Question about IOGear GCS632U 2-port KVM Switch
I know i hooked everything up correctly, the mouse and keeyboard switch work just fine but, when i plug in the monitor the screen goes blank.
  • 30 Answers
With the GCS632U is recommended that you keep the KVM focus on a computer while it is booting. For example if both computers are turned off you can turn computer one on and the GCS632U should stay on computer one until it comes to a desktop. This allows the KVM to pass the monitor information and that may help.
Posted on Aug 13, 2010
Dell e193fp goes blank at times
From the description there are bad solder connections on the power supply board and since the monitor is 7 years old there is a good chance some of the capacitors need to be changed.
Jul 11, 2012 | Dell E193FP 19" LCD Monitor
I have been using my Iogear kvm switch for almost 2 years now to switch between a desktop and a laptop, both Windows XP. I unplugged the laptop in a hurry to go do a presentation, and plugged everything...
This almost sounds like the display setting on your laptop was changed to an external device. Most laptops are designed to be hooked up to an external display, such as a monitor or projector, specifically for presentations. You can alternate the display options in the following ways:
  1. Laptop display only
  2. External display only
  3. Laptop+External clone
  4. Laptop display + extended desktop on external display (dual monitor setup)
Check your laptop display settings and make sure that it's not in presentation mode (options 2-4) before connecting the KVM switch to it. It may be recognizing the KVM switch as an external display in option 4 mode.
Mar 25, 2011 | IOGear GCS634U KVM Switch
Samsung 22inch lcd monitor goes blank after 1min idle system.
Hello sir, I have samsung 22in lcd monitor and nvidea fx5500 card. since last more than 6 months, my monitor goes blank If system remains idle (means I don't move mouse and don't touch keyboard) for 1 minute. After monitor goes blank I have to move mouse to brink it back to on. The power led keep on during this problem. I tried everything including power options in windows but could not fix it. Is it bios setting to be checked or could it be windows bug? Please help
Mar 23, 2010 | Acer X193W LCD Monitor
Black screen
Sounds like your screen is being switched to "Power Save" mode due to inactivity. This should switch back when the mouse is moved. This can take several seconds on a laptop. You can remove this "Power Save" by right clicking anywhere on blank desktop, select "Properties", "Screen Saver" and "Power Settings" then select "Always On" for the monitor.
Sep 13, 2009 | Toshiba TECRA 8000 13.3" TFT LCD Display...
Monitor is blank!!!!
Firstly, the LCD+external setting will switch one or the other or both on.
Secondly, if you go into your display properties (or even the advanced page where your video card additional features are) you can usually select which monitor is "primary".
I suspect that your external display is primary, and the LCD screen is not "enabled" or used as part of the desktop.
The settings are all there, it's just a matter of finding them (depending on what video card is in whatever laptop you have)
This might have happened in the first place if you accidentally hit "Fn" and one of the "F" keys up the top. Fn + F6 on my laptop will switch LCD/external monitors on and off. (for example) There is usually a little blue picture on one of the "F" keys to denote that function.
Sep 09, 2008 | Toshiba Satellite A105 Notebook
Screen goes blank when I move the mouse
Did it work properly using a VGA (analog) cable? If so, check your DVI (digital) cable against the pictures at the bottom of http://www.datapro.net/techinfo/dvi_info.html.
You probably have one of the two at the left. Each has a different bandwidth, translating to a maximum resolution. The native resolution for your monitor might be marginal if you have a single-link DVI-D cable.
My 204B seems very picky about signal-level. It blinks when connected by DVI, even though it should be fine with a single-link cable, and complains about the settings even though the settings are optimal. Maybe yours is similar. I have ordered a dual-link cable and will try that myself.
Feb 13, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
ViewSonic VG170m 19 in. flat screen monitor
plug it in at the back of the monotor.....i left my connector undone and it fell out a LITTLE bit on one side of the connection and all i got was a blank screen also.
good luck
Feb 11, 2008 | Computers & Internet
I own a evo n510c
If you are hooked up the the external monitor and/or TV and can see the desktop, you can probably reselect the internal display via software from Display Properties.
In most cases you can change from the external display to the internal and vice versa by holding down the blue Fn key, and hitting the proper number on the keyboard. The correct key has a blue icon meant to resemble a monitor on it.
This is if the repair/replacment of the internal screen was done correctly and the screen is actually working. If the screen is not actually working, though, this will not help you.
Jan 28, 2008 | Compaq Evo N610C Notebook
Fujitsu c series labtop screen goes blank, the hooked up to a monitor, starts to work then says out of frequence and goes blank
The video resolution and/or frequency that's set in windows is not supported by the monitor you have plugged in. Restart the PC in VGA mode (hit F8 after the BIOS messages but before any Windows messages) and change the video settings to something basic, such as 800 x 600 @ 60 Hz. Then restart the machine normally.
Jan 21, 2008 | Fujitsu LifeBook C6555 Notebook
Open Questions:
See all IOGear GCS632U 2-port KVM Switch Questions
IOGear GCS632U 2-port KVM Switch Logo
470 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
