Question about Panasonic PT-47WX49 47" Rear Projection Television
I need someone to come to my home and clean the projection light bulbs inside the tv. ive had the tv for almost 7 years and i think it could use a good cleaning and re-align the lights
    President:
  • 1,619 Answers
Your going to want to call a local repairman as this is a question and answer service.
Posted on May 15, 2010
KF-50WE610 blotch of color on screen
Either dust/dirt inside (unlikely but possible) or a damaged optical light engine--Google the model number with "problems" etc.
Apr 17, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Clean bulbs on a D56W136D
Hello. Here are the steps to a perfect cleaning job:
  1. Power down TV and unplug all cables attached to back of TV, including TV power cable. You never want to risk touching components inside the TV that could be hot, including a rear-projection bulb.
  2. 2 Unscrew and remove back cover of TV. Have someone help you if the TV is big or back cover is heavy. Most TVs will unscrew easily, but refer to your TV owners manual for specific instructions.
  3. 3 Locate and unscrew bulbs housing unit. Your owners manual can again be used to find specific instructions on how to properly unscrew bulbs housing unit.
  4. 4 Clean bulb with soft cloth and cotton swabs. Never let your bare hand touch the bulb. The oils on your hands can cause the bulbs to deteriorate prematurely. Be gentle with the cotton swabs to avoid breaking or cracking anything.
  5. 5 Reattach bulbs housing unit.
  6. 6 Reattach the back cover and have someone help you again if you needed help taking the back cover off.
  7. 7 Attach all media devices and power cords.
  8. 8 Power on the TV and begin watching.
Joe
Thanks for choosing Fixya!
Nov 29, 2010 | RCA Televison & Video
Picture is not bright enough, very faint, and cloudy. Appears as if the bulb is not bright enough or something. It has not been replaced recently. Cleaned the filter, checked settings. Does the bulb...
The coolant inside each of the tubes need to be flushed cleaned and refilled.Over the years of the TV's use, the coolant gets cloudy from heat. usually this kind of service can range from $350-$650+ dollars. Its not an easy job... Call your local TV repair professional to find what they charge to refill coolant. You can CLICK HERE to find a TV repair professional in your area, just type in your zip. 'best wishes'...
'if this helps you please rate, its like a donation :-)
http://tvtechwork.webs.com/
Oct 26, 2010 | Mitsubishi WD-52525 52" Rear Projection...
On-going problem where tv is turned on and almost immediatley says it will shut down because of an air-flow problem. After turning on several times it used to then work but lately it just repeats the same...
The fan is shorted and might be dead.The projection bulb been in the tv and used for the last 3 years?The projection bulb,life span are over.Require a new projection bulb.
Jul 04, 2010 | Mitsubishi WD-57732 Projection Television
Sony kdf-E2000
I've seen this exact problem before and it was the lamp. Take it out (if in doubt) and look for glass fragments in the reflector. Even if the glass capsule isn't shattered, the bulb can still be bad. This is the easiest failure to visually confirm. A lamp should last between 2 to 3 years depending on the amount of daily use the TV gets. Should a bulb last less than two years the lamp cooling fans may need cleaned. Homes with a dust problem, smokers, pets and open windows are more prone to dust accumulation inside the TV. If you take the lamp out and see dust bunnies inside the lamp housing, the set should be cleaned and fans checked for dust deposits. Every six months or sooner vacuum the rear cover panel and area behind the entertainment furniture.
Jul 28, 2008 | Sony KDF46E2000 46" Projection HDTV
Sony 55" rear projection tv
TIGHTEN THE BULB --AFTER YOY CLEAN THE DUST OFF THE BULB VENTS ON THE BULB ITSELF. PROBLEM SOLVED. EASY--CHEAP. Hey it worked for me. My picture was turning off blinking 29 times for picture 37 times for audio. This was the first issue with my KDF-55WF655 since I unwrapped it almost 5 years ago......... ITS STILL ON!!! I hope this helps someone.
Feb 14, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KP-61HS10 61 in. Rear Projection Television, dirty innerscreen
The important thing here is cleaning the refelective mirror inside you tv .We have noticed in dirty areas the dirt on mirror makes blurry picture.THerefore you have to open back cover and than tp cover to clean mirror and also dont forget to claen c.r.t lenses ,sisnce they are mounted facing upward ,lot of dust sit on c.r.t lens there fore clean 3 of them r.g.b..And you will notice on picture diffrence.
Dec 18, 2007 | Sony KP-61HS10 61" Rear Projection...
Mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Jan 06, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
116 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
