Question about HP Pavilion dv4000 Notebook
How to remove battery on motherboard on hp pavillion dv4000
    Genius:
  • HP Master
  • 1,354 Answers
Hi
which bettery u wnat remove
if u looking to remove cimos bettery then in this model you have to open from the keybord penal if you well noon in this then only
or go to technition
Posted on May 15, 2010
The bluetooth for my HP is gone
Click "Start" and type "wireless assistant" into the search box.
Click the "HP Wireless Assistant" entry in the list of results.
Locate the "Bluetooth" entry.
Click the "Turn On" button in the "Bluetooth" category to enable the Bluetooth antenna in your HP Pavilion.
Hope this helps
Oct 24, 2012 | HP 403895-001 PAVILLION DV4000 V4000...
Hello, i have hp pavillion 4 laptop but when i power it the caps lock and num lock keys keeps blinking and the display screen is also blank.
This is a very common problem & it affects the Hp dv2000 , dv4000 , dv6000 , dv9000 series of laptops . In almost all cases this is caused by the video card overheating . There are 2 options , one is replace the motherboard ( expensive ) , the other is performing a " reflow " similar to how xbox 360's & ps3's are repaired . After the " reflow " you should replace the thermal paste with Arctic Silver #5 & I clean out the heatsink & fan before replacing them . Good Luck if you attempt the 2nd solution , I have done it about 20 times so far only 1 failure .
Apr 16, 2011 | HP Pavilion dv4000 Notebook
Is there any sata slot available on HP Pavillion dv4000 laptop, i mean can i install a sata hard disk in my hp Pavillion dv4000 laptop?
hi this depends on the age if it is older than 3 1/2 year old approx, then you maybe able to put one in, other than that the easiest way to find out is to take the old one out, just look at the back end where it connects to the board, if it has pins in the back its ide if it has just a line of contacts then its sata...hope this helps
Jun 05, 2010 | HP Pavilion dv4000 Notebook
I have a HP Pavillion DV4000 and it does not charge
pls check if it runs ok during power supply AC and also check Battery contacts on both side laptop side and battery contacts see if rust or residue is sticking there try to scratch it out by some rust removing cream or something normally it happens other wise if the adapter supply is ok AC one then ur battery is faulty try replacing it there is a battery checking utility on HP support software try it , i think it will help u cjeck the batt
pls rate me if i fixed it
Feb 27, 2009 | HP Pavilion dv4000 Notebook
HP Pavillion dv4000 cto won't start
Hey,
if the computer doesn't beep at all, and noting comes on the screen.
Lets do this first,
Remote the ram from the computer, start up without ram.
turn the laptop off and unplug, did you hear beeps?
Place the other memory module back in and try starting up.
if the computer starts up then all is ok you can plug in the other ram and start up again. if it doesn't start up then repeat the previous process.
if this has no effect and you don't get any beeps from the computer the motherboard most likely has a problem.
I would suggest you call hp or your dealer to check your warranty.
If you are outside of warranty the repairs will cost you.
Discuss repairs with hp and see if its worth it.
Let me know if you need anything else.
Thanks,
Ekse
Feb 16, 2009 | HP Pavilion dv4000 Notebook
Faulty Connection
I have HP DV6000, I used it without the battery. it worked until I was able to purchase a new battery. It might work on the HP dv4000...
Jan 05, 2009 | HP Pavilion dv4000 Notebook
HOW TO REPLACE HP DV4000 MOTHERBOARD
Check out the manual, located here:
http://h10032.www1.hp.com/ctg/Manual/c00530488.pdf
Check under the Removal and Replacement Procedures section.
Replacement for the Full Feature Motherboard can be found here:
http://www.getpartsonline.com/396696-001.html?source=googlebase&code=396696-001
Nov 25, 2008 | HP Pavilion dv4000 Notebook
Pavillion wont work with battery
First, I recommend you to try removing and reinserting the Battery when the Notebook is turned on and powered with the Power Adapter.
I recomend you to first clean the Battery Connectors by removing the Battery and use a Earbud to clean the Metal Connectors which connect to the Battery to remove any dust which is peventing from the Battery to supply the required power to the Notebook.
You can find some related topics related to troubleshooting issues related to Batteries in HP Notebooks from the links below :
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00485351&dlc=en&lc=en&jumpid=reg_R1002_USEN
Additionally, you can download and install HP Battery Health Check SP3229.exe and check the status of the Battery by following the instructions.
Hope this helps...
Aug 27, 2008 | HP Pavilion dv4000 Notebook
Pavilion dv4000 microphone
sorry no build in microphone use ext....
Apr 28, 2008 | HP Pavilion dv4000 Notebook
Halecol
1)try to check also if you'll see a solid GREEN LED light on your ac adapter.if yes, possible problem could be on the battery port or the battery itself
2)With regard to the battery meter,where did you find that?If not in the BIOS,try this.restart computer and press F2 several times .Once you're inside the BIOS.try to go to the battery option-try to see if the battery indicator would say 100% also.
3)if 100%,try another battery if you have one.use only the battery as the only source of power..if a known good battery works then the problem is with your old battery.if a known good battery won't work,that would mean that you have a problem with your battery port.if that is the case, you may have to replace your motherboard for that but if you still have an active hardware warranty on your pavillion dv 4000.try calling the manufacturer for a motherboard replacement and try asking also if your battery is part of any recall.
4)if the battery meter in the BIOS does not say 100%, try charging the battery for an hour then go back to the BIOS try to see if the battery meter would go up.if it increases the battery meter try using the battery as the only source of power...if nogo,go back procedure 3.
Jan 17, 2008 | Computers & Internet
HP Pavilion dv4000 Notebook Logo
97 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
