Question about Vizio L32 32 in. LCD HDTV
My television picture is out
It's not a cable issue. It's out on all inputs
Ghost images
Is this a projection? If so the internal components could have issues and I wouldn't recommend trying to repair that. If it is a LCD or Plasma if may be an issue with that specific input or cable. Try another input like the antenna or cable input and see if it has the same issue. If it does the issue is again internal. If not than the one input may be the issue. Try replacing the cable or changing the device on the bad input. It that works great if not, you may not be able to use the one input. Also try and unplug the TV for an hour and try again. Good luck!
Apr 09, 2014 | Televison & Video
PS3 wont display using HDMI ports and Input connection on PT-52LCX66
It would seem either a setting at the ps3 or the set is not right.
Good idea to check all inputs and setup again--if something like a DVD works on rear input issue is with the PS3.
Mar 14, 2012 | Panasonic PT-52LCX66 Projection Television
My Dell 42 inch plasma tv has an issue with the picture blinking on and off when using the HDMI input. All of the analog inputs work fine.
Plz check your cable which is connect between your cable operater and your tv or set up box and tv. Try this and attach cable should be properly.
Apr 04, 2011 | Televison & Video
Our AKAI is a 42'. The screen displays squares of color, not the picture, no matter what input is selected, cable or Blueray. We do hear sound but the picture is messed up. Yesterday after it was on for a...
check cables, make sure all are undamaged and secure. Try troubleshooting different sources of video input (ex. dvd players, satellite boxes, game consoles). If you find a specific device to be the issue and not the tv then post a new problem. Otherwise it is possible that your tv has damaged hardware and requires maintenance and/or replacement.
May 20, 2010 | Akai LCT3285TA 32 in. LCD Television
TV sound but no picture
Can you tell me which Cable box you are using?Which model/region?
The possibility is that the HDCP handshake could not have happend correctly and hence the issue. Try to connect to different HDMI input of TV from Cable box. If possible change the resolution of cable box and check video
Nov 01, 2009 | Philips 50PFP5332D 50 in. Plasma...
1/4 of image on screen, similar to a picture in a picture. Could this be a problem with my cable and its' remote. TV was fine earlier today. Maybe something got pushed accidentally on TV or Cable remote...
Change to DVD or some other input and see if the issue is still there. If it's a TV issue the problem will be there no matter if your watching basic cable or a DVD. If the problem goes away then it's an issue with the cable.
Rarely does an issue like that only effect one input (ie Cable)
Sep 27, 2009 | Memorex MLTD2622 26 in. LCD TV
I just replaCED THE LAMP AND NOW i CAN'T GET A SIGNAL FROM MY CABLE BOX
try bypassing the cable box and plug the cable directly into the TV if you have a snowy picture you might have a cable issue. Also make sure you can view a movie from a DVD player.If your DVD player does not show a picture then you might still have a TV issue but if it does the problem is either your cable box or it's the cable going to the TV either not plugged in or defective.Also try moving your cable from the cable box to a different input on the back of the TV you could have a issue with only that one input (video source).
Jul 07, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Poor picture quality on cable input
Try swapping some cables around, like the skart lead from the dvd(if scart) for the cable one, if the picture problem swaps with the lead then thats the problem. If it doesn't try settings on the cable and tv, if the cable is sending nvbs signals and the tv is set to pal then this can also occur.
Jun 30, 2009 | Dell W2306C 23 in. HD-Ready LCD Television
Re-soldering the flyback transformer now I get no picture
check to see if you have it on the correct input with cable connector channel up or down. the fact that you have picture on other inputs tells me the signals not getting through somewhere. and it possible its not being routed correctly. so try changing inputs on remote also try searching for channels with cable plug up to it. Physicaly there may be a tuner issue.
Sep 26, 2008 | RCA R52WH73 Projection Television
Vizio L32 32 in. LCD HDTV Logo
83 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
