Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
My icemaker makes very little ice and the water is horribly slow. I don't know what to do. Please help.
  • 401 Answers
CHECK YOUR FILTER IF IT IS NEWER. YOU MAY NEED TO SHUT OFF YOUR WATER SUPPLY VALVE TO THE REFRIGERATOR AND THEN OPEN IT BACK UP THIS WILL CLEAN THE HOLE. IF IT IS A SELF PIERCING VALVE YOU SHOULD REPLACE IT FOR A 1/4 INCH VALVE.
Posted on May 15, 2010
Icemaker is slow in producing ice
If your icemaker is producing ice, but it is slow, there are 2 likely explanations.
1. Temperature. Water freezes at 32 deg, but the icemaker won't eject the ice until it gets below 10 degrees. If you always had good ice output and all of a sudden it has slowed down, you're temperature is a little higher than ideal. Check for a door seal not making good contact or try dropping the temp in the FREEZER side a couple degrees
2. New model. Most new refrigerators make ice much slower than older models to meet energy efficiency guidelines. This is not a repairable issue.
May 25, 2012 | GE Refrigerators
My Ice maker in my 2 year old samsung rf267 Space Icemaker quit making ice. I don't know why or how to get it to make ice. The "ice off" isn't the reason, nor the lock. I did hear a slow...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 19, 2011 | Samsung Refrigerators
Amana scd25tl is making ice poorly...very little ice... bucket is about 30% full in the morning, makes very little ice during the day, freezer is set to number "6"....7 being the coldest...
NOTE: This
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Aug 07, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
Our Maytag icemaker stopped making ice suddenly after we changed the filter. It dispenses water only.
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
Aug 20, 2009 | Maytag MSD2732GR Side by Side Refrigerator
All water underneath.ice in the bottom.freezer working.not making
If I understand you correctly your water line that comes through the back wall of the freezer and into the icemaker is frozen. If so you have a bad water valve. When the valve goes bad it will not seal off the water. It will seep causing a slow drip where the water comes out at you icemaker. It'd slow enough to freez causing a ice blockage. This will not allow water to come through and fill your icemaker when it calls for water.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker maker horrible noise when activated
take out your ice bucket and clear all frozen water out of it only cubes should be in there if you have had a drip for several weeks you may have a big chunk in there possibly wrapped around the screew
Feb 26, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker stop making ice
I had the exact same problem after looking at the ice maker I saw that there was a test button I pressed the button and it started working again
try that!!
Dec 28, 2008 | LG LRSC-26922 Side by Side Refrigerator
11 year old amana frig icemaker
you most likely have a short in the ice maker ..the ice should be ejected before the water is call for... you need a new ice make or if you can change the ice maker head let me know and I can help
Jun 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Kenmore - Ice Maker Not making much ice
check water inlet valve on your frig
Nov 06, 2007 | Refrigerators
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
102 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
