Question about Encore Software Kawasaki Jet Ski Watercraft for Windows
PlZ PLZ HELP kawasaki jet ski with fuel issues
96 kawasaki 750 zxi that will run while gas is poured in carb. Once this is done the pump case will fill the fuel filter up but once the gas poured has started the ski and the gas in the fuel filter is used, the ski will shut down. I have taken the line off and blew inside it to check for restrictions, bu none noted. The line will fill back up once the filter is lowered to fill the container the filter sits in, and I can repeat this process with the same results each time. I cannot get this ski to run and need some help
Hi, i have a problem with my ski running it has a low end flat spot and wont idle properly it keeps stalling any help appreciated
Posted on Sep 08, 2011
    President:
  • 1,978 Answers
Take your carburetor apart and clean it. There is moisture corrosion that is keeping the needle from moving. Be careful not alter the little teeter totter spring in any way.
Posted on Sep 03, 2010
TROUBLESHOOTING FUEL PROBLEMS
carbs clean and checked the fuel pump diaphrams not gone hard etc ?? tank and fuel clean and fuel getting to carbs ?? pulse pipes on intake manifold to pump clear and if you crank engine you feel a pulse of air ? plugs sparking ? i would fit a fuel primer bulb inline of feed to carbs and prime fuel and see if helps and as engine running see if priming keeps it running then i would check pump !!
Aug 25, 2014 | WSM 2002-2005 Kawasaki Stx-r 1200 Cc Jet...
After seating for 3 years would not run
clean injecters and replace fuel ! compressions 100psi or more !?? sparks on all 3 cylinders ?
Aug 25, 2013 | WSM 1996-2003 Kawasaki Zxi 1100cc Jet Ski...
What are the flywheel torque settings for a 1998 kawasaki jet ski 1100 zxi?
You might want to post this question in a different section. This is the computer games section.
Aug 22, 2012 | Encore Software Kawasaki Jet Ski...
Jet ski bogs out under load.
I had a similar experience with that model. It turned out to be a mouse nest in the water box. However , in this case i think you just have some moisture corrosion on the rubber tipped needle in the carburetor. Clean that part of the carb and do not alter the tiny spring in any way. If that does not work open the electronics box, if it is wet , dry it out , and seal it back up. Those are the three things I know of that will cause your problem. Start with the carb.
Apr 06, 2010 | Encore Software Kawasaki Jet Ski...
I have a 1995 kawasaki zxi the bolts on top of
The numbers on the head are the torque pattern/order. Two stroke motors generally use a torque value of 18 to 22 foot pounds on the head bolts/nuts.
Feb 01, 2010 | Encore Software Kawasaki Jet Ski...
Jet Ski Won't Start when Engine is cold
You must take out completely the carbs and clean them especially their canisters with the flowters.They may have jelled gas inside or closed air pipes.Use a carb cleaner spray and compressed air.
May 25, 2009 | 1990 kawasaki ZXR 750
Jet Ski Will not start when cold
If the teeter/totter needles are gummy or covered with moisture corrosion it could be the reason the machine is so hard to start. When storing the jet ski's syphon all the gas out and burn it in your car or truck. Even if you stabilize it it wont be good fuel in the spring. Your plastic tank will not rust so remove the fuel. You may be able to clean them up by running a tank of Chevron Techron through them. Before riding we charge are batteries and start are jet ski's on the trailer/lift before dropping in the lake. This saves the battery. It takes more juice to start the boat in the water.
May 25, 2009 | Encore Software Kawasaki Jet Ski...
Encore Software Kawasaki Jet Ski Watercraft for Windows Logo
921 people viewed this question
Top Encore Software Video Game Consoles & Games Experts
James Wishart
Are you an Encore Software Video Game Console and Game Expert? Answer questions, earn points and help others
