Question about Maytag Neptune FAV6800AW Top Load Washer
Leaking watermodel sav205daww code1241b5
After filling with water it starts the cycle,water leaks under wash maachine.
  • 10,319 Answers
A hose has a leak. Remove the top panel and search all hoses for a wet area surrounding it
Posted on May 15, 2010
I have a Whirlpool washer that's leaking water onto the floor. Jason Harris told me to look under the heater i don't know where the heater is.
There is no heater on that machine.
Does the water leak as soon as you start the fill cycle or does it start to leak when the water level gets up to the agitator?
Oct 20, 2012 | Washing Machines
Maytag washer sav205daww leaking water from bottom of washer when runinning
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.Also check on this link : http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Jul 02, 2012 | Maytag Washing Machines
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
Fisher and paykel gwl15 leaking water from under machine. Unknown where leak is coming from. Want to look under machine ourselves before calling in experts.
If it is leaking during fill cycle then it is probably the fill tube. If it is leaking when it drains it is probably the drain hose on the bottom of the drum. If you do not know when or where it is leaking from get a piece of card board and put it under the machine and run the cycles checking the cardboard between each cycle to find out when and where it is leaking from.
Jan 16, 2010 | Fisher Paykel EcoSmart GWL15
Maytag Model...SAV205DAWW leaking water at bottom
there could be 2 things that i know of
first one is that someone bended the door to much and the joint's are eather lose or out of place
the second thing is that the door sealing rubber is out of place, you need to putt it back to place
Dec 27, 2009 | Maytag SAV515DE Top Load Washer
WATER LEAKING FROM UNDER THE WASHING MACHINE
follow the hose from where it connects into the washer.. take off that panel and pinpoint leak. more than likely a hose is unattached
Apr 15, 2009 | GE WWSE5200B Top Load Washer
Kenmore top load washer 110-24642300 is leaking when it fills
tip the unit back and lean against the wall so you can look under it you will see the pump it is plastic. more than likley this is your problem. let me know if you need more assistance
Feb 24, 2009 | Kenmore 22642 Top Load Washer
Water leaking from bottam while in running cycle
water leaking from under the machine while running. Also will not stop filling in the rinse cycle.
Jun 14, 2008 | GE WHRE5260E Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
125 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
