Question about Car Audio & Video
My Philips DVDR5570H is not going past the 'starting' mode. It suddenly went black on the screen and went into 'starting' mode. I followed the instructions as per manual: turned power off at the mains, waited a while, pressed the stand-by/on button on the recorder and turned power back on at the same time. 'Starting' appeared again on the display but no text started scrolling on the display as mentioned in the manual.
IB4G2008
  • 3587 Answers
SOURCE: no screen on starting laptop
remove the battery from bottom, plug into ac power pack, and try it that way
Posted on Jun 01, 2008
toddg
  • 171 Answers
SOURCE: firmware upgrade failure
AREN'T THESE GUYS GREAT. LAME.
It pays to read the directions, completely.
DO NOT UNPLUG, TURN OFF, OR USE ANY OTHER FEATURE OF YOUR PLAYER DURING THE FIRMWARE UPDATE PROCESS. Doing so will cause the writing of the firmware update to the player to be halted and the player may no longer operate properly. If the player stops working, please contact Toshiba Customer Solutions at 1-800-319-6684 or HD-DVD Concierge at 1-888-MYHDDVD(1-888-694-3383).
Posted on Oct 14, 2008
  • 998 Answers
SOURCE: Laptop won't boot (display problems)
If the diagnostics displays on the LCD screen but you get no display when Windows starts to load, it sounds like you have a video software driver problem. Try tapping the F8 key when you power on your laptop and boot in Safe mode. If it works in safe mode then you need to check you driver. You can also try connecting the laptop to an eternal monitor and see what happens.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
  • 3 Answers
SOURCE: Panasonic PT-AX100U-EC
I just repaired mine with some oil for the iris assembly.
The problem is the iris is either slow to respond or doesn't respond to it's controller. The cam should snap back to it's resting point and move freely. It needs to be re-oiled. Mine would move but sluggishly like it was sticky. There are TWO pivot shafts to oil. One on top and one on the bottom. The bottom one can be accessed by removing the bulb. You can see the bottom cam while the bulb is installed. This is a good point to test the iris movement at.
You need to have some mechanical ability. If you don't think you can do this then don't.
First remove the bottom bulb cover. Now get a flashlight. Look in the area that bulb is pointing towards. In the left corner of the side towards the front of the unit where the lens is, you will see a brownish cam. It has a spring around it.
Take a small screwdriver and move it to it's extent like a wheel. Let go and it should quickly return to where it was. It virtually snaps back to it's resting point. Do this several times. 5-6 If at any time it returns sluggishly then it needs to be oiled. 3 in 1 oil works great.
This takes time. I used a small jewelers screw driver to deliver the oil. As you oil it move the cam back and forth to work the oil to the shaft. Standing the unit on edge after you put the oil in the gap helps the oil get to the shaft.
If it now starts to snap back put the bulb cover back on and try the unit. If after 5-6 movements it still does not snap back each time then the actual motor shaft needs to be oiled as well.
Take the top off. There are several screws and one on the back. All have an arrow marking them. The cover is caught around the lens assembly. You have to be a little bit violent to get it off. After the cover is removed, you have to really look for the upper iris cam. It is under the large multi pin connector with brown wires on the main main display board. There is a small perforated metal cover under this connector.
After bending the cover up you will see the linear motor that drives the iris. There is a small flex cable going to it. You need to oil it's shaft. Use the same procedure to oil it as the cam under the unit. After oiling this shaft the iris should now snap back to rest every time. That's it.
Posted on Jan 04, 2009
SOURCE: How to turn off burn-in mode if botton on Monitor
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
Posted on Feb 15, 2009
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
My vimicro android tablet 10
mi tablet turn on but no start window just stay on android sing
May 16, 2012 | Computers & Internet
My display screen goes on and off
I find sleep mode nothing but trouble, eventually corrupts window files over extended use, go into power options, go to stand by and select never and click apply, next go to hibernate "top right" and click, make sure the check box is clear, if not! remove check and click apply and restart your laptop.
Apr 04, 2012 | Sony VAIO Computers & Internet
Philips freevents laptop will turn on but show a black screen
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back. If that doesn't work get back to me...
Feb 22, 2010 | Computers & Internet
Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
Feb 15, 2010 | Sony Televison & Video
Computer won't start.
Boot in safe mode (press F8 when booting and select safe mode)
do a system restore to a few days back
START,, SYSTEM TOOLS ,, SYSTEM RESTORE
or
search it in the seach option in vista..
cause of problem,, driver crash..
Feb 07, 2009 | Brother Multi-Function Center MFC-240C...
Stuck on black screen after login
You have a virus. Go to safe mode and reinstall video card drivers.
Nov 29, 2008 | Computers & Internet
Phililps DVDR5570H only plays zone 4.Is there an unlock code for multizone playback?
Try this:
Models supported:
DVDR3570H
DVDR3575H
DVDR3577H
DVDR3590H
DVDR3595H
DVDR3597H
DVDR5520H
DVDR5570H
  1. Power on the recorder
  2. Wait for player to initialise.
  3. Press [HOME] on the remote control.
  4. Press [PLAY / PAUSE]
  5. Key in 1 5 9 1 2 1 2 1 2 0 0 5 2 5 5 – The numbers will appear in the display of the recorder.
  6. Press [PLAY / PAUSE]
If the recorder goes into browser mode during the procedure, then it will need to be re-started from the beginning.
If at any point the recorder is reset to factory settings, then the procedure will need to be carried out again.
Jul 27, 2008 | Televison & Video
Computer won't stop
Hi ashbadash93,
I have had similiar issues in the past. Try powering it down by un-plugging it from the back of the pc, wait at least 2 minutes before plugging it back in. After 2 minutes, plug it back in and power on the pc. Sometimes this helps.
Jul 26, 2008 | Dell Dimension 3000 PC Desktop
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
Apr 22, 2008 | Samsung SyncMaster 17" LCD Monitor
Car Audio & Video Logo
166 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
