I have a MX-3501N Sharp Copier that is giving us a Call for service Code:H4-00. Is there a way for me to fix this?
  • 10,515 Answers
The H4-00 error code means that you have a defective fuser. The unit has detected that the fuser is not heating up correctly and the fusing lamp is either defective or the thermal fuse is blown. Unfortunately, It will not reset until one of these items are replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 15, 2010
Sharp MX-3501N will not accept envelopes
here is a walkthrough for printing on envelopes. basically you have to set the machine for envelopes then set your print job for envelopes.
How To Print on Envelopes or Labels on Sharp Printer
Copier Collin Houston TX Copier and Imaging Expert
Jun 30, 2014 | Sharp MX-3501N All-In-One Printer
Sharp mx-350n will not print in color from the network
Which model is it? The MX-350N is black and white, the MX-3501N is a color model. I'll assume it's the MX-3501N.
Either it's defaulted to print B&W in which case you just go to your printing preferences of the print driver in the printers menu in the control panel, and uncheck the "black and white print" box, or you have account/user codes that you need to enter in your print driver in order for it to print color. Instructions for adding a user code to the printer driver are found here.
Setup and Manage User Codes Account Control on Sharp Copier
Feb 03, 2014 | Sharp Mx-3501n Color Copier Printer...
Macbook can't connect wirelessly to sharp 3501n copier
I think you don't have the right driver for connecting it. Check it with other comp once or cellphone.
Engine Performance Chip
Aug 08, 2012 | Sharp MX-3501N All-In-One Printer
How to clear error code L4-06 for Sharp Mx-3501N
If you power the machine off and on and it comes back, try replacing the whole transfer belt unit. If it still comes back, sorry dude you're out of luck. Your copier can't swing the hinged portion of the transfer belt on and off your color drums because a badly designed gearshaft for your transfer lift motor has worn out and probably ate up a bearing or bushing as well. This is a known problem and Sharp has published a service bulletin addressing this. It may be motor rebuild time for you, with the new edition gearshaft.
Feb 08, 2011 | Sharp MX-3501N All-In-One Printer
Our Sharp mx-3501n copier flashing improper cartridge code: f2-70 and will neither copy nor print. If we restart the code still remains never go out, Do you know what is the problem? Thanks. my...
Your copier is not accepting your black toner cartridge (F2-71 Cyan, F2-72 Magenta, F2-73 Yellow). It either is not inserted properly, the packing tab is not removed from the back, or a faulty cartridge. Often 3rd party cartridges that the manunfacturer "guarantees" will work will bring this code. In short, the copier is rejecting your black toner cartridge and you should replace it.
Oct 25, 2010 | Sharp MX-3501N All-In-One Printer
I got call for service code: h5-01 I already took 3 papers that were jam but still the error code are still there. Please help... Sharp mx-3501n
press these keys
#, *, c, *, or
#, *, c, #
if input correctly copier will ask for simulation code
type in 14 then start
01 then start
if it ask are u sure after inputing 14 then start hit yes or 1 for yes or execute. copier will restart. all will be fine untill the next three jams
Jun 11, 2010 | Sharp MX-3501N All-In-One Printer
HI HAVE SHARP MX 3501N COPIER , TORE TRANSFER BELT
You really dont want to do this. It is tricky. The new belt can be pinched and ruined extremely easily, and you are required to apply it with a special lubricant. In case you really want to, The supply item is MX-4501Y1. That is just the belt. There is another kit for the transfer rollers inside. If you want to buy. $150 email me.
Remember, kit wont work without lubricant
just4fixya@gmail.com
Feb 27, 2010 | Sharp MX-3501N All-In-One Printer
Sharp MX 3100n showing code H5-01 , what is it,how do I fix
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Feb 19, 2010 | Sharp MX-3501N All-In-One Printer
101 people viewed this question
k24674
jasbo
jasbo
