 255.255.255.0
Default Gateway: blank
5. Just to be safe, also set the options to "Use the following DNS Server Address"
Preferred: 208.67.222.222
Alternate: 208.67.220.220
(You may use your ISPs DNS entries also, these are just the OpenDNS ones that should work for everyone)
6. Under the "advanced" tab, you need to check "Allow other network users to connect through this computer's Internet connection."
7. Right-click on your wireless connection, go to properties, click the "advanced" tab and check the same box to allow other users to share the connection.
8. On your Xbox360 go to the network configuration menu and enter the following settings:
IP address: 192.168.100.5
Default Gateway: 192.168.100.1
DNS1: 208.67.222.222
DNS2: 208.67.220.220
Now you should be able to get on the internet with your Xbox as it will be using your PC/Laptop's wireless connection.
Jan 04, 2010 | Microsoft Xbox 360 Console
Get router started
Have you tried entering your username and password for your isp provider? You have to enter the config page of your router and enter this information there.
Jan 31, 2008 | Computers & Internet
Adding additional computer problem
Yes, the xp machine connects to the net. DHCP is not enabled. The ipconfig/all command brings up the correct static ip address, subnet mask, and default gateway. But it does also say under the ip configuration that ip routing is not enabled. I did have the 2000 machine connected when I first set up the router yesterday, but I booted up my laptop to try to set up a wireless connection, and then I had to reinstall the entire router set-up.
Jan 12, 2008 | Linksys Wireless-G WRT54G Router
Gateway clean install issues
Re-installing your OS won't help..
Configuring your connections may help
1. Go to control panel.
2. choose network and internet connections
3. click the network connections
4. create new connections.
If you're using an IP addesss, pls. assign an ip address, subnet mask, default gateway, DNS1 and DNS2.
Nov 15, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
