Question about Vizio GV42L 42 in. LCD Television
How do you switch to cable without remote
  • Vizio Master
  • 12,061 Answers
On the Unit itself, are Buttons, up to seven, 7, of them, usually, ON/OFF, MENU, Channel Up, Down, Volume Up, Down, SELECT/ENTER, Nearly ALL functions available on the remote can be performed via the buttons on the TV. Simply choose menu, and Step through with the Channel & Volume keys, and "Selecting" with the select/enter key. www.scribd.com/doc/.../VIZIO-GV42L-HDTV-Service-Manual
static.compusa.com/pdf/GV42L_HDTV_User_Manual.pdf - United States
Above are your User manual, above that is a service manual.
Posted on May 15, 2010
Switch from antenna to cable without a remote on apex digital mod at 2704s tv
You can't select its inputs without a remote control. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 09, 2014 | Apex Digital Televison & Video
It is the powertype plugs that plug into the mains circuit not my router flashing but now both plugs are showing green but youview box not responding
I am sure you have tried this, but if not give it a go:-
Switch off both powerplugs and leave for 5 minutes..
Switch on the powerplug nearest the router without the LAN cable installed.
Wait for 2 minutes and switch on the other powerplug without the LAN cable being attached.
Now wait for another 2 minutes before plugging in the LAN cable
Now plug in the LAN cable at the router end.
After about 2 minutes, plug in the LAN cable at the remote end.
Good luck.
Jun 07, 2014 | NetGear DG834G Router
Truck will not start how can i tell if its a starter or selonoid
does it spin real fast without clanging and grinding against the flywheel? if so then its probably the solenoid bad. do you have to hit the starter with a hammer then it works? it is probably bad brushes or a worn motor. eather way i think you can only get a new starter and solenoid together not sold seperate. check for bad battery cables (loose).
May 30, 2011 | 1996 Chevrolet K1500
I have a Sansui SLED 2280 that I'd like to use without cable input. How do I switch to regular over the air (no cable) antenna? Thanks
To switch from cable to air or vice versa on most Sansui flat screen tv's including the SLED2280, go into the menu. Select "channel" on the screen. Press "enter" on the remote. Select "auto ch mem" on the screen. Press "enter" on remote. Select "signal type" on screen. Press right arrow button or right volume button on remote to change signal type (cable or air). To program channels into tv, select "automatic search" on screen then press "enter" on remote. Wait for search to finish.
I hope this helps you.
Bobya
Dec 19, 2010 | Sansui Televison & Video
Battery dead.when i try to boast the car alarm goes off and i can"t turn it off without removing boaster cables
Try manually disarming the system when you hook up the battery cable. After you hook up the cable ( the siren will be going), turn ignition on, press and release valet switch one time. The siren will stop and you will be able to start the vehicle. Test the remote. If the remote is not working, and the battery is good, try reprogramming the remote. Turn ignition on, press and release valet switch one time. Press and HOLD valet switch, press lock button on remote. You will hear a confirmation chirp when the remote is programmed. Turn ignition off. Test system.
Nov 21, 2010 | Remote Start System
Need to know how to switch from air to cable w/out a remote for t.v.
I purchased a switch box from radio shack to switch my components. But, you have to get up and press the switch. I'm afraid there is no real easy way to do that without either doing it manually or using a remote. You can program a universal remote so it will change the input if you are missing a remote. Good luck!
Oct 10, 2010 | Insignia Televison & Video
My cable tv remote will turn this unit on with the codes supplied for the remote. But the remote will not control the volume or turn the unit off. Is there another code, or is this a problem with the cable...
There has to be another code and when you find it you will probably have to "lock" your remotes volume control to your audio device not the cable box (set-up that way from cable co) once you do that the cable box will be controlled from the remote(channels) and the audio will be controlled by your receiver from the same remote without even having to switch functions.. ask your cable company for a setup guide for your remote they will probably have a copy online.
Nov 27, 2009 | Onkyo TX-SR606 Receiver
I need to switch my tv to input without a remote
Hi
please use the menu button in your front panel then search the video, Air, or Cable selection!
Thanks!
Apr 10, 2009 | Sanyo DS27820 27" TV
Magnavox TV accessing menu without remote
There may be away but need the model number to narrow it down, most remotes can be found at www.vancebaldwin.com and for usaly under $20.00
Feb 13, 2008 | Televison & Video
Would like to switch tv mode to cable mode
go to the menu button,press it, in menu service you to choice either air or cable. then select the cable
Nov 06, 2007 | JVC TV-13142 13 in. TV/VCR Combo
Vizio GV42L 42 in. LCD Television Logo
330 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
