Question about Sanyo 52 ROBUST LCD MONITOR CE52LH1R LCD TV
Red lines on the picture - Sanyo 52 ROBUST LCD MONITOR CE52LH1R LCD TV
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Red lines are taking over
possible your tripler control is going out .This part splits the high voltage from flyback transformer into 3 high voltage leads to feed to the three picture tubes .The side for the red is likely to go out causing red picture tube to overdrive in red retrace lines..That or RED CRT BOARD is bad
Dec 06, 2007 | JVC AV-48WP74 48" Rear Projection...
Red lines, blurry picture
try this link. It fixed my sony.
www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 29, 2009 | Sony KP-51HW40 51" Rear Projection...
Turn on pic turns red with thin bright red horizontal lines
Sorry to say, but that's usually the sign of a bad picture tube. One of the elements inside the tube shorts and you see the picture you describe, and the set shuts down due to high voltages getting to places it shouldn't. There's no solution except picture tube replacement, and that is uneconomical. You're better off replacing the TV when the tube goes bad.
Mar 31, 2009 | Toshiba Televison & Video
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
My screen have some red lines
I will assume from you description that this is a rear projection crt(picture tube) tv. if this is true I have good news/bad news.
faint red horizontal bowed lines in the picture indicate the screen(G2) voltage for the red tube is too high.Slight lowering of the G2 adjustment will eliminate these lines. I stress SLIGHT because too much adjustment will mess up the gray scale .
The bad news the red crt made be bad. if the adjustment works but in the future the problem reappears then suspect the red crt.red crt replacement is probably not economical to repair.
Jun 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red diagonal spottted lines
These are called retrace lines they occur because of the blanking pulse not turning off the electron guns in the picture tube during the retrace period. Since this is occuring with the red gun there may be a proble with the video circuitry connected to the red electron gun of the picture tube. This would include the red amp and the red driver transistors. You will need a schematic and a multimeter to properly test these items.
Aug 03, 2006 | Sony KV-36XBR400 36" TV
A horizontal or vertical red line appears on picture.
Red lines are caused by glare. Avoid photographing shiny surfaces that reflect excessive amounts of light into your lens.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Sanyo 52 ROBUST LCD MONITOR CE52LH1R LCD TV Logo
52 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
