Question about Refrigerators
Fridge timer location
Hi, just looking for the timer location on a Westinghouse, frost free, model RJ442j-q.
THREE DIFFERENT LOCATIONS FOR DEFROST TIMERS ON
MOST REFRIGERATORS.
1 BEHIND THE REFRIGERATOR IN THE COMPRESSOR COMPARTMENT.
2 BEHIND THE TOE PLATE LOCATED ON THE FRONT BOTTOM OF THE REFRIGERATOR.
3 IN THE FRESH FOOD SECTION WITH THE CONTROLS
ON SOME NEWER ELECTRONIC MODELS, THE DEFROST IS
PART OF THE ELECTRONIC CONTROL LOCATED BEHIND A PANEL ON THE BACK OF THE UNIT.
Posted on Apr 01, 2008
I have a Westinghouse frost free fridge with freezer on top.(RJ340M) Freezer part is working great but the fridge is not performing well at all. Thermostat was my first thought but wouldn't that be...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 23, 2010 | Westinghouse Refrigerators
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
Automatic defrost no longer works
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 19, 2009 | Refrigerators
Fridge will not get cold
Was your fridge transported upright at all times? There are warnings on most brands not to lay them down due to potential damage. If that was not the case, those small units are often easy to repair.
[Note to garing: The person said there was no ice anywhere but on the back. Dorm sized refridgerators are rarely frost free, so your answer was pointless.]
Aug 17, 2009 | Haier HSB03 Compact Refrigerator
Not getting cold
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
Would also appreciate if you could provide us the model number of your fridge so that if the above solution does not resolve your issue would look into the matter specific to your type of model.
I am sure this solution would help you to resolve the issue.
God Bless
Jul 13, 2009 | Whirlpool Refrigerators
The fridge side keeps frosting up so that fan wont push air within days of complete defrost
did you change any parts if not you may need a defrost timer .May not be cycling enough to keep your fridge frost free.Most timers are located around light and control housing hope this help:)
May 11, 2009 | Refrigerators
Fridge shorts power out
From your description it sounds like a short in the defrost heater circuit. It would normally be a repairable item. You may want to consider the age of the refrigerator before getting into the repairs.
Aug 24, 2008 | Refrigerators
Westinghouse 522 frost free fridge not switching off on thermostat
stuck timer or stuck thermostat if it has an mechanic timer change the timer first if problem persists, change the thermostat.
Apr 23, 2008 | Refrigerators
Refrigerators Logo
563 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
