Question about Furuno FCV-582L GPS Receiver
I have a furuno fcv 582l. The unit has just come back from the factory and works well until I power up any other electronic equipment on the boat. Then it flickers and the screen goes dark. Any ideas?
Check the voltage getting to the device. You can set this to display using the menu. These sounders need about 11 volts minimum to work. I had a similar problem until I installed an additional battery to supply my accessories.
Posted on Jul 02, 2010
    New Friend:
  • 132 Answers
You likely have inadequate supply to your helm. Otherwise, there is interference being generated. Try turning things on slowly one at a time, check your batteries and ground connections.
Posted on May 31, 2010
Hi,do I have to ground my fcv587 if I run straight from my 12v battery?
Grounding the unit is recommended by the manufacturer but the unit will work ungrounded. The negative DC input point is not necessarily chassis ground so connecting the power leads won't assure a direct ground connection. The reasons for grounding the chassis range from external noise reduction to lightning protection to electrolysis reduction.
Mar 21, 2014 | Furuno FCV 587 Color Fishfinder
How do you get the Furuno FCV 295 out of demo mode?
go to the ' menu ' page -- scroll down to ' simulator ' -- and choose simulator OFF.
the unit should work fine after that.
fish on (!!!)
c...
Feb 02, 2011 | Furuno FCV 295 104" Fish Finder
LCD coating needs to be replace or LCD REPLACED
Since you have little to loose you can attempt to remove the protective coating and not attempt to replace it with a substitute material. It's not required to operate but is intended to enhance viewing in certain light conditions. Might try a window cleaner with ammonia and a little "elbow grease". Remember though, your end result could be worse than what you have now if you're unable to completely remove the film or damage the JCD panel in the process.
Jul 14, 2010 | Furuno FCV-582L GPS Receiver
INSTALLATION MANUAL FURUNO FCV-585 BEST GROUND FOR THE UNIT SHOULD I GROUND IT TO ENGINE OR BELLHOUSING OF OUTDRIVE
Attach to engine grounding point with battery cable. Add a grounding plate for RF (green) ground.
May 03, 2010 | Furuno Fcv 585 Color Fishfinder
Furuno fcv-667.When powered on good screen comes on for 1-2 seconds, then goes to a solid blue screen
1. Check that you have not altered settings - HUE, that is, background colour.
2. Go to menu - select FACTORY SETTINGS and try that. The unit may go back and rectify.
3. Check depth setting - if greater than depth operating, will show just blank screen.
Hope this might be helpful
Jun 14, 2009 | Boating
Furuno Colour Video Sounder FCV-68 tech diag need.
most are available from furuno, but not FCV 68 are you sure that is the model #?
Apr 11, 2009 | Furuno 1623 Radar 16nm Range
LLOKING TO BUY A REPLACEMNET TRANSDUCER FOR A FURUNO FCV-582L
Yes, the current model of this is the FCV 585 and it is great. The transducer will need to be changed.
Apr 07, 2009 | Furuno FCV-582L GPS Receiver
I have a furuno fcv 585 echo sounder with a FURUNO CA50/200-12M -c13298 BRONZE THRU HULL HIGH PERFORMANCE TRANSDUCER. The transducer has 4 wires and it looks from the schematic that it attaches via a...
you need an MB1100 matching box has the 10 pin pigtail for your sounder and accepts bare wire input from your ducer
this will also ensure that all power from sonar get to ducer, but it from me if you like 847-746-0100
Jul 09, 2008 | Furuno FCV-582L GPS Receiver
Furuno 582L
those jacks are on a circuit board available from Furuno call me if you like 847-746-0100
Mar 23, 2008 | Furuno FCV-582L GPS Receiver
Furuno FCV-582L GPS Receiver Logo
337 people viewed this question
Top Furuno GPS Experts
Ron Dufek
Ron Dufek
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
