Question about Gateway M275 Tablet PC
Can't get microphone to work with Jing
I used to be able to plug in the headphone with mic, turn on Jing and record just fine. Now I can't get my voice recording. I've tried the troubleshooters and the voice recognition and managed to get some results by using the webcam mic, but still don't get my voice using Jing - just static.
How do I activate my microphone on my samsung galaxy tablet
reset settings,,,otherwise mic should be change by an expert,,,or use headphones
Mar 14, 2015 | Samsung Galaxy Tab S 8.4" Tablet - 16GB,...
Microphone on my iPad 3 with ios8 not working
Try recording using the voice memo to check the mic if you can then mic is working if not then either downgrade your ipsw to the previous firmware if you are sure it stopped working right after the software upgrade or replace the mic
Mar 07, 2015 | Apple iPad 32 GB WiFi Tablet PC
Static noise
Try connecting an external mic while recording. If it works fine, there may be a probem with your mic
Dec 28, 2013 | Samsung Series 7 Slate Pc Tablet Windows 7...
Nexus 7 tablet mic doesn't work in portrait mode
The microphone for the nexus 7 is a small hole on the right hand side of the tablet, just below the volume button. Make sure your hand and any cases you're using aren't covering this when you're trying to do a voice search.
Apr 10, 2013 | Google Nexus 7
Toshiba Satellite 1905
First, try pluging in an exteral mic to check the mic itself is not broke. Next Go to the device manager to check for driver problems (control panel, system, Hardware look for yellow ?'s) Check control panel, Sounds and Audio, audio, sound recording, volume. There are just too many ways to mess with the sound settings, and they often seem to just mute themselves!
Good luck
Mar 17, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Turn on mic
I read the question and i suggest that if the notebook has inbuilt microphone then the mic is already enabled if u have installed the proper drivers but if u plug in external mic then check the pin and socket of microphone. if this does not work go to control panel and then sound and then check the microphone
Jan 23, 2008 | Acer TravelMate C110 Tablet PC
Screeching noise
right click on the speaker icon in your taskbar, select Open Volume Control. If you do not see the Microphone control select options>properties and select it from the list of check boxes. Press OK. Check the mute box for your microphone.
Jan 04, 2008 | Lenovo ThinkPad X60 Tablet PC
Audio feedback
this maybe was cause by a grounded connection.
Please try put a grounding wire from your stuff to the ground. this elimanate noise.
if this not work, do not rate me instead notify me for another solution im online 12 hours day.
Sep 13, 2007 | Acer TravelMate C110 Tablet PC
Gateway M275 Tablet PC Logo
133 people viewed this question
Top Gateway Tablets & eReaders Experts
ashburton
Ricky Ostrom
Ricky Ostrom
vojvodabudva
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
