Question about Fisher PC-36S90 36" TV
Picture "wobbled" and set turned off. Set will not turn on.
My set was made in 1998. The set had been on for about seven hours. I noticed that the picture was wobbling and then the unit turned off on it's own. I unpluged the set and let it cool down. I pluged it back in and it did not work. I checked the internal fuse with a multi-meter. It tested good. The circuit boards were very dusty. I cleaned them with a soft brush. I saw no obvious burns on the circuit boards.
  • Fisher Master
  • 1,229 Answers
This TV may turn back on, if you let it set for a few days or week unplugged.Then plug in and see if it will try to start. If that is the case you have one or two bad capacitors. Look for values in this range....160 volts to 250 volts at 1 mf to 4.7Mf. Theses will certainly go bad. And suspect any of those that may be 16volts to 35 volts at 100Mf.You said you have a good fuse, correct? Also check out any bad grounds under the flyback transformer, power resistors and ICs mounted on heatsinks.You may have another fuse, please check again for a second fuse. If the fuse is blown, you have a problem that may cost more than your TV is worth. Remember this TV may have a lot of miles on it! Thanks for asking!
Posted on May 15, 2010
Testimonial: "samgjanm@aol.com: Great info! I will a follow thru with your advise and diagnose. Thanks"
  • matt martin
    matt martin Feb 18, 2011
    You are most certainly welcome!
How do set the clock on my 1998 chevy Malibu radio?
If the radio has a set button: Turn key on and radio off. Press the set button and use the right seek button to set the minute and left seek to set the hours. If it has no set button: find the hour and minutes buttons or holes under the auto tone knob. Turn key on engine off and radio off. press the left button for the hour and right button for minute.
Sep 18, 2014 | 1998 Chevrolet Malibu
1998 s70 wobbles front end at low speeds
Go to an Alignment Only Shop & have them road test
while you ride along
Then have them inspect for worn parts
Nov 29, 2012 | 1998 Volvo S70
Tv is on with no picture or sound, only 4 months old!!
Hello
The power supply regulator board to your set has the fault. If you try to open the set, or try to repair it by yourself, the warranty will void. The set must have warranty as it is new. Why do you spend for it? Just contact the nearest authorised service center for Sceptre. the components in this set will be very hard to get from open electronic spare part market, and will costly too.
Mar 11, 2012 | Sceptre 32 X320BVHD 32 LCD TV
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
The instructions are not very clear on my new UPM ET420C Electronic Outdoor Timer. What I want to do is have the time turn on power everyt morning at 3am, run for 2 hours, and stop at 5am. Could you tell...
Using the right & left arrows, go to CLOCK to set the current time & day.
Press SET
Using arrows, set the day, press SET.
Using arrows, select the hour, press SET.
Select the minute, press SET.
Select the second, press SET.
Using right arrow, press once for program 1.
Press SET.
Select day, press SET.
Select hour, press SET.
Minute, SET.
Repeat this for every day you want this program, five days or seven days,
Programs 1-5 or 1-7.
Gary, good luck, these instructions are difficult.
May 27, 2011 | UPM Programmable Outdoor Timer
When the product description says "7 on/off
Yes.
The way the programming mode works, you can sert it any way you want. At work, we use it to run the coffee pot. it is set for 5 "OFF" times (5PM, 6PM, 7PM...), so if someone turns on the pot after 5, it will turn off at the next hour (so the pot doesn't burn).
I use one of these at the house, and use it like a regular times.
Dec 05, 2010 | Intermatic & Self-Adjusting Wall Switch...
Please tell me how to program my timer. How do I set the time and when it should come on and go off everyday
Smarthome has the T-1032 pdf manual
http://www.smarthome.com/manuals/4256.pdf
1) Test installation to see if your wiring technique is correct.
Open cover > set on-off switch to 'ON'
Press the tiny round reset button with paper clip
Screen displays 0:00, MO, MAN, OFF
Close cover
Push cover inward like a push-button (the cover is the manual override)
Lights should turn on
If lights don't turn on, then you need to rewire ... so re-post a re-wire question ... and then come back to this answer to program
2) Set Time and Day/ Correct time and day are needed for programs to work.
To start, notice on the screen - in the corners are little letters: MAN, MO, OFF. And to left of time is PM.
Set the Hour: Press hour button until correct hour shows, including PM or AM
Set minutes: Press MIN button until correct minutes show
Set the day. Press day key ... MO in corner changes ... for example TU is Tuesday, WE Wednesday, TU Thursday
Press one of the control buttons to finish operation
Programming overview
Timer allows 7 programs
Program 1, Program 2 etc
Each program has ON and OFF time
So you have to select Program 1
And then set DAY for Program 1, set ON time for Program 1, and then set OFF time for Program 1
Next you do the same for Program 2 , and then Program 3, 4 etc to 7
If you only want Program 1, then you do not need to set Programs 2 thru 7
Let's program
Press PGM button ... the timer screen show a P to right of time
The number 1 appears below P and indicates Program 1
Set days you want Program 1 to work: Press day button and you can see MO TU WE TH etc appear on screen.
If you want all week long, press day button until all 7 days appear in tiny print on bottom of screen
Now you have the Day set for Program 1
Notice the screen shows ON ... this means you are going to set the ON time for Program 1
First, Set hour you want Program 1 to turn ON: press Hour button until correct AM PM time shows on screen
Last, set minutes to go along with hour: press MIN button until correct ON time minutes show
You have the day, hour and minute set for ON time
Set OFF time for Program 1: we are going to set a Day, hour and minute you want Program 1 to turn OFF
Press PGM button, and notice that OFF appears in top right corner of screen
Set the day you want timer to turn OFF for Program 1 by pressing DAY button >>> Tip set same days you set for ON times. So if you selected all seven days for ON time, then select all seven days for OFF time
Set the hour and minute you want Program 1 to turn OFF by using Hour and MIN buttons as before.
OK, the ON and OFF day, hour and minute are set for Program 1.
To continue to Program 2, press PGM button until a 2 appears on screen below the P
If you do not want to set more Programs, then you're finished
To finish, press any control button
Close the lid, cross your fingers, you did good
Sep 30, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
Set wont turn on, Beeps.
Try Resolder all of the Big Diodes around power supply.
Feb 18, 2009 | RCA P52960 52" Rear Projection Television
Wavy picture and turns itself off after an hour or two.
when the set shuts down if you try to press power again does the led blink? If so let me know how many blinks it blinks
May 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
Fisher PC-36S90 36" TV Logo
70 people viewed this question
Top Fisher Televison & Video Experts
matt martin
matt martin
Mike
Are you a Fisher Televison and Video Expert? Answer questions, earn points and help others
