Question about Nikon D90 Digital Camera with 18-105mm lens
Aperture doesn't appear in my view finder, the f-- blinks and i can't adjust it. what should i do to make it work? i tried switching it to manual and it still blinks. whats the quick solution for this?
  • kakima May 17, 2010
    May I assume this is happening with the 18-105mm lens? If so, try cleaning the electrical contacts on the back of the lens and in the mount on the body. Does this make any difference?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Having gone over a month with no response, I assume this is no longer a problem.
Posted on Jun 21, 2010
I cant see through the Viewfinder its just all black but i can see on the led screen and i can switch the display to he view finder and see it fine , so is the viewfinder broken ?
It is not likely the view finder is broken, because it is deep inside the camera. There can be many reasons why you can't use it as it should. Did you know you can adjust the brightness of the viewfinder and the display separately? It is in the manual page 31. And if you are with the manual (still online available) have a look on page 16 too.
When the camera does not give the image to the view finder, it also could be an electronic problem, because switching in the camera goes along electronic paths.
Jan 19, 2014 | Canon PowerShot Cameras
Tip
How to manually adjust the aperture in video mode on the Nikon D90
When working with a AF-D type lens mounted on the D90, you can manually adjust the aperture during video production. In order to do this, lock the aperture at f/22. Turn on live view. Once in Live-View mode, you may unlock the aperture and adjust it during video-taking. You may NOT take a still image when doing this. This feature creates very pleasing videos with out-of-focus backgrounds, and is a very useful tool.
on Dec 10, 2009 | Nikon DSLR D90 Digital Camera
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
I just put new batteries in my N65. I haven't used it in a while but it appeears to be working proper, ie the lcd comes on and indicates full battery and the view finder symbols are nice and bright green...
What I'm thinking is the shutter and or the aperture ring is lazy. Move the aperture ring up and down several time see if the little ring next to the the camera body is responding quickly to the change.
Do this without film in the camera.
What I'd suggest is setting the camera in "M" mode aperture at F8 manual set the ISO at 100 and the shutter speed at 1/60 shift the camera into manual focus. The shutter can be in AF-S (single frame with each depress of the shutter). Trip the shutter and listen to it work do that a few times (maybe three) then set the speed at 1/125 do the same test listen the shutter should sound faster. Repeat the test at 250 then 500 then 1000. Then start backing down to 1/60th again, listen to the response. In all manual mode the shutter has to fire it it isn't or the speed doesn't increase and then decrease then the shutter needs service.
Jan 14, 2011 | Nikon N65 35mm SLR Camera
Trying to use the telescope but cant see anything
Hi, this is a real handy scope. You need to remove the disk like cover for the high polished mirror located at the but end of the scope. Then insert one of the two ocular lenses provided into the viewing aperture. Next, aim the polished mirror end at something obvious like a street light. Use the range finder located opposite the viewing aperture, (switch red button on) and align the circles with the red dot. Happy viewing!
Nov 16, 2010 | Celestron AstroMaster 114 AZ (50 x 114mm)...
Dark View Finder?
The short answer is check the aperture. If the aperture is to high (it's using a big F Stop) it will slow down the shutter speed.
Jun 27, 2009 | Sigma Cameras
Manual Exposure mode Nikon F80
1) turn the mode switch/knob on the left of the camera to M ( manual mode ) 2) turn your lens to the highest f-stop ( 22 or 16 depending on your lens ) 3) in front of shutter release button you have control for your aperture : turn until the desired aperture is displayed ( view finder or the LCD monitor on the top ) 4) your shutter speed setting is controlled with your thumb with the control situated next to the strap lug on the right hand side of the camera. 5) press shutter release half way and look through viewfinder and see light meter reading and adjust either shutter speeds or the aperture as explained being guided by the l.meter.
Sep 23, 2007 | Nikon F80D 35mm SLR Camera
Dark view in view finder
Sounds like a lens diaphragm problem ( lens stays closed down to F16 and that is why you have a dark viewfinder ). Remove lens and see if you can activate the aperture mechanism via the activator which protrudes from the rear of the lens. You should get nice and brisk action from the aperture . If the movement is sluggish or the lens stays fully closed then your lens needs attention.
Sep 15, 2007 | Nikon N75 35mm SLR Camera
My Minolta Maxxum 3Xi has a dark picture in the view finder. It won't focus on anything because everything in the view finder is dark, if not completely black. I was told it might be the aperture ring. ...
The aperture ring is the right diagnosis. The aperture mechanism has a broken piece that can be repaired by a competent repair shop for under $75. There are no parts available for Konica Minolta cameras since Sony bought them - the part can be rebuilt.
Oct 22, 2006 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Aperture Priority Mode - an undocumented feature
In addition to the "quirks" of the Landscape and Aperture Priority Modes (neither mode works as documented!)..... The camera also behaves differently in full Manual Mode (it changes the settings, whether you want it to or not to compensate for available light)... At lower Zoom Levels, the camera will adjust the Shutter Speed Only, to try and compensate for available light... For example: with the Camera preset to F5.6 Aperture, and 1/48 sec. shutter speed, the camera will adjust the shutter speed between a range of 1/30 to 1/291 sec, to try and "auto expose" the shot for lower or higher light levels, even though you're in manual mode. At an Aperture Setting of 2.8 and 1/48 of a second, the number of internal steps in shutter speed the camera is willing to take, increases dramatially - for example: shutter speeds up to 1/600 of a second, even though you have the shutter set to 1/48 in manual mode. The camera WILL NOT attempt to adjust the Aperture to compensate for proper exposure in available light (OR WILL IT??).... It depends on your Zoom settings! It won't if your're near to full wide angle, but IT WILL if you are using the Zoom. Once you cross some unknown zoom threshold (it doesn't have to be at full zoom), then the camera begins to change both the Aperture and Shutter speed to compensate for available light, even though you are in "Full Manual", versus Auto Exposure Mode. In Manual Mode, (as in Aperture Priority Mode), the amount of change the camera is willing to make to your settings, appears to be related to a preset number of internal steps, with the number of steps dependent on both Aperture and Zoom Settings, before it gives an EV Warning for Over or Under Exposure conditions.... The type (shutter speed only for wide angle, shutter and aperture for zoom) and amount (number of internal "steps" it takes to increase/decrease shutter speed and increase or decrease aperture), is dependent on the amount of zoom you are using for the current shot.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Nikon D90 Digital Camera with 18-105mm lens Logo
62 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
