Question about Marshall Mg100dfx 100-Watt Combo Guitar Amplifier
One speaker of my MG100DFX makes loud noise similar to a guitar disconnect. When that speaker is disconnected, noise stops. What is the suspected problem?
  • Marshall Master
  • 5,603 Answers
NEVER disconnect a speaker with the power on the amplifier !!!!!! Good way to blow the amplifier.
If the speaker rattles while you are sending audio through it, it is likely damaged. It should be inspected as there are several failure modes, some of which as hazardous to your amplifier.
First test is to gently move the cone and listen for any rubbing of the voice coil. If you hear rubbing, then the speaker needs replacing OR re-coning.
Sometimes the magnet breaks off the back of the speaker.
Investigate this before further use.
Posted on May 15, 2010
Marshall MG100 MG DFX. Full speaker noise with all volume knobs turned to zero and on all settings. When the amp is switched on there is a horrible loud buzz/growl that can only be left on for a split...
well theres only 3 sections of the amp the problem can be in. Pre-amp, Power amp, or speaker. First Unhook the speaker. If you can turn on the amp after that and hear your guitar through the headphone jack this means your pre-amp is ok. at that point you can just take a voltmeter across the 2 terminals of the speaker to see if oyu have 4, 8, or 16 ohms. that'll prove the speakr is good. I'd also try to connect and disconnect the pedal a few times to see if the normals in the jack on the amp are just being stupid. if all this concludes no success, you sir have a power problem.
Aug 31, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
My amp makes a loud foghorn type noise whenever turned on. Even if i have the volume turned all the way down and the guitar unplugged it still hums. I'm not sure if its an amp or speaker prolem. I took...
Likelly the TDA7293 chip in the power amp has failed. It shorts to one power rail and drags the power down where it hums... this CAN damage the speaker if left on. Verify the problem and replace the chip. Slight chance there are bad electrolytic filter caps but those are easily spotted.
Aug 06, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
I have a Marshall MG100DFX. I turned my amp on a few days ago and I heard this loud sound (not the standard hum/buzz that you hear when you plug a guitar into an amp; it sounded more like a foghorn). Now,...
I would try hitting the side of the amp before turning it on. There may be a loose piece of solder or other conductive particle stuck somewhere. Bang the cabinet rather hard with your fist. If that doesn't help it might be a loose solder connection at a resistor or capacitor but a tech should check that out.
Dec 04, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Can i fix one ampli marshall mg100 i had used my bass, and now my marshall have a very estrange noise
Well i know ive destroyed a guitar amp with a bass guitar before :-p this is why they make bass amps and guitar amps instead of just amps
Sep 25, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
I play Gibson USA Sgs, one with 490/498 humbuckers and one with 57classics....The Amp has a loud buzz like feedback all the time on the overdrive channel.
If the amp is quiet with cables unplugged at the same settings as observing the buzz, the amp is OK.
In this case, cables and/or shielding and wiring in the guotar is suspect.
Guitar pickups are sensitive to magnetic fields and you can search out these fields by moving and orienting your guitar to find maximum buzz.
If the amp has objectional buzz with teh cables UNPLUGGED then the amp needs servicing. Filter capacitors among other things are suspect.
Sep 12, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Hi,I turned on my Marshall mg series 100 dfx and there is no sound,just static comes on.Its starts with a kinda bad feedback sound than turns to loud static.
I suspect the power supply for the effects processor has failed. The effects unit will "go crazy" when power supply is too low voltage.
If the amp has loud noise, then the power amp portion is PROBABLY OK.
I had a similar problem in a Behringer amp caused by a bad electrolytic filter cap.
Aug 11, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
No output
There are some possibilities. One, your speaker may be blown or disconnected. Make sure the wiring is still connected to the speaker and if you have one, try measuring the resistance(impedance) of the speaker with a volt ohm meter.Do this unplugged from current and disconnect one of the wires from the speaker or you will get a reading from the output stage. Two if there is a heaphone or line out jack it may have become faulty. If you have sound with the headphones plugged in your amp is still producing sound. Some jacks are designed to interrupt the signal to the speakers allowing you to practice without bothering anyone. If your amp has that feature and you still have sound with the headphones and your speaker tests OK then your problem is the jack. Hope this helps.
Jul 20, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall MG100DFX noisy
Before you bring this into a shop, try spraying out all of the controls. Use an electronics switch cleaner that contains a lubricant. Spray into the control and work the control back and forth a number of times to loosen up any dirt inside. Then spray it again.
Let me know if that resolves the problem.
Thanks,
Dan
Feb 14, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall Mg100dfx 100-Watt Combo Guitar Amplifier Logo
236 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
