Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Uniden 6.0 answer/base/ cord less message set up
Uniden 6.0 answer/base/ 3 handsets cord less out going message set up (got no manual with it)
    Brigadier General:
  • 7,191 Answers
Thanks for using FixYa.
Please let us know the complete model number of the phone.
Posted on May 15, 2010
What is meant when screen says out of range
You will need to take your handset closer to the base because the signal is weak and out of range. Try locating the charging base in a more central location. If this doesn't work try this.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
For more info go to this site
Customer Support
Feb 27, 2015 | Uniden Dect6.0 Digital Answering Syst W...
How do I find messages/mute?
To hear your messages, press PLAY on the base.
To mute, press CLEAR on the base.
See pages 22 and 6 of the manual: Owners Manual User Guide for Uniden Dect2188 3 Dect 6 0 Cord cordless...
Feb 22, 2015 | Uniden Dect2188-3 Dect 6.0 Cord/cordless...
THE BASE SET OF MY UNIDEN 1480-3 CORDLESS PHONE NO LONGER BEEPS WHEN I HAVE A NEW MESSAGE. CAN ANYONE HELP?
You can set or change the answering system options from any handset.
Open the menu and select Ans setup then select Message alert and activate it!
Beeps will be on!
Oct 05, 2014 | Uniden DECT 1480-3 Black Cordless Phone w/...
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
Dec 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
My uniden hanset stopped working. When I click on
Disconnect your phone from the wall and charger....Take out the Batteries and wait 2 secs...Replace batteries and recconnect phone ..see if this problem is still happening.
1. Disconnect Battery from handset(s)
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Heres a site for more help:http://mycusthelp.net/UNIDEN/supportkbitem.asp?sSessionID=&Inc=1093&sFilA=Product&sFilB=Model&sFilC=&FA=-1&FB=-1&FC=-1
(Copy paste to browser)
Mar 08, 2010 | Uniden Cordless Phone
Uniden base display does not work after chargin for 1st time.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
May 05, 2009 | Uniden DECT 6.0 Cordless Phone ID
After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Question:
Answer:
May 05, 2009 | Lands Phones
Wharfedale digital orb twin phone
TO REGISTER A HANDSET
[At the base]
1. Press and hold the the PAGE button on the base station for at least 3 seconds. You have 90 seconds in which to register a handset.
[At the handset]
2. Press MENU and scroll to ADVANCED SET and press MENU
3. Scroll to REGISTRATION and press MENU
4. If necessary scroll to display REGIST.BASE and press MENU
5. BASE 1 2 3 4 is displayed and the registered base number is flashing.
6. Enter the number of the base you wish to register to your handset. If you have only 1 base station, press 1. If you have 2 base stations, press 1 or 2, etc.
7. When the display shows PIN---- , enter the base pin.
8. When the handset is registered to the base it is assigned a handset number.
If you have forgotten your PIN you will need to:
Reset your ORB
1. Press MENU, scroll to ADVANCED SET and press MENU
2. Scroll to RESET UNIT and press MENU
3.CONFIRM? is displayed. Press MENU
[NOTE: Entries stored in the phonebook and new answering messages are retained. You PIN will return to the Default setting 0000]
To Set the PIN
1. Press MENU and scroll to ADVANCED SET and press MENU
2. Scroll to PIN and press MENU
3. Enter the current 4 digit master PIN and press MENU. [Default setting is 0000]
4. Enter the new PIN and press MENU
Hope this has been helpful!
Rob
Dec 28, 2008 | Uniden Cordless Phone
Uniden cordless
Had same problem, answered AMOST completely by the owner's manual, which you can find here:
http://www.quadro.net/DCT646om.pdf
I recommend these steps in this order:
1. Try unplugging the base set for 30 seconds, then plugging it in again.
2. If that doesn't work, these steps come from the manual:
• Check both ends of the base telephone line cord.
• Make sure the AC adapter is plugged into the base and wall outlet.
• Disconnect the AC adapter for a few minutes, and then reconnect it.
• Remove the base ID (see "Replacing the Base Setting" on page 27) and register the handset
(see "Register the Handset to the Base" on page 50).
• Make sure that you are not too far from the base.
• If an outside call is already established, you can not be able to make another outside call.
3. If at any point you get the "Registration failed" message when inserting a phone into the cradle, try unplugging the base for 30 seconds again.
4. If your situation is like mine, you'll probably want to get new batteries, which is what started the whole problem.
Good luck.
Feb 19, 2008 | Uniden DCT646-2 Cordless Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
278 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
