Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
MF Tractor 265 diesel engine fuel problems.
Tractor: Massey Ferguson 265 Diesel Engine: It has been dieing on me regularly since it ran out of gas once. I bled the air out of the lines according to repair manual, it works for awhile running well with no hesitations nor miss firings and then dies again. I pump the fuel lift pump by hand to bleed the system of air and now I get no air or fuel coming out of the air vent plugs, even after a couple hundred pumps. I tap the engine from time to time to reposition the fuel lift pump acuating lobe until I get good resistance in the priming lever. Still no air nor fuel coming out of the air vent plugs. Yet tomorrow I could try again and get air, then fuel coming out. I just changed the fuel filter and gaskets, and the tractor was running after doing so for about 15 minutes. I could use some suggestions at this point. I am new to diesel engines.
  • Anonymous Mar 31, 2014
    changed fuel pump didnt help is pumping gas
I ran into the same problem and found the line to the tank was clogged, take your line loose and see if your fuel flows freely if not blow some air from a compressor back up the line and into the tank. Hope this helpls
Posted on May 29, 2010
  • Mike Holmes Sep 13, 2013
    This is most likely your problem, after you clear your fuel lind from whatever, drain your tank out and remove the crud from the inside of your tank or this will happen again and do not run out of fuel again
I had this problem with a 135. I tried all usual things problem turned out to be contamenated fuel. Bought another tractor changed fuel storage tank and fuel supplier. No problem for last year or co.
Posted on Apr 22, 2011
How do you wire Massey Ferguson 230 diesal ? With 3 wire delco alternator. Along with oil pressure switch , ammeter, neutral safty switch, fuel,water. 12 volts.
    mages for wire diagram Massey Ferguson 230 diesel
    More images for wire diagram Massey Ferguson 230 diesel
    230 MF - wiring diagram - SSB Tractor
    www.ssbtractor.com/wwwboard/view_all.cgi?bd=massey&msg=10416
    Allen Stewart, I need the wiring diagram of the dash area. Does anybody have this? Allen Stewart, wiring diagram is needed for Massey Ferguson 230 diesel.
    [PDF]MASSEY-FERGUSON - MyeDocs.com
Jan 01, 2016 | Toys
WHERE CAN I FIND INFORMATION FOR A YEAR OF A MASSEY FERGUSON MF 40 WITH A SERIAL NUMBER 9A 277334. THE HOOD IS STICKERED WITH MF 40. IT HAS A 4 CYLINDER DIESEL IN IT. THANK YOU.
this tractor was produced in the years 1972 to 1977 and production was finally stopped due to it not having roll over protection , although many were retro fitted with a hoop later last years of production so depending if you have a hoop over the operator seat or not would narrow down your production date
Nov 12, 2015 | Diesel Toys
255 massey ferguson tractor diesel empties into oil pan when tractor sits diesel tank goes empty oil level goes over the hi level just about to the top of the stick.where would you look first?
my 135 fuel supply pump was leaking into the engine . I removed the pump pressured a line with air and found the leak at the seal
Apr 03, 2015 | Diesel Toys
Hi we have a Massey Ferguson Dyna 4 5465 and it was working this morning and then it died we started it up and it ran for about 1/2 a minute when we try starting it now we can hear the fuel pump runs for...
am i to assume its a diesel ,if so sounds like its out of fuel but i could be wrong as its been many years since i have worked on tractors and all the fancy electronic gizmo on modern vehicles can confuse me.Now firstly check the key as no doubt as its a modern one it has a immobilisor and if the head of key loses its chip inside the key head it will never start unlike the old ones that would run on paraffin diesel or petrol ,the later ones were diesel only but again providing they had fuel and oil with the rad topped up they ran 24/7 ,thats a point check the oil level if its low it may stop the engine from starting
Jan 18, 2015 | Garden
Trying to find out what year a Massey ferguson tractor is the serial # is 9 A 108154
1971 and appears to be one of these models. Massey Ferguson Model MF-135, MF-150, MF-165, MF-175 and MF-180
Mar 06, 2014 | John Deere Tractor 1020, 1520, 1530,...
Ferguson tractor misfiring
fe 35 23c engine,the diesel feed pipe to the heater plug still drips fuel in the inlet manifold when runnig causing it to splutter is this normal.
Jan 16, 2011 | RTO Massey-Ferguson Tractor TE20, TO20,...
What kind of oil goes in a Massey Ferguson Tractor gearbox?
What model tractor - MF130/135 diesel takes 10/30 not gear oil for transmission/hydraulics
Jul 18, 2009 | Puzzle Massey Ferguson Tractor
Need a wiring diagram for a massey ferguson 135 tractor
I need a wiring diagram for my massey ferguson 135 tractor regards ****
Mar 24, 2009 | RTO Massey-Ferguson Tractor TE20, TO20,...
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
2,016 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
