Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Only green light on
Only the green light is on. The blue and orange lights will not come on and the green light will not turn off even when power is pushed. Therefore, all I can watch is snow..
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
Shanonl,
If the lights will not turn on, try unplugging the receiver from the electrical outlet for about 10 seconds. Plug the receiver back in, which will make the receiver reboot and re-acquire satellite signal. If the receiver does not turn back on, at least the green and amber lights on, we may need to replace the receiver.
Ray Calo
DISH Network
Posted on Jan 20, 2011
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
What is the wiring diagram for the stock radio
Check this...
1998 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Light Blue/Red
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: N/A
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 5" x 7" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Hope helps (remember to rate and comment this answer).
Feb 16, 2011 | 1998 Ford Taurus
What color is the power antenna wire for a 1995 ford explorer
Check this for 1995 Ford Explorer Car Stereo Wiring Diagram...
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Hope helps (remember to rate this answer).
Dec 31, 2010 | Ford Explorer Cars & Trucks
No power, backfiring thru the carborator. need to know what the problem is
Hello! lets check the Manifold Absolute Pressure (MAP) and the Throttle Positioning Sensor (TPS) in that order...if you have a multimeter and a wee bit of experience using one both of these sensors can be tested...If not replace the MAP first and the TPS second...
The MAP has a three wire connector with wire colors Orange/White...Blue/Light Green...And Black./White...using two safety pins push one into the rear of the in-place connector into the Blue/Light Green...The other into the Black/White...connect the + probe of the meter set to read 5 volts on to the Blue/Light Green pin...the - probe to the Black/White pin...turn key to on...Meter must read at least 3 volts...If not MAP is defective...
Using the same technique lets test the TPS...Three wire connector Green/Light Green...Orange/White and Black/White...Safety pins into Green/Light Green and Blue/White...Set meter to read 5 volts...Place + probe of meter on Green/Light Green pin...And - probe on Black/White...start the engine...at idle meter must read less than 1 volt (.85)...slowly increase the idle (as best you can)...Meter should rise smoothly to 4 volts...If it skips, jumps or acts erratic the TPS is defective...See pictures below...Guru...saailer
saailer_28.jpgMAP
saailer_29.jpgTPS
Dec 07, 2010 | 1984 Ford F 350
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Had to cut the factory harness
trick of trade... take a 9 volt battery and touch the wires to it.. the speaker will pop and you will know which one is which... do one color at a time
Apr 21, 2009 | 1993 Ford Explorer Limited
Mercury cougar
Constant 12V+ Black/Orange Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Light Green Dimmer n/a Amplifier Remote Dark Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Side Panels Left Rear (+) Pink/Light Green Left Rear (-) Tan/Yellow Right Rear (+) Pink/Light Blue Right Rear (-) Brown/Pink
Sep 28, 2008 | JVC AM FM CD DET FACE CAR STEREO
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
495 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
