Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore side by side not cooling after a move
The Kenmore side by side is about 5 years old. We moved the side by side on its back. The trip took about 1 hour. We cleaned the coils thoroughly before placing the fridge in the new house. Now it doesn't cool. The compressor is warm to the touch but none of the lines are cool. The fan runs.
  • 1 more comment
  • Inal Mar 30, 2008
    yes, I hooked it up as soon as I got it into the house. When it didn't begin to cool after about an hour I unplugged it again, waited about another hour and plugged it in again. I left if plugged in all night. This morning I'm hearing a click every now and then like it is trying to start up but still is not cooling at all. I do not hear a hum.
    No water is going into the ice maker although I can get water on the door.
    thanks,
    Inal
  • Inal Apr 01, 2008
    I want to thank you for the helpful information. I bought the relay today and my son installed it tonight and the refrigerator is cooling. I was worried that I would need to purchase a new refrigerator which I cannot afford at this time. Thank you again for the help.
  • robert samples May 11, 2010
    are you hearing a hum and a click from the compressor and did you hook it up soon as you got to the house
    President:
  • 1,314 Answers
Go to the back of the fridge see if it has a white relay on the compressor that's the piece that plugs onto the compressor if it does un plug the unit take it off and shake it if it rattles and little black stuff falls out of it replace it with a three in one relay from an appliance repair parts store just follow the instructions on the part its easy don't worry about water in the ice maker it will fill when it starts cooling if it doesn't have the relay try turning it off for 24 hours to give the oil time to run back down to the compressor and advise me further
Posted on Mar 30, 2008
  • robert samples Apr 01, 2008
    hey that deserves a four box fixya dont ya think lol
I have a KIC 223l. I moved into my residence yesterday and its not cooling. The moving took 5 min while it was lying down. I immediately switched it on when i got into my room. Its been on for less th
Hiya, u should leave a fridge and freezer after moving it at least 24 hours before switching it on because the gases need to settle. If it has been switched off perhaps you need to check the plug just in case the wires have loosened. hope i was of some help to you kind regards
Feb 11, 2012 | Refrigerators
The refrigerator is approx. 4 years old (side by side model). It was recently moved 100 miles. It was working fine in its old location, moved it 100 miles and now it does not cool or freeze. The lights...
if you laid it on it's side you could have damaged the sealed system.the machine has to be standing upright just like when it's in your kitchen or the compressor can get damaged,if you stood it back up and didn't run it for a few days the oil might go back down into the compressor but if it was moved on it's side and started most likely you damaged the compressor,or a wire or something got knocked off while moving it if it was moved correctly.is the compressor running?
Apr 13, 2011 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Northland side by side AND a stand alone freezer.. both alternate going warm.. I move all the food to the one working.. and unplug the bad one.. after 24 hours..plug it back in and it cools perfectly,...
Are these the built-in units with the power module on top? If so, it sounds as if the defrost mechanism is bad (i.e. timer or heater or bi-metal limit). How old are the units? Still under warranty?
Sounds like you are getting ice build-up in the evaporator which lowers the cooling capacity and causes the unit to run alot if not continously with little to no cooling.
You can get further troubleshooting assistance by calling the factory at 800-223-3900.
Jun 16, 2010 | Refrigerators
I have a Kenmore Refrigerator that a friend just gave me that is about 5 years old in good condition. On the move we didn't lay it on it's back, but of course it was tilted back at times. Transported it...
How long have you let the unit run? Sometimes if you leaned it back too far you need time for the oil in the compressor to recess..to go back into the compressor. It normally takes a refrigerator 24 hrs. to cool but also up to 72 hrs. if after three days of continous run and not cool at all then you have a restriction in the system, in this case oil in the lines or a stopped up liquid line dryer. It's a filter for moisture and impurities in the closed system. Otherwise give it time to cool without putting the settings all the wayup. Put them on the factory settings usually in the middle of both knobs or whatever you have for adjusting the coolness. Overheating the compressor will not cool the unit and you might try shutting the unit down for a day and then resume again the next day at middle or lower settings. Make sure never to lay a refrigerator over on it's side! The life of a refrigerator should be up!
Randy
A.I.R. Appliances
San Antonio, Tx. 78209
210-822-1818/210-493-2700,cell 210-264-1471
Feb 24, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore 19365
If you are asking how to drop the feed dogs, the lever is located underneath the free arm bed on the back side of the machine. So you must first remove the free arm bed. To drop the feed dogs, push the lever over to the side. To raise them back, push the lever the opposite direction, back where they were originally. You will not actually see the feed dogs move until you turn the handwheel toward you. I hope this helps. I do not know how old your machine is or anything. I believe mine is about 5 years old or so. Good luck
Oct 02, 2008 | Kenmore 19365 Computerized Sewing Machine
Freezer and refrigerator run but is not cold
unit has reached its life expectancy. tilting causes oil to move into the condenser and is damaging in itself, newer units can survive moving, but when you expect both units to recover,i have to recommend replacement
Apr 07, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Moving a whirlpool side-by-side
just do not crush any cooling lines in the rear of it.
I would put foam rubber or styro foam in the bottom around the compressor if it is a very bumpy ride.
When you get it to it's location, do not plug it in until it sits upright at least overnight so the freon can settle.
Mar 21, 2008 | Refrigerators
Andeb, couple of things you want to check. Is the fan in the freezer section running? Take the lower back panel off and see if the condensor fan is running as well as the compressor. As long as you tilted it only slightly I would think this is a fan or overload relay problem. Check the things I mentioned and post back...Catriver.
Aug 21, 2006 | Kenmore 50522 / 50524 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
108 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
